08-22-2021, 08:13 PM | #1 |
Rep 383
GTS Tail lights questions
Hi All!
So im thinking of the getting the V2 GTS tail lights and im not sure where I should get them from, From what I read they are all roughly from the same manufacturer but some are separate platforms. If anyone knows or has done this upgrade let me know how it went and where you got them from. Currently, I'm looking at the V2's from bayoptiks. https://bayoptiks.com/collections/ta...33400987746390 Let me know in the comments your suggestions! |
08-23-2021, 10:42 PM | #2 |
Rep 1,173
I think you msg'd me lol but if it gives you peace of mind to buy from a company like bayoptiks or kies and are ok with spending near 1.5x or twice the price, then I'd say it's worth the price. Peace of mind can be a big thing to some ppl.
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
08-25-2021, 03:28 AM | #3 |
Rep 208
As said above your looking to pay nearly double buying from them, and you'd get the exact same product you'd buy from China no different, so me personally and what I done is bought from Ali express, usually takes around 2 weeks to come and half the price
08-25-2021, 08:23 AM | #4 |
Rep 163
I bought mine from VLAND on Amazon: https://www.amazon.com/dp/B08RHVDMRM...Q3QJ0ZMT?psc=1
The fit was near perfect with slight adjustments and you honestly can't tell they're aftermarket. They look to be the same exact thing that kies/bay/etc just repackage. Plus you get the protection of Amazon if they just don't work out for you. |
08-25-2021, 07:38 PM | #5 |
Rep 383
ye im looking at some of the cheaper options and I cant lie I really can't tell the difference
08-25-2021, 07:42 PM | #6 | |
Rep 383
08-26-2021, 08:15 AM | #7 |
Rep 49
Theyre all from Vland regardless where you buy them (or atleast i think Vland is the people that developed the lights. Regardless where they come from, they come from the exact same place no matter who you buy them from.), KIES, Bayoptics ETC just charges a premium for "inspecting" the lights and make sure theyre not damaged before you buy them. Theres even a re-seller here in Norway that charges a 2x price premium...
I bought my V1`s here (bought V1`s because i liked its start up sequence more than V2`s. And since i knew they had a rear fog light which is mandatory in Norway, i didnt know the V2`s also had rear fog lights when i purchased the V1`s because Vland and all the re-sellers are utterly terrible at describing their products.) https://www.amazon.com/dp/B08RNFBRVP...t_details&th=1 Had them for 2-3 weeks now and im happy with them, no gaps at all, installs just like factory lights and looks "factory" when it comes to the fit and finish. Only complaint i got is the blinkers, theyre extremely dim and unnoticeable in direct sunlight on both V1 and V2. Not sure how Vland managed to get the lights SAE/DOT/ECE certified with blinkers that dim (in anything but direct sunlight theyre perfectly visible tho). Last edited by MagnusAG99; 08-26-2021 at 08:43 AM.. |
08-26-2021, 03:28 PM | #8 | |
Rep 383
08-26-2021, 03:33 PM | #9 | ||
Rep 383
01-28-2022, 08:52 AM | #10 | |
Rep 66
Hey boss! Did you get the smoked one or the red? |
01-28-2022, 01:02 PM | #11 |
Rep 49
01-29-2022, 05:04 AM | #12 | |
Luxury at the redline :)
9105
Rep 7,563
I know for a fact that they do not meet US DOT photometric size requirements and the turn signals are going to remain dim because the proper defusing outer (red) plastic and LEDs are not properly used, which in my opinion, is a notable safety hazard but to each is own.. |
01-30-2022, 07:18 AM | #13 | |
Rep 49
01-30-2022, 08:14 AM | #14 | ||
9105
Rep 7,563
If someone rear-ends you today because you have some insufficient taillights on your vehicle, "VLAND" couldn't give two shits about your problem because they don't have to and I'm guessing all their third-party seller will do is offer you a refund or replacement of the same light. With taillights, the red plastic acts as a diffuser of light, it requires the correct quality and precision of the LEDs for them be noticeable in the daylight. BMW combines the a red diffuser ( outer plastic) with a green optical filter behind the LEDs to create a amber color output turn signal, which is visible in the daytime. Red + green = amber. "VLAND" just throws in whatever is cheaper, looks cool and is required move units, to hell with if it's visible or not because they are not required to meet any sort of compliant standards or becomes legally liable if it isn't. OEM manufactures have a higher power to answer to; the local government that has the ability to block sales of their new vehicle, if the lighting output is not sufficient, so they verify that their lighting are fully compliant. The local government doesn't certify OEM or aftermarket lighting, they leave that up to the manufacturers to self-certify, with the notion that they are fully aware of the requirements and that their equipment are up to standards and the risk of not complying. VLAND can put any insignia on their lights, real or genuine and it wouldn't matter one bit because they are not held to the same criteria as the OEM manufacturers are. The quality assurance or standard are really only up to the discretion of the reseller, not any local ordinances. They have very little to lose other than maybe future sales of their product. https://www.boogeylights.com/theres-...-dot-approved/ |
02-23-2022, 05:00 AM | #15 |
Rep 9
VLAND indicator issue
Does anyone know why my indicator and hazard lights work perfectly when my engine is not running but the moment i turn the engine on the rear left incator blinks really fast and throws an error code on the dash?
02-23-2022, 10:56 AM | #16 | |
Rep 1,686
Drives: 2014 428i and 2018 X5
The coding of disabling the warm/cold checks for newly installed LEDs has been discussed many times on these forums already
ethandolan0.00 |
02-24-2022, 03:37 AM | #17 | |
Rep 9
Thanks Ethan |
