09-27-2019, 10:30 PM | #1 |
Rep 191
Hey guys,
So I've been experiencing what I would describe as excessive road noise from my car. The sound reminds me of my 2009 VW Jetta, tires out of balance and super worn. I've noticed it for a while now and feel like it started happening (or I started hearing it) a thousand miles before I changed my tires out. At that time, I assumed it was the tires but when I replaced them the problem persisted. The annoying droning sound starts around 25 mph and progressively gets louder until cruising speed of about 80mph. No change when coasting w/ transmission on neutral or turning left or right. 2015 F32 19" Staggered OEM 403s Bridgestone S001 run flats Front 32 PSI, Rear 35 PSI Any experience with this or insight would be appreciated. |
09-27-2019, 11:29 PM | #2 |
Rep 3,225
These cars have always had excessive road noise.
I’m sure there would be a 100 threads in the topic. AFAIK is comes down to lack of sound deadening etc. |
09-27-2019, 11:36 PM | #3 | |
Rep 191
Looking for experience/insight into 4 series specifically. |
09-28-2019, 12:13 AM | #5 |
Rep 191
Thanks. Assumed they were close just based on this combined forum. It's odd I never really seemed to notice it before. I'm really wondering if different tires will a noticeable difference.
09-28-2019, 12:28 AM | #6 | |
Rep 10,473
Speed numbers are about right. |
09-28-2019, 12:31 AM | #7 | ||
Rep 191
09-28-2019, 12:33 AM | #8 | |
Rep 10,473
The things you eliminated (tires) and the sound with no changes coasting, turning etc makes it more likely that could be the issue. Just repaired and major difference in the sound. |
OC_F32118.50 Onizukachan1086.00 |
09-28-2019, 03:47 AM | #9 | |
Rep 15,858
Does the sound level change when you drive on different road textures? To illustrate, my typical drive includes varied road surfaces. My 5-series can vary from quite a lot of tire noise, to virtually silent on some sections of road. Bearing noise would definitely show up on those quiet sections. |
OC_F32118.50 Lance_Goodthrust4.50 |
09-28-2019, 09:27 AM | #11 |
Rep 16,082
72dBA at 75 MPH is about average. Mine measures 68dBA at 65 MPH, and it's as quiet as any car I've owned before. I can carry on conversations with passengers in the backseat without myself or them raising our voices. And I have run flats.
However, the dBA scale only measures the middle frequencies. It doesn't measure lows or highs, so you could have a car that measures 65dBA that's louder than one that measures 70dBA. Measured with the far more useful dBC scale the former might read 85dBC, the latter 80dBC. On average dBC should be about 10dB higher than dBA. If there's more of a differential that would indicated low and/or high frequency levels that are out of whack. Tire and road conditions would be examples of low frequency sources that might not register on the dBA scale, wind noise a high frequency source that might not register on the dBA scale. |
09-28-2019, 11:22 AM | #12 | ||
Rep 191
09-28-2019, 11:29 AM | #13 | ||
Rep 191
From what I gather searching the wheel bearing discussions, it's not a DYI job I'm comfortable (or have the to tools) to manage myself. I'm hopeful to have answers or at least an idea of the cause this weekend. |
09-28-2019, 11:33 AM | #14 |
Rep 191
The crappy part is I still have a solid 30k of wear left on these tires. Going to rule out the wheel bearing suggestions theory first. If that's not it, I suppose I could always just upgrade and sell these tires.
09-29-2019, 09:36 AM | #15 |
Rep 191
I had an opportunity to work on the car yesterday. After a bit of research online and YouTube (this forum wasn't working for some reason), I spent some time on the road specifically evaluating the sound at different speeds and turns.
The results were no different than what I experienced under typical driving conditions - noise increases and decreases with speed, no change while turning in either direction. I also jacked up each corner and gave the wheel a good spin. Two front wheels were uber smooth. Virtually no noise, brakes hardly sounded l Ike they're were pads on. The rears were about the same. Again a corner up at a time, car in neutral and it felt very much like I would expect. I had some resistance from the differential but nothing alarming by way of sound or feel. No "play", grinding, sloppiness from any wheel. And I thought the undercarriage, with the exception of a coupe of scrapes, looked pretty darn clean. I'll do some more research on bearings and noise. Will also check out tire discussions. If I don't come up with anything I may take it in to get checked out. Any other thought or suggestions are appreciated. |
09-29-2019, 04:11 PM | #16 |
Rep 5,210
another thing to consider is your own hearing. I have mild hearing loss but paradoxically it increases my sensitivity to tyre roar!
I had only done 10k miles on my pirelli rfts but swapping them to michelin pilot sport 4 has absolutely truly been great. Do it and dump your current tyres. money well spent. |
OC_F32118.50 |
09-29-2019, 04:14 PM | #17 | |
Rep 191
02-16-2020, 09:54 PM | #18 | ||
Rep 191
It was the rear wheel bearing after all
frazervalley125.00 Onizukachan1086.00 IK6SPEED4488.00 chiefneil771.50 Jostack24.00 GenXer1363.00 rphz70.00 kpgray333.00 |
02-17-2020, 02:04 AM | #19 | |
Rep 1,386
My F30 seems very road noisy after driving my ML 350. One thing I have noticed is if the Pirelli P7 runflats go a couple of PSI under the noise is much reduced. No clue what that is about except the ride height is subtlety changed. Some folk in Europe have reported issues with the under body covers drumming due to airflow at certain speeds. Mine sounds like that. Maybe I should get my local indy guy to remove the covers for a week. |
02-21-2020, 07:49 PM | #20 |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
Thanks for returning to report the solution, will certainly help others!
02-21-2020, 07:49 PM | #21 | |||
Rep 10,473
dbright0377.00 |
02-21-2020, 07:57 PM | #22 | ||
Rep 191
