08-07-2020, 06:39 PM | #1 |
Rep 119
Tyres PSI dramatically increases in hot weather?
Hello,
I have an F30 330e 2017 with new 'go flat' tyres - MPS4. Revently there's very hot wather in the UK (35c a lot for the UK) and I noticed that when I took the car to a short drive on the motorway today (around 30 miles? not much) the PSI in the fron tires reached 47(!), I keep ot at the spec 41 usually and the tire sidewall says don't inflate it to over 50. Is this dangerious? What shoudl I do if I go on a long drive? let some air out of the tires (they'll be warm naturally). Thank you! |
08-07-2020, 06:46 PM | #3 | |
Rep 119
Just worried that is I drove 300 miles instead of 30 the PSI could reach over 50 PSI... Also the manufactures presures assume runflat tyres, maybe go flats are different? I realisethere are many far hotter places than the UK... |
obert1781.00 |
08-07-2020, 06:55 PM | #5 |
Rep 4,456
I know people have different preferences on tire pressure but for me 32lbs is what I run in normal tires and run flat tires. The only time I would run less is if I had a race car or off road vehicle while off reading for better traction.
08-08-2020, 03:16 AM | #6 |
Rep 119
08-09-2020, 12:00 PM | #7 |
Rep 878
Is 41 really the recommended normal inflation pressure? Seems a bit high to me.
Not the same model but for my staggered setup I run at a max of 37 all round. |
08-09-2020, 01:18 PM | #8 |
Rep 119
These are the recomended pressures for my car - I have the staggered 18":
08-09-2020, 10:07 PM | #9 |
Great Teacher
1079
Rep 1,303
Drives: 06 e91 325ix
The 50 max is cold pressure, don’t worry about it, Increase due to heat is already accounted for in the engineering of the tire.
I had the inverse problem, it was super hot and then cooled off when it started raining super heavily and the tires Cooled and dropped pressure so dramatically the TPMS threw a flat tire alert!
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
RoundRound30.50 |
