05-25-2021, 12:31 PM | #199 | |
Rep 15
Very good that you asked because this is one of the most important step when you later reassemble the suspension. This bolt must be torqued in one of the last step with the wheels on the ground. You want this “rubber torsion bar” to be torqued in the ride height. It is also important when you lower the car to have this torqued at the new height. Note that this is only necessary for non M cars. M2-M4 have a uniball in that position. For M-cars you don’t need to loosen the bolt. And if you do you can torque it with the car raised. |
05-25-2021, 03:17 PM | #200 | |
Rep 1,369
Samuel, how do you torque the control arm bolt with the car on the ground? The wheel would be in the way and there is no space to crawl under the car if it's on the ground.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
05-25-2021, 03:49 PM | #201 | |
Rep 15
To make this at home you can jack up the hub without wheels to an estimated position and torque the nut. Since you probably do it on one side at a time the swaybar link needs to be unconnected. This way is equally good. My point is that we need to “reset” the torsion in the bushings. This also applies to the rear axle points with rubber bushings. |
05-25-2021, 08:04 PM | #202 | |
Rep 1,369
05-25-2021, 08:24 PM | #203 | ||
Rep 891
05-31-2021, 10:54 AM | #204 |
Rep 1,369
Do I need to remove the belly pan to get access to the control arm bolt? Or can I loosen the screws of the belly pan closest the control arm?
05-31-2021, 01:50 PM | #205 | |
Rep 785
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
05-31-2021, 02:58 PM | #206 | |
Rep 891
06-12-2021, 02:43 PM | #207 | |
Rep 1,369
06-14-2021, 08:29 AM | #208 |
Rep 271
Uninstalled mine to sell the car and the helicoil type thread adapter pulled out. Not sure how to fix this, no way is that coil going back in. might have some expensive paperweights now.
06-16-2021, 08:35 PM | #209 | |
Rep 3,947
https://www.realoem.com/bmw/enUS/sho...diagId=31_0950 |
06-21-2021, 10:35 AM | #210 | ||
Rep 3,947
Millway sells replacements. |
kern4174446.50 |
06-22-2021, 09:02 AM | #211 | ||
Rep 891
Millway Camber Plates
Ordering the Street bearing replacement kit for install next month and will report back then.
06-22-2021, 11:28 AM | #212 | |
Rep 3,539
MacklinUSOB518.00 |
06-22-2021, 01:49 PM | #213 | |
Rep 891
I shot out a message to Samuel after I placed my order asking about expected lead time and he said he hopes to have an estimate by this weekend. If that lead time is super long I will shoot you a PM and we can go from there. In any event, thank you. I am stuck running these ones on July 3rd at Lime Rock either way so hopefully I won't have any issues.
Polo088161610.00 |
06-22-2021, 05:21 PM | #214 | |
Rep 3,947
06-22-2021, 07:24 PM | #215 | ||
Rep 891
How long ago did you order your plates?
06-23-2021, 05:33 AM | #216 |
Rep 3,947
06-23-2021, 10:49 AM | #217 |
Rep 1,934
Have anyone of you guys put in your orders for the new ohlins xdrive kit?
06-24-2021, 02:46 PM | #218 | |||
Rep 67
MacklinUSOB518.00 |
06-24-2021, 06:23 PM | #219 |
Rep 3,947
MacklinUSOB518.00 |
06-29-2021, 09:24 AM | #220 | |
Rep 891
Can't wait to get these on. FaRKle! Thanks again for extending a hand!
kern4174446.50 |
