03-05-2019, 06:11 PM | #1 |
Rep 1,381
Custom laser cut alcantara trims
Thought I'd share some custom alcantara work I've been doing lately on F3x and E90 trims
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
03-06-2019, 07:37 PM | #3 |
Rep 1,381
Thanks! I use an aggressive high temp contact adhesive (don't bother with sprays or carpet sprays, they web up in clumps and show behind thin material). Once it's all laid down but not fully cured I pull each section tort before hot welding the fabric to the trim on the back - alcantara contains plastic so it makes this part easier and keeps everything in place.
2015 435i - 401whp
03-06-2019, 08:09 PM | #4 | |
Rep 503
03-07-2019, 08:10 AM | #5 |
Rep 1,381
Yeah I make them, mainly based on your current trim though which I know can be tricky for people outside of the UK, however I can also buy in a spare trim for you if prefer or even send you the fabric finished; just not stuck down.
I have a complete set of instructions on how to take apart your trims, adhere the fabric and reconstruct if people decide to go down that route.
2015 435i - 401whp
03-07-2019, 07:14 PM | #7 |
Gettin It Figured Out
1820
Rep 2,669
Very nice OP!
fortythirtyfive639.50 |
03-10-2019, 08:36 PM | #8 |
Rep 188
Drives: 2013 328i xDrive
03-11-2019, 04:51 AM | #9 | |
Rep 1,381
My solution was to find a seamstress / upholstery repair shop that I could give £30 to run a couple of lines of stitching for me
2015 435i - 401whp
10-10-2022, 03:55 PM | #11 |
Rep 15
Drives: 2016 Bmw 340i
who does your laser cutting? I want to get this pattern done on my 340I for the rear parcel shelf I am doing in Alcantara
10-10-2022, 04:51 PM | #12 | |
Rep 1,381
Are you trying to do something similar to this? |
FrankDK170.00 |
10-10-2022, 05:02 PM | #13 | ||
Rep 15
11-27-2022, 08:50 PM | #15 |
Rep 1,381
