BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Bm3 for B48 F30 Datalogs
      10-25-2019, 01:40 PM   #23
chenzhuops2
China
Originally Posted by hybris View Post
Originally Posted by chenzhuops2 View Post
http://www.bootmod3.net/log?id=5d92b356ae729b2cae3138bf
the stock 98gasoil
The ignition has improved a lot?
Yes. But also lower power, so.. You won't get that high timing on a tune. Depends on ambient temps too.
For comparison here's a couple of mine (also B48) on 91 stage 2 beta tune, running 98 octane fuel.
June (high ambient temperature):
http://www.bootmod3.net/log?id=5d0df5c0c090c611aedbcfde
Recent (only +5c):
http://www.bootmod3.net/log?id=5d9b2951c090c61ab1d89b59
B48 engine should be 530 oil or 540 oil?
      10-26-2019, 01:41 AM   #24
hybris
hybris's Avatar
Norway
205
Drives: BMW 330e F30 M-sport
I let BMW handle that, and I would refer to your service manual, but I'm pretty sure its 5W-30.
Thorbjorn
16 BMW F30 330e M-sport
Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs
      10-26-2019, 11:14 AM   #25
chenzhuops2
China
I am using motul xmax 040 full synthetic oil. Do you have a good choose? BMW original is castrol oil?
      10-31-2019, 07:35 PM   #26
haibebei
Drives: f30 320im M sport
why your 98 RON gas quality is so bad?
I'm also in China, here is my log which is logged in the summer (about 30 C degrees above)
http://www.bootmod3.net/log?id=5d4f9c25ae729b5066de3c89
      11-03-2019, 12:45 PM   #27
chenzhuops2
China
哥们儿哪里人?我在北京 刷bm3之前原厂跑log就有爆震 刷了bm3之后也有爆震在1500-2500转连续爆震非常严重 但是听不到发动机异常 我看过你的帖子 也看过你得log 几乎很健康而且点火也不低 我刷了之后还有点火低的问题
      11-07-2019, 01:30 AM   #28
haibebei
我在上海,98号汽油跑Oct 91的map没问题,应该95号汽油也够了
你是中石油还是中石化加的油?
      11-07-2019, 10:18 AM   #29
chenzhuops2
China
你是中石油还是中石化加的油?
中石化啊 最重要的就是我原厂低转速也爆震 这点儿让我有点儿郁闷 其他倒还好 你看过我的log了么?
http://www.bootmod3.net/log?id=5d92b356ae729b2cae3138bf 原厂98号油
http://www.bootmod3.net/log?id=5da6d01cc090c64ea9e1603e acn91 98号油
你看看
      11-07-2019, 10:19 AM   #30
chenzhuops2
China
你是中石油还是中石化加的油?
我换了ngk 94201火花塞 换了mkl300头段 用了bmc风格 就这些了
      11-07-2019, 09:14 PM   #31
haibebei
你把火花塞换了试试?原厂的timing看起来还好啊。
      11-08-2019, 06:52 AM   #32
chenzhuops2
China
火花塞已经是新的ngk94201了啊 我这acn91感觉点火是不是有点儿低
      11-08-2019, 06:53 AM   #33
chenzhuops2
China
而且你刷完了有没有变速箱脱档的问题?一千多转在三档特别难受
      11-08-2019, 07:14 PM   #34
haibebei
会拖档的,在1000转左右。用换挡拨片降档或者切sport模式解决
ACN91的log看起来比普通91好一些,但是动力会差些
北京中石化的油品这么差的么。。。。
      11-08-2019, 09:02 PM   #35
chenzhuops2
China
北京中石化的油品这么差的么。。。。
你觉得我原厂低转速爆震会是什么问题呢?不知道跟什么有关系啊 机油xmax 0w40不知跟机油是否有关系?oct91比acn91强很多么
      11-14-2019, 05:32 PM   #36
GreepM
Czech_Republic
Drives: BMW 330i 2019 F31 LCI
for 100octane gasoline in Europe... which stage 1 map should I use? E30?
      11-15-2019, 11:19 AM   #37
hybris
hybris's Avatar
Norway
205
So, map 91 = 95 euro, map 93 = 98 euro.
So you'd typically use stage 1 93. The maps seem to be tuned quite aggressively in terms of timing assuming high quality fuel, while many seem to experience that their local gas station does not provide the required quality.
So for instance myself (and many others) have to run the 91 (95) map despite using 98 octane gas.
You should also post your logs here and/or send them to PTF to verify that your car is working properly with the tune.
Thorbjorn
      11-23-2019, 12:21 AM   #38
haibebei
I also run oct91 with ron98 gas. As weather gets cooler now, I'm considering of stage 2 for more power. Is stage 2 any big difference from stage 1?
The log seems better than in summer.
http://www.bootmod3.net/log?id=5dd8bc51c090c60ec88333f2
      11-23-2019, 12:41 AM   #39
hybris
hybris's Avatar
Norway
205
Expected gains are listed here https://www.protuningfreaks.com/coll...-x3-x4-20i-30i
Thorbjorn
      11-24-2019, 06:05 PM   #40
haibebei
Hello I read your log
Is that stage 1? Why does it look so different from mine mainly in high rpm where your boost remain high at around 18 psi while mine is at 15 psi.
I'm also with Oct stage 1 91 map.
Maybe you had downpipe so you can keep high pressure through the high rpm?
