10-18-2021, 01:07 PM | #1 |
Rep 80
Inlets and Outlets
Currently getting a MST inlet. Also are outlets a necessary because I see no forums of the oem breaking on people.
2014 m sport 435i rwd fbo upgraded turbo VRSF Chargepipe, vrsf race fmic, and hi flow downpipe BMS aluminum elite intake Stage 2H 93 bootmod3 ngk Cold spark plugs 0.020 PR Ignition Kit Vargas stage 1 upgraded turbo 93500 miles xHP stage 3 transmission tune Last edited by Bmweth24; 10-18-2021 at 01:22 PM.. |
10-18-2021, 01:13 PM | #2 |
Rep 7,602
MST and CTS have the best design. If you read the main thread on inlets, you will see that several were tested and those came out on top. https://f30.bimmerpost.com/forums/sh...1656337&page=8
Other ones are OK, and will be better than stock, but i would just wait for the "best" ones. Check various vendors to see if you can find one who has them. The TIC does not fail like CP, but some people say the TIC swells/balloons when you get into higher boost levels. I can see why, it is quite thin and malleable. I didn't really notice a difference with the TIC change, more something i would just do while you are in there or if you have an issue. |
10-18-2021, 01:20 PM | #3 | |
Rep 80
10-18-2021, 01:37 PM | #4 |
Rep 7,602
10-18-2021, 04:08 PM | #5 |
Rep 80
10-18-2021, 04:18 PM | #8 |
Rep 80
https://www.racdyn-usa.com/PROD/139+...8aAn2hEALw_wcB
Is this a good one? The only one I could find. |
10-18-2021, 04:24 PM | #9 | |
Rep 7,602
10-18-2021, 04:52 PM | #10 |
Rep 4,134
It looks like an FTP. Do you think there is any value to wrap the TIC in reflective tape? And is it really a larger diameter compared to stock?
Mods: Yes.
10-18-2021, 05:22 PM | #11 | |
Rep 5,393
AmuroRay2267.50 |
10-18-2021, 05:55 PM | #12 | |
Rep 7,602
Also stock TIC isnt plastic, its rubber like a radiator hose but very thin (with metal ends). |
10-18-2021, 10:53 PM | #13 | ||
Rep 5,393
10-18-2021, 11:16 PM | #14 | |
Rep 7,602
johnung4528.00 |
10-19-2021, 05:34 AM | #15 | ||
Rep 5,393
I did my DP in black a few years ago to fly under the radar. Looks more like a shadow underneath and doesn't stand out. But they have a lot more ceramic coating colors now. I snapped a photo that I will attach. I'll post a link in case someone reading this is interested. They do great work and people ship them parts to coat all the time. They are in PA. https://boneheadperformance.com/ |
terryd5150507.00 |
10-19-2021, 05:41 AM | #16 | ||
Rep 5,393
(Note: His opinion was that a turbo blanket wouldn't do much if anything on a street engine but that they had benefits on the track on very high horsepower race engines) |
10-19-2021, 12:57 PM | #17 | |
Rep 7,602
The keeping in the heat pre-turbo increases the amount of energy that goes through the turbo, so more energy is spent spooling than "wasted" as heat. This is why heat wrapping a manifold for example can actually be a big benefit. Its the same reason why a lot of OEMs tuck the turbos into the V of engines now (audi i know for sure does, i think Merc does as well) - very short exhaust runner length from cylinder head to turbo and minimizes heat loss. Wrapping post-turbo is more just for underhood heat control and doesnt actually affect the turbo itself. The ceramic coating is nice and i might have done that had i planned ahead more before i installed my DP lol |
10-19-2021, 01:45 PM | #18 | ||
Rep 5,393
