03-24-2021, 04:08 AM | #23 | |
Rep 749
Drives: F31 320d xDrive M Sport
(If the correct part number is fitted)
05-14-2021, 08:10 AM | #24 |
Rep 5
TPMS Receiver
Many thanks to BBri89 for his help in giving me the location of the receiver.
My car is a 2015 320D F31 After much cursing and swearing I can actually see what I believe to be the receiver tucked right up under the petrol cap side window. However, despite many attempts I cannot for the life of me see how to get the final piece of trim off. Its the one in the picture , the plastic piece that the rear seatbelt goes through with the large protruding metal lug that the rear parcel shelf fastens on to. I have removed the three screws at the rear end of the panel as well as the two screws at the front of the panel, found underneath the rear seat side bolster. Also the two bolts at the bottom of the piece where the rear boot sliding cover clips into. Despite this the front section of the trim piece is still tightly attached. Any help on this would be greatly received. TIA |
05-14-2021, 03:56 PM | #25 | |
Rep 573
Hope this helps |
05-14-2021, 04:19 PM | #26 | |
Rep 749
05-15-2021, 02:05 AM | #27 |
Rep 5
Thank you so much guys.
3-GT that really does help, thanks for taking the time to post it. One of the steps listed as ‘preliminary work’ is the ‘removal of the D- pillar trim panel’ and I wondered if you would be kind enough to post details of that operation from your manual? Many thanks in advance |
05-15-2021, 06:06 AM | #28 | |
Rep 749
05-15-2021, 06:38 AM | #29 |
Rep 5
Thanks both - now finally got to it and need to order a new receiver from BMW. It seems this receiver operates the Central Locking too -I take it that's normal?
I'm usually pretty mechanically minded but I have to say removing and replacing trim is right up top of my 'hate' list |
05-15-2021, 06:59 AM | #30 |
Rep 749
Yep Tony, it's the central locking receiver as well.
Comfort Access/keyless entry use a different frequency, but normal key fob is 434kHz. The new part is £70ish, probably not the same part number as they supersede a lot of these things, but might need ordering from BMW UK or even Germany. At least you would hope the new superseded parts should fix some of the problems with older versions perhaps.
05-17-2021, 05:33 AM | #31 |
Rep 5
All fixed!
Thanks to help kindly provided I've sourced and fitted the new receiver. It has yet again been superceded by a new part see pic below of old part removed and package showing new part number.
For future info the trim was eventually quite easy to remove - once it was explained to me - and the part is plug and play. £66 from BMW. |
BBri89515.50 Techno 9000518.00 |
05-17-2021, 06:05 AM | #32 |
Rep 749
Glad you got it all sorted Tony
05-18-2021, 12:25 PM | #33 |
Rep 749
@jm84
This thread might give you some more info.
05-18-2021, 12:26 PM | #34 | ||
Rep 749
This might help
01-31-2024, 07:38 AM | #35 | |
Rep 179
A new receiver module sorted my problem and is located behind this panel. |
