BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 10 HU discussion
proTUNING Freaks
      03-12-2020, 07:05 AM   #111
beeee83
Drives: F11 525XD
hi,
I upgraded succesfull to 1.2 (from 3.8.5), and then tried 1.3. it started once to 1.3, but rebooted and next i got in android recovery mode.
I tried, the factory reset method by use of this:
Change the software name to: Ksw-P-Userdebug_OS_v-ota-reset-data_factory.zip.
1. Change the name of the USB flash drive to: _kswota_
2. Copy the software to a USB flash drive.
3. Connect this USB flash drive to the Android unit.
4. Restart the unit, it will automatically force the upgrade.
After the forced upgrade is completed, then upgrade the OEM, copy it into the USB flash drive and upgrade.
but this is not working, it keeps getting in recovery mode, any thoughts?
I did not tried connecting a keyboard since i dont have one atm (not at home), but the factory recovery via USB drive should word, shouldt it? Its a verified snapradon unit with 4Gb ram and 64gb STORAGE.
regards
bart
      03-12-2020, 07:34 AM   #112
Kri
Austria
1084
Drives: E87
Originally Posted by beeee83 View Post
hi,
i upgraded to 1.2, and then tried 1.3. it started once to 1.3, but next i got in android recovery mode.
i tried, the factory reset method by use of this:
but this is not working, it keeps getting in recovery. any thoughts?
i did not tried connecting a keyboard since i dont have one atm (not at home)
regards
bart
Most time the issue is that the file does not have the correct name.
ensure that it is "Ksw-P-Userdebug_OS_v-ota-reset-data_factory.zip"
No additional "." a the end of the file, and also that the 2nd ".zip" is not shown at your computer so not ".zip.zip"
Also after every recovery you need to delete the additional created textfiles at the thumbdrive.
also the name of the thumbdrive itself does change after a upgrade, your need to rename it again.
Kri
      03-12-2020, 07:44 AM   #113
beeee83
Drives: F11 525XD
Kri
Kri,
I got it i think the issue is that the name should contain Q instead of P for android 10 to recover so use as file name:
Ksw-Q-Userdebug_OS_v-ota-reset-data_factory.zip and
NOT Ksw-P-Userdebug_OS_v-ota-reset-data_factory.zip
maybe add this to page one of the android 10 thread?
regards Bart
      03-12-2020, 07:53 AM   #114
Kri
Austria
1084
Drives: E87
Kri,
regards Bart
Hy
Oh yes, i oversaw this, has to be Q for sure
Kri
      03-12-2020, 08:51 AM   #115
Stainy
Drives: 435d Xdrive
Originally Posted by Mirjam View Post
You are referring to a different audio bug than in question here, which came with 3.8.3, where the volume level isn't correctly reflected by the volume slider. This is probably fixed in later versions. The low volume bug has been present always, where the volume is low after boot, until the music app, Bluetooth app or possibly other built in app, is launched. This bug we set up Tasker to handle.
No I'm not. I didn't have the low volume bug where you have to run music app etc until after 3.8.3. Nevermind, I'll go to 10 and if necessary continue to use Tasker
/Edit actually I upgraded the MCU to 27/11 at the same time as 3.8.3 - The sound bug was probably imported then as I still have it with Android 10 1.3.0
      03-12-2020, 09:04 AM   #116
beeee83
Drives: F11 525XD
Hy
Kri
Yup it was, up and running on version 1.3
      03-12-2020, 10:47 AM   #117
daschacka
Drives: M5Competition
Im experiencing the same. Im still on an old MCU from July 2018 and didnt notice any low sound bug on 9.0 and 10.0
      03-12-2020, 12:21 PM   #118
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Drives: Alpina D5
found new bug:
Display brightness started always with 50% or less although level is on 100%.
Touching the brightness slider forth and back to 100% then it's bright.
Anybody an idea how to solve?
For the sound bug (not the new bass bug):
Middle speaker isn't working
I forgot the workaround from Android 9 and can't find it anymore in the thread.
      03-12-2020, 12:49 PM   #119
elnino72
Drives: Bmw E92 320I
Hi group, one question, since the problem of low volume at startup and other problems has not been resolved why update to Android 10? We need a reliable and fast system. What do you recommend?
      03-12-2020, 01:41 PM   #120
Levi
Drives: 2016 BMW 328i
Ddvr-cam2 hd dvr
Just installed Android 10 on Avin SD625 64gb/4gb. DDVR-CAM2 HD DVR camera app now crashes on launch and will not communicate with USB, this is front and rear DVR camera app. Anyone else have these cameras and this issue? Application is DUAL DVR-com.ankai.cardvr-3.0.20-20.apk
found here:
https://drive.google.com/file/d/1iwH...ew?usp=sharing
      03-12-2020, 02:44 PM   #121
akirax
Drives: BMW F30
Originally Posted by Alpina_Guy View Post
found new bug:
I always had the brightness bug, in Android 9 also. Tasker and cflumens is the fix.
For the sound bug... Are you saying that now bass bug is fixed but the center speaker don't work?
Cheers.
      03-12-2020, 03:19 PM   #122
Stainy
Drives: 435d Xdrive
The system is just as fast and is no less complete than the final 9 - I upgraded as all updates will now be on 10 and I had a free afternoon
      03-12-2020, 03:24 PM   #123
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Drives: Alpina D5
Originally Posted by vigorio View Post
3. I´ve read that someone has a hissing sounds in background like me. Is that normal? It sounds like a working digital mechanism in the background and reminds me of an old gsm phone near a loudspeaker.
Me too, depends on the gsm network power
      03-12-2020, 03:24 PM   #124
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Drives: Alpina D5
Cheers.
Yes
I‘ll try to describe it better. It sounds like Dolby digital 5.0 without center speaker working.
      03-12-2020, 03:46 PM   #125
Svenson
Svenson's Avatar
Drives: F11 530d
Signal comes from AUX with stereo sound.Android has nothing to do with center speaker.
      03-12-2020, 06:08 PM   #126
shakir
Drives: bmw e60 530i
Originally Posted by whitewidow View Post
Hey guys and gals. I know this forum post is mostly for the f30 and 10.25" Android HU. But i have a 2010 e90 with the 8.8in CIC Logic 7 stock system. No ComBox. I am looking into getting this Android Snapdragon unit.
Andream 8.8" Android 9.0 8core 4G 64G Car Multimedia Player
https://www.aliexpress.com/item/3284...65ae4c4dSaJnBA
Are these smaller units compatible with the android updates being posted here? If so I assume root is possible on this unit. Can someone post a link to the rooting instructions? Would the system wide idrive controller work on this unit as well? Is there a way to map the voice control steering wheel button to Google Assistant?
Also do these unit not need the aux cable routed to the center console? In this post he is stating he does not use the AUX cable.
https://www.e90post.com/forums/showp...&postcount=497
Hi. I have one in my E60 - you need to add AUX to your VO via coding if you dont have it as a menu choice in your oem system.
Then when you wire the new head unit up, you need to unclip the fiber optic green plug and transfer it over onto the new adaptor plug or no audio
I think the software updates on here are for all units - the file names suggest they are the same.
      03-13-2020, 03:28 AM   #127
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Drives: Alpina D5
Harman Kardon will use all speakers, incl. center
      03-13-2020, 03:30 AM   #128
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Drives: Alpina D5
Is it possible to downgrade MCU without problems?Anyone tried?
      03-13-2020, 05:06 AM   #129
Svenson
Svenson's Avatar
Drives: F11 530d
You write "Middle speaker isn't working".
I mean this can't be a android problem. Android (AUX) is playing stereo, not more.
By the way i have Hifi-System and my middle speaker work correct.
      03-13-2020, 05:08 AM   #130
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Drives: Alpina D5
again:
      03-13-2020, 05:18 AM   #131
Svenson
Svenson's Avatar
Drives: F11 530d
again:
It is not an Android bug.
      03-13-2020, 05:26 AM   #132
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Drives: Alpina D5
again:
IT IS!
Using bluetooth audio, no problem, and it wasn't before by using Android 9 and version 3.5
