BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > XDelete- the answer to XDrive?
      12-17-2019, 10:30 AM   #353
opinion914
Drives: F31 N47
In the "live data" section of Xdelete is a Position Actuator readout. Any idea if this can be used to determin clutch wear and what a good value would be if so?
K
      12-26-2019, 08:24 PM   #354
antzcrashing
antzcrashing's Avatar
Drives: 2018 BMW 440i GC
Sorry to not read all the recent pages, but can someone answer a simple question for me: has anyone figured out how to reprogram theses cars (f30 specifically) to run RWD same as xdelete does? Seems to me if xdelete can do it, a simple register change (or a few should too). I have used INPA on E90, so it wouldn't be with zero practice
      01-13-2020, 12:30 PM   #355
SamSungF30
Drives: 328D
Curious to know also! anyone?
      01-13-2020, 12:56 PM   #356
fantanas
Drives: F33 435d
You can do it from esys.
"You can just change with ESYS module DSC > 3000 > C_Funktion_LaengsMomentVerteilung_aktiv_e > aktiv to nicht_aktiv
After you code this you will have RWD car WITH traction control, which can be turned off"
The traction light will stay on, but you will have a RWD car.
      01-15-2020, 07:52 PM   #357
antzcrashing
This appears to be exactly what I am looking for. Is it also fully reversible ie setting back to active brings back AWD and the traction light goes off?
Can someone confirm that they've used the RWD ESYS coding with success?
      01-16-2020, 02:57 AM   #358
fantanas
Drives: F33 435d
Yes when you change it back it goes back to like it used to be. No light and awd working. You can also have a similar result my removing a fuse (different number depending on the car). But with the fuse you lose dsc, dtc and abs, so not the best experience
I had two backups one rwd and one awd so i can quickly switch.
But I think that XDelete is doing more than that. It is loading a different program to the transfer case. Also you retain full functionality of safety systems. It is more refined.
If you just want to play a bit once in a while in a safe environment I would do the esys method. But I am running the rwd mode constantly and the car is my daily, so I went for XDelete at the end.
      01-16-2020, 04:17 AM   #359
Skyhigh
Skyhigh's Avatar
442
Drives: BMW F36
What continues to worry me is the part with the different software XDelete puts in the transfer case controller. I had intended to but haven't yet contacted them to ask for explanation about what goes on it. Chances are that the XDrive you drive after applying XDelete is not the same as prior to applying XDelete.
In this respect, coding is "safer". If it really works like that (have never tried it, but would).
      01-16-2020, 08:13 PM   #360
antzcrashing
Ok so if I am understanding correctly when you turn off this flag and go into RWD via the code, the traction is really off, not that the traction warning is simply there to warn the driver that something driving is not right ie AWD deactivated - if so that's a negative for me - less sure footed in the rain
Also, are you happy with xdelete, worth it?
      01-16-2020, 08:15 PM   #361
antzcrashing
Ok that's interesting, if there are parameter changes due to xdelete that change the way the car drives even after switching to AWD that is a negative for me. Can anyone confirm, what do the developers of xdelete say about this?
      01-17-2020, 04:58 PM   #362
fantanas
Drives: F33 435d
Yeah all nannies are off. That is why I went for xDelete.
I am very happy with it. I have an issue once when I changed back to awd. I was dragging the wheels. I contacted them and they weren't sure what is wrong. I fixed it with recalibration the transfer box. After telling them they added it to the software so it is rock solid now. During the winter I have awd all the time but from March I will go back to rwd full time. More fun to drive and better mpg.
      01-20-2020, 08:16 PM   #363
warcraftjs
Drives: 2014 435i
So has anyone tried xDelete with a DINAN box on their car? I have the stage 2 and just donít want any problems. Itís still winter by me so Iím not in to much of a hurry to turn off awd.
      01-21-2020, 01:10 AM   #364
fantanas
Drives: F33 435d
Originally Posted by warcraftjs View Post
So has anyone tried xDelete with a DINAN box on their car? I have the stage 2 and just don’t want any problems. It’s still winter by me so I’m not in to much of a hurry to turn off awd.
I don't see why you would have a problem. They are different ECUs so one doesn't have anything to do with the other.
      01-21-2020, 09:50 AM   #365
SteelBlue46
Drives: Alpine White '13 335i XDrive
I was running XDelete with a BM3 stage 2 tune and had no issues with either. Have been set to AWD for awhile though due to winter.
      01-23-2020, 10:09 AM   #366
warcraftjs
Drives: 2014 435i
Thatís good to hear. I just didnít want to have to disconnect the DINAN box just to change things.
      01-24-2020, 09:53 AM   #367
M Smurf
M Smurf's Avatar
36
Drives: 2013 328i M Sport
Y'all should have just picked up a proper BMW with RWD! Problem solved.
      01-24-2020, 10:29 AM   #368
deviantspeed
moew
183
Drives: 2017 F31 330 and a WP0AA
Great! Where can I find a RWD F31 in the states that is legally imported and titled?
BTW the reflash can be detected if it comes to some heavy lifting and connecting to the mothership.
      01-24-2020, 11:15 AM   #369
Onizukachan
Great Teacher
Onizukachan's Avatar
Drives: E46/3 M56 & F31d
Can you provide me an f31d RWD in the US of A?
Preferably manual, since you are pulling things out of your ass.
      01-25-2020, 06:39 PM   #370
warcraftjs
Drives: 2014 435i
I would have had the M4 they had. But I got the bad burning eyes from the wife. So I got the 435i x-drive.
The M4 will be coming soon. But in the mean time, I can have the best of both worlds.
rcaso26151.50
      01-26-2020, 07:38 PM   #371
mckk
Drives: F32 430ix
Have an important question - I have read that xDrive is really sensitive to a different tread height of the tires, so if I have xDelete activated it is super easy to wear off rear tires quicker than the front - in such cases, I can kill my transmission
I don't know how it is solved in the new M5 F90 which has xDrive with an option to have fully RWD vehicle, but then you can wear off rear tires quickly as hell, which might end up in destroying transfer case because of different sizes in diameter of the front and rear tires
      01-27-2020, 01:44 PM   #372
SĶpreme
SĶpreme's Avatar
Drives: 2016 340i xDrive M-Sport
Just read this whole thread from beginning to end and wow, this has been a roller coaster of a conversation lol
I think I might try it this summer, idk yet. Depends on how much power I'm making once my in-progress mods are completed & how much I want to risk killing myself in RWD mode...
2016 340i xDrive M-Sport MPPSK
VRSF DP; AP intake; HDP6 hpfp
MHD; Wedge Performance E50 tune; xHP Stage 3
AG wheels & KW coilovers
      01-27-2020, 02:21 PM   #373
fantanas
Drives: F33 435d
I had been thinking about that as well, but in my mind the difference should be small and the transfer case and xdrive system should compensate. The car is 60/40 in normal x drive mode, so the rears could wear faster.
I would love to hear from somebody that knows more thoufh
      01-27-2020, 02:28 PM   #374
AlpineX
Drives: Diesel
Don't overthink it. Rotate your tires. If you're staggered, then you already subscribe to higher cost and shorter life tires.
