03-24-2019, 12:35 AM | #1 |
Rep 27
420D Ran out of fuel when the guage shoes half a tank
I drive a late 2017 420D - Last Sunday, at 11:30pm driving home from a concert, I ran out of diesel, with the needle showing just over half a tank, and the trip showing a range of 250 miles. Roadside assistance brought me 10 litres of fuel and I headed home. Booked the car into BMW the next day, and dropped it off on Tuesday. They had the car for three days, and had replaced the fuel sensor and head unit (software crash they couldn't recover apparently). When I picked it up, it showed just over 1/3 tank, and a range of 168miles. My assumption they've fixed it and put some fuel into test it (remember I'd only added 10litres from dry). Drove home, picked the kids up and all seemed well, the range dropped around 12 miles so must be working. Yesterday we were going on a family trip, loaded the car up - kids, coats, picnic - and set off. With the range showing 154 miles, I ran out of fuel AGAIN! Car is back with BMW and the technician advised this time he'll replace the whole tank - something to do with sensors they can't reach and possible function issues (lost me to be honest). But I can't understand how BMW doesn't have any way to check physical fuel level, to confirm it fits with the reading! Couldn't find anybody else that has had this issue, hence thought I d post this. Picture shows the fuel readings when the tank was actually empty.[IMG][/IMG]
03-24-2019, 12:09 PM | #4 |
Rep 129
I must admit I am one of the few who brims and resets the trip every single tank (I upload to Fuelly) I tend to go on mileage more than the gauge, and I always like to have roundtrip fuelling, so if I plan a long trip I fuel in advance, (just a personal quirk) to ensure I don't waste time on the run,,,,
I am keen to know just what emerges on this however it is very strange indeed |
tex26702412.50 |
03-24-2019, 01:28 PM | #5 |
Rep 10,256
This is the first time I heard about this problem, whether the engine is diesel or gasoline.
VERY unusual. I am surprised the dealer cannot determine the root cause. |
03-24-2019, 01:59 PM | #6 |
Rep 552
03-24-2019, 05:44 PM | #8 |
Rep 27
In hindsight I did rest the trip, but first time round I doubted myself - as it's a sub conscious action. I work from home a lot and fill up every 2/3 weeks so couldn't recall when I'd last put fuel in. I actually started questioning the fuel level about 50 miles before it ran out the first time, but the guage and range decreased, so I just assumed I'd not reset the trip! Second time I assumed that BMW had put fuel in, so went of the range. I usually fill up when it pings at 45miles to go.
03-25-2019, 11:44 AM | #9 |
Rep 4,210
03-25-2019, 02:40 PM | #11 |
Rep 776
03-25-2019, 02:44 PM | #12 | |
David
786
Rep 2,010
By all means if you like filling up at the last possible moment go for it.
03-25-2019, 04:25 PM | #15 |
David
786
Rep 2,010
Who's talking about the engine running, my point is running dry is not good. idc what you say or what your experience is, this is a known fact. Diesel lubricates the pump and air will get sucked in if you run it dry, same with gas engines.
Plan and simple. Some people just like to argue on here rather than admit they're wrong, jesus |
03-25-2019, 04:47 PM | #16 |
Rep 2,499
Unfortunately this repair process is pretty standard. There are two fuel level sensors but for obvious reasons they only more easily replaced sensor first. Then if that doesn't fix your issue, they'll replace the fuel tank to fix that. That's how most repairs are done when the source of the issue could equally be multiple parts. Repair the cheapest and quickest part first, then go on to the next.
Also, if you continue to have these issues, I'd highly recommend filling up your car to full before something important like a family picnic. You don't want to be stranded on your day off with your children possibly on the side of the highway. Save the testing for another time like driving to the gym or work. Also, filling up full tanks allow you to estimate your range. Before car computers gave you your range, some people would reset the trip odometer at every fill up and get used to how much mileage they were getting. |
03-25-2019, 05:42 PM | #17 |
Rep 776
It stopped immediately when there was no fuel. Fuel system overhaul is for a diesel/ gasoline mix. No reports of cranking to oblivion that I've seen, though possible.
03-25-2019, 05:45 PM | #18 |
David
786
Rep 2,010
No it's not, it's when you put in gasoline and that doesn't provide adequate lubrication for the HPFP, which causes it to destroy itself and send metal shavings throughout the entire fuel system. The same thing happens when you're out of fuel, it sucks in air and parts don't get lubricated.
03-25-2019, 05:52 PM | #19 | |
Rep 776
Gasoline is a lubricant? Whatever |
03-25-2019, 05:54 PM | #20 |
Rep 776
03-25-2019, 05:56 PM | #21 |
David
786
Rep 2,010
