BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > B58 ‘Clacking’...WTF is this noise?
European Auto Source (EAS)
      02-14-2019, 04:41 AM   #1
Minty
Drives: F31 340i
Question B58 ‘Clacking’...WTF is this noise?
My 340i is coming up to 3 years old and I don’t remember it ever making this noise on cold start. After starting and the revs dropping I can hear what I can only describe as a loud clacking noise. After another 20-30 seconds it disappears and I can then hear the normal DI injector tapping noises.
Any suggestions?
      02-14-2019, 06:21 AM   #2
dizzy619
Drives: F30 335d xdrive
Take it to the dealer...
      02-14-2019, 06:31 AM   #3
creepy coupe
creepy coupe's Avatar
1721
Drives: Mazda 6. Help
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Hydraulic tappet leaking down?
Current car.M240i.
Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
      02-14-2019, 10:24 AM   #4
RoShambolt
RoShambolt's Avatar
160
Drives: Looking
Loose exhaust mode valve flapper? I think it has been discussed in here on another thread. Mine has done it twice, I think it may be that because it's sounds similar to mine when it did it, also I believe the valves are both open on cold start, so when it goes to low idle (in comfort) the valve closes, hence the change after it has been running for a bit.
      02-14-2019, 10:26 AM   #5
creepy coupe
1721
2009 335i  [0.00]
Could be. Although the exhaust valve should be closed on cold start. mine last about 25 -30 secs before it opens.
Current car.M240i.
      02-14-2019, 10:27 AM   #6
RoShambolt
RoShambolt's Avatar
160
Drives: Looking
Sounds similar
https://www.bimmerpost.com/forums/sh...php?p=22945355
      02-14-2019, 10:29 AM   #7
RoShambolt
RoShambolt's Avatar
160
Drives: Looking
I thought it was the other way around, cars always start in comfort. Which is one exhaust pipe open in usual operation. But the turn over louder on starts until they go low idle, and that was because both valves being open. Something to do with reduced emissions on starts? I could be way off here, I've read a hell of a lot of stuff on this forum so may well be wrong.
      02-14-2019, 10:31 AM   #8
creepy coupe
1721
2009 335i  [0.00]
I think Minty's sound heavier.
Current car.M240i.
      02-14-2019, 10:39 AM   #9
RoShambolt
RoShambolt's Avatar
160
Drives: Looking
You are indeed correct. After a little digging.
I copied the below posts and text from the thread I just found.
Originally Posted by crono06 View Post
Does setting the car in Sport mode open up the flap as well? I swear whenever I put it to Sport, the exhaust is more audible. Just as reference, I have Sport mode set to chassis only (regular/Comfort setting throttle/drivetrain).
When I asked BMW for specifics of when the exhaust will be open, they said during cold starts, the left exhaust pipe will be closed for approximately 1 - 2 minutes. I was told they designed this for both noise-control reasons and vehicle warm-up. You will then here it open up and it will remain open.
However, while driving in Comfort or Eco Pro, it will adapt to driving habits. If you are not accelerating harshly, it will keep it closed most of the time to give off less sound. If you floor it though, it will open up. It will continue to open in close based on how much you are trying to accelerate.
When in Sport/Sport+ mode, the exhaust flap will remain completely open and the exhaust will start having more noise (the gurgling sound) whenever the engine RPM is decreasing. To hear what I'm talking about, roll down your windows and manually downshift to kick up your engine RPM to around 2500 - 3000 RPM and let the engine speed decrease. I usually hear it gurgle most if the RPM decreases near that range that.
Sport will also make the shifting 'grunt' noise more often in Sport mode. When accelerating hard, with the throttle past half way, manually shift around 4500 RPM and you will hear the noise I'm talking about. They didn't specify this but I believe the shifting noise is only with the Sport Auto.
Hope this helps..
      02-14-2019, 10:42 AM   #10
creepy coupe
1721
2009 335i  [0.00]
You're right. it has been discussed a lot. I think the general consensus was to heat the cat up faster.And yes reduce the emissions.
Current car.M240i.
      02-14-2019, 10:44 AM   #11
creepy coupe
1721
2009 335i  [0.00]
Hope this helps..
You might find this of interest
https://www.youtube.com/watch?v=_BB8MRGpjIo&t=45s
Current car.M240i.
      02-14-2019, 01:13 PM   #12
Minty
Drives: F31 340i
Thanks for the replies. I am pretty certain it is not exhaust noise...it is definitely coming from the engine area.
      02-14-2019, 03:10 PM   #13
Sasquartch
Drives: 328i Luxury auto
It's always difficult to tell from a sound clip from a phone, however it sounds like a noisy belt tensioner to me
But really you need to take it to a dealer for a proper listen as it could be any number of things
      03-07-2019, 08:47 AM   #14
Minty
Drives: F31 340i
UPDATE: B58 ‘Clacking’...WTF is this noise?
Picked my car up from dealer yesterday who replaced all 6 injectors - problem solved . Top marks to dealership (BMW High Wycombe) for taking it seriously and resolving under warranty.
It is still noisy on startup (as are all B58's) but it doesn't make that tapping / clacking noise now.
Master technician updated the software (not sure what modules) but all my custom settings gone. Gear change seems smoother, and cold start definitely different but other than that all good so far.
Pequin69.50
      03-07-2019, 02:17 PM   #15
cfm56d7b
Thanks for sharing the update. It's interesting that all 6 injectors were replaced. Perhaps the labor to isolate the injector in question would be more expensive than replacing all of them.
      03-07-2019, 04:50 PM   #16
Pequin
Pequin's Avatar
Drives: Shiny blue
BMW High Wycombe are my favourite dealership, shame Dick Lovett are closer to me by 110 miles.
335D EB LCI - Debadged
      03-07-2019, 05:27 PM   #17
Minty
Drives: F31 340i
Spot on, they believed it was one noisy injector but it was safer to replace all 6.
Since the software update it definitely runs ‘differently’...haven’t driven it much so will reserve my judgement.
      03-07-2019, 05:41 PM   #18
cfm56d7b
It was actually a very prudent decision. Why have one injector perform as new and leave other injectors in potentially less than optimal state?
Your dealer was 100% correct.
