Login
11-03-2017, 04:13 PM | #1 |
![]() 16
Rep 152
DRL always on
Is this possible to code on an f30 2016? I have bimmercode but probably an esys job. Thanks.
I want drls always on regardless of light setting that's chosen i.e. dipped. |
12-02-2017, 01:29 PM | #2 |
![]() ![]() ![]() ![]() ![]() 78
Rep 760
12-02-2017, 02:49 PM | #4 |
![]() ![]() 17
Rep 63
You can change the brightness but for that specific option for all light switches, I used Carly.
My DRLS (Angel eyes) stay on at 100% on any switch except for low beams. They then drop to about 20-30%. Still working on that one. |
12-04-2017, 06:49 AM | #5 |
![]() ![]() 60
Rep 166
This can be coded using esys. I don’t know how by heart, but it’s in the cheatsheet.
Edit: I believe it’s this: Change Angel Eye Brightness when headlamps on (Left): FEM_BODY 3062 MAPPING_STANDL_V_L_PWM_LEVEL_1 Default: 8 Change to: 32 Change Angel Eye Brightness when headlamps on (Right) FEM_BODY 3062 MAPPING_STANDL_V_R_PWM_LEVEL_1 Default: 8 Change to: 32 Last edited by KingpinRCR; 12-04-2017 at 06:54 AM.. |
12-04-2017, 07:08 AM | #6 |
![]() 16
Rep 152
Still looking to do this on a halogen with the white drl bar. I've read it's in the fle module. I've tried the above but it doesn't work unfortunately on this type.
12-04-2017, 08:36 AM | #7 |
![]() ![]() ![]() 2006
Rep 7,866
12-04-2017, 08:39 AM | #8 |
![]() 16
Rep 152
12-04-2017, 08:40 AM | #9 |
Rep 7,866
12-04-2017, 08:50 AM | #10 | |
![]() 16
Rep 152
![]() Also, mine is an LED LCI. I have an LED white bar on the light so still will be worth checking fle. Last edited by steve498; 12-04-2017 at 08:59 AM.. |
12-05-2017, 07:48 AM | #11 | ||
![]() ![]() 17
Rep 63
I'm still working on mine. |
12-05-2017, 07:59 AM | #12 | |
![]() 16
Rep 152
I'm going to try something soon with esys and hopefully it'll work. Tried so much fem coding but no luck. ![]() |
12-06-2017, 06:14 AM | #13 |
![]() 16
Rep 152
So I used esys today and unfortunately the FLE module isn't available under the SVT. Is there something I'm missing or does my car only use the FEM_BODY module? I also looked in there but can only find MAPPING_STANDL_V_L_STANDARD and not pwm_level_1. This sucks. Any ideas? :/
Edit: I don't think this is possible unfortunately. It's a wiring job. Last edited by steve498; 12-06-2017 at 07:00 AM.. |
12-06-2017, 08:43 AM | #14 | |
Rep 7,866
The coding, to which you refer, requires Xenons or LED's. |
04-07-2018, 11:33 AM | #15 | |
![]() 0
Rep 27
04-07-2018, 12:32 PM | #16 | |
![]() 16
Rep 152
04-07-2018, 12:41 PM | #17 | |
![]() 0
Rep 27
04-07-2018, 12:59 PM | #18 | |
![]() 16
Rep 152
04-07-2018, 01:04 PM | #19 | |
![]() 0
Rep 27
04-16-2018, 02:51 PM | #20 | |
![]() 0
Rep 27
11-17-2018, 06:18 PM | #21 | |
Rep 12
