02-21-2020, 08:03 PM | #23 |
Rep 4,877
My RFT's are fine until they start to wear after a couple years. The cabin noise right now (4 years on the tires) is starting to get quite high. When they were new, it was very manageable.
02-22-2020, 07:59 AM | #24 |
Rep 4,877
I had the same bearing needing swap in the first year of owning the car as well. They called it "rail bearing" being caused when the vehicle is shipped by train, and a needle in the bearing sits against the bearing race with no grease. You get a "arc" from the induced static, destroying the needle.
02-22-2020, 08:57 AM | #25 |
Rep 80
Bearings damaged during railroad shipment were first discovered during world war II. Heavy materials like tanks had the problem and it was determined that the jarring without bearing rotation squeezed the grease from the contact line between the roller and the race. The failure mode was fretting erosion on that spot on the race and roller.
02-23-2020, 02:24 AM | #26 | |
Rep 2
Thanks for info everyone. I've had my F30 for a few months now and have always thought the road nose was excessive. Almost as loud as my wife's E46 convertible..... well kinda. I'm putting some 403s on with Pilot Sports and guess I'll get the bearings looked at at the same time now.
02-23-2020, 03:27 AM | #27 | |
Rep 474
J. D. Cordier
02-23-2020, 03:43 AM | #28 |
Rep 3,966
Run flats and inadequate sound insulation, I'm afraid.
Some RFTs are better than others. Goodyear Eagle F1 Asymmetric tyres are regarded by many as the quietest. Not much you can do about the sound deadening unless you're prepared to spend a lot of cash/put in a lot of effort.
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
02-23-2020, 06:58 AM | #29 |
Rep 944
Originally Posted by OC_F32
"The issue turned out to be the rear driver side wheel bearing. It's been replaced and the dB registers at around 66 in the cabin now. Thought I'd give an update for those interested." Ahem, The OP sorted his problem. |
Billfitz8243.00 |
