03-02-2017, 11:19 PM | #309 |
Rep 38
Haha finally I can reach the rear seats latch with 1 metal stick (about 1 meter long). Trunk opened and will retrofit a way to fold down the seat from inside cabin.
03-02-2017, 11:28 PM | #310 | |
Rep 278
How did we get sidetracked??
2017 430ix Gran Coupe
03-06-2017, 10:58 AM | #312 | |
Rep 39
03-08-2017, 02:06 AM | #313 | |
Rep 180
Sorry to hear you have had the same problem that I had.Hope it comes right for you. |
03-08-2017, 12:36 PM | #314 | |
Rep 180
03-08-2017, 12:59 PM | #315 | |
Rep 278
It could be that in your situation, the obstruction is only slight enough that sometimes it works, other times it doesn't work. I would advise you to crawl inside your trunk from the back seat with a worklight and look carefully to see if that is the case with your car. Just don't stick your fingers in a place where they might get pinched when the trunk is closing!
03-09-2017, 01:22 AM | #316 | |
Rep 180
Thank you very much , will do as suggested. |
Maciej@BimmerTech29.00 |
03-09-2017, 06:43 AM | #317 | |
Rep 180
Update 2: So after a weeks of using the car the second lock unit has also failed.This time round i had a real problem as the emergency release also failed to unlatch the lock and i had one heck of a time to finally get the lock Unlatched.Looks like there is something that is not right with my kit that is causing the lock to fail. I have juts decided to remove the whole kit and put the car back to stock. |
03-09-2017, 11:24 AM | #318 |
Rep 59
speed608 - that is unfortunate news. I contacted you via the support line to get this resolved - I'm very sorry this happened.
We care about the quality of our products and more importantly about the experience our customers have installing and using our kits. Among all of the F30 Power Trunk kits we have sold so far (and there was quite a few delivered to customers) there have been a 3 or 4 instances where the locks have failed. It's paramount for us to first replace these locks and secondly to get the faulty units back to our offices for an investigation. We'll do our best to apply improvements as necessary in order to prevent this from happening altogether. |
03-09-2017, 11:54 AM | #319 | |
Rep 180
Thanks Maciej, Yes it is very unfortunate as I really liked this auto boot open/close feature and it's disappointing that my kit has had some sort of a fault. I have replied to your mail as per instructed and I hope you get to the bottom of these failures . Thanks |
03-11-2017, 01:41 AM | #320 |
Rep 407
Hi Maciej,
I just emailed you. My lock seems to have failed this morning. The boot will not unlatch. Worst part is I don't know how I will get to it, my car does not have the emergency cable release.
03-11-2017, 04:05 AM | #321 |
Rep 161
I also don't have emergency release, hope my lock will work for ever Knock knock on wood
2009-2011 E90 320si street/track car - SOLD ; 2010-2016 E92 330d LCI street car - SOLD ; 2016-2018 F30 335d LCI street car - SOLD
2011-2021 E46 M3 track car - SOLD 2018-???? F87 M2 Competition street/track day car My Instagram |
03-11-2017, 06:49 PM | #323 |
Rep 23
Seems that cars sold in Australia don't have the emergency release installed. As soon as someone reported a lock failure, I realised that I needed to install one just in case my lock failed so I ordered one and fitted it. From looking at the online parts catalogue, there were two options so I went ahead and ordered the cheaper of the two which was a single part number. The one I obtained was a simple cord with a loop at the end while the flash one was a cable, separate handle, etc., with various part numbers.
Previous: E30, E34, E39, E46, E91, & F30 320d
Current: F30 330i |
03-12-2017, 01:47 AM | #325 |
Rep 23
Sorry I don't but the install just involves removing the new lock and connecting the release cord as per the video and feeding the cord through the slot in the boot lining assuming you go for the cheaper option with the single part number.
Current: F30 330i |
03-12-2017, 01:49 AM | #326 |
Rep 180
03-12-2017, 05:20 AM | #327 |
Rep 55
Salut,
Lorsque j'avais comandé le kit retrofit , j'avais anticipé les risques de panne en achetant la tirette de secours , vu les problemes rencontrés , ca confirme que j'ai bien fait d'acheter le cable tirette je vous joint la liste des ref qu'il faut commander ! Hi, When I ordered the kit retrofit, I had anticipated the risk of breakdown by buying the emergency zipper, given the problems encountered, it confirms that I did well to buy the cable emergency zipper I enclose the list of ref which you must order! Ref : 51 24 7 238 463 51 24 7 057 739 51 24 7 056 413 51 24 7 056 414 51 24 7 224 054 |
ronanz1822.50 |
03-12-2017, 06:03 AM | #329 |
Rep 180
03-12-2017, 07:33 AM | #330 | |
Rep 55
Yes the cap referred to is the one corresponding to the F01, see picture, that of the series 3 does not go on the lock of the retrofit. The lock of the bimmertech retrofit is that of the F01 série 7 Last edited by TheFrench; 03-12-2017 at 07:58 AM.. |
