01-20-2020, 11:43 AM | #2707 | |
Rep 1,499
Yes bm3 has been available on Mac OS since day 1. It was developed on a Mac.
01-20-2020, 01:20 PM | #2708 | |
Rep 7,607
01-20-2020, 02:26 PM | #2709 | |
Rep 861
2023 i4 eDrive40
2022 Acura MDX |
01-20-2020, 06:13 PM | #2710 | |
Rep 287
ive read that the the trans shifts smoother and just as quick in sport/+ i dont know about comfort. it seems like the whole forum drives in sport mode. makes me wonder how often they are at the gas stations |
01-21-2020, 10:19 AM | #2711 |
Rep 3,022
Drives: 2019 M2 Competition
Jumping in on this thread... just made the transition to BM3 plus custom tune by Cary Jordan. I am blown AWAY with the results candidly.
Best stats (same dyno different day, different tune) prior (on my FBO, XDI35 N55 F32) was 429rwp 425 torque. Just posted yesterday 440rwp and 454 torque and three CLEAN smooth pulls and the curve on the dyno graph were spot on. I am truly impressed. And in response to the previous.. yeah.. I am Sport or Sport+ full time unless stuck in the !@#$!@# $ awful PacNW traffic, then ECO to save a few pennies.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
01-21-2020, 11:20 AM | #2712 | |
No 55mph
1622
Rep 8,476
Like I said yesterday - that is hella sweet And that's with stock turbo, 93, and the Jordan Base Map No doubt the XD helped you out Can't wait to see what is left on the table once he tweaks your tune Anxious to get my custom Jordan tune done now...
BMW DIY Guy3075.00 |
01-21-2020, 11:27 AM | #2713 |
Rep 3,022
Candidly I doubt there is very little if anything left for headroom. What really frustrates me is MYSELF yesterday at the dyno. I am not sure how but I completely screwed up getting logs. I have log entries with the time stamps, but no data in them at all. HUH?!
Figure it was something I did.. so will do it again at some point. I have the dyno output but not detailed logs which is a bummer.
01-21-2020, 01:19 PM | #2714 | ||
Rep 76
01-21-2020, 01:51 PM | #2715 | |
Rep 643
01-21-2020, 01:52 PM | #2716 |
Rep 3,022
Working on it.. I will have them as soon as I can.
01-21-2020, 02:22 PM | #2717 | |
Rep 2,654
01-21-2020, 02:26 PM | #2718 | |
Rep 3,022
My fuel rail looked like a dead patient.. it was bad. At peak RPMs my rail would be as low as 900lbs with the oem pump. Yeah, the pump isnt cheap but cant imagine pushing for the higher edge tunes without it.
01-21-2020, 03:09 PM | #2719 | |
Rep 643
if that is not the case, then was the car detuning itself with the stock HPFP? |
01-21-2020, 03:21 PM | #2720 | |
Rep 3,022
I bot the XDI-35 and installed, and then updated the tune for the HPFP. The only change in that build of the tune was HPFP support, not increasing anything else and the dyno run shortly after that put up 413rwp. Tthe updated tune after that put up 429rwp, with excellent rail pressure throughout the entire RPM band. Hopefully that makes more sense.
DeeM5527.50 |
01-22-2020, 11:38 AM | #2721 |
Rep 151
Further update on my v7.0 STG 2 ACN OTS saga. PTF suggested I run a 10% boost reduction across all gears to help. Now I'm seeing HPFP crash, overboost to 20 psi and 2nd cylinder timing is not keeping up as well as others. Any thoughts? Time to just get a custom tune?
BMW DIY Guy did you have any trouble with the 92 octane in WA like I am having? http://www.bootmod3.net/log?id=5e2860b3ae729b14d8182f62
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
01-22-2020, 11:43 AM | #2722 | |
Rep 3,022
01-22-2020, 12:09 PM | #2723 | |
Rep 151
Trying to determine if it's hardware or software issue i'm trying to fix! Also watched your video on the DV+ install, so thank you for that as I am wanting to do that soon, but plan to find a lift before I tackle it! My boost is not holding to target always as seen in the log.
01-22-2020, 12:12 PM | #2724 | |
Rep 3,022
Commanded and actual boost can vary a little, just depends on how much variance you are actually seeing. Give me a shout, I do commission work all the time here at my place.
01-22-2020, 12:23 PM | #2725 | |
Rep 151
01-24-2020, 09:46 AM | #2727 |
1296
Rep 3,533
01-24-2020, 11:44 AM | #2728 |
Rep 4,632
Someone mentioned HCP, but i guess bm3 does the OTS maps in house it seems, as i cant find any info on it.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
