11-16-2020, 06:08 AM | #45 | |
Rep 565
So speaking to the car audio guy hes said he will use it as a 3 channel set up. so channel 3 and 4 are bridged to be one channel for use in the future with another sub if I need more oompph So 4 channels will become 3 by : 130 w x 2 at 2 Ohm channels 1 and 2 (my woofers are 90w RMS at 2 Ohm) and the 3rd (bridged 3 and 4) will be idle at 260w at 4 Ohm |
11-16-2020, 08:06 AM | #46 |
Rep 2,069
Ah, I see. I didn't know you could have an 'idle' channel if using the other part of the split. Nice one, this should work a treat then.
When it's fitted, make sure he shows you where the 'gain' control is. You can then adjust that to your own taste, to get your own ideal volume balance of the woofers. Some like them to blend, others like them to dominate. I'm sort of midway. This needs to be adjusted with the main system volume set at least to 70%. So find somewhere to do it, lol. Cos the whole setup is going to be louder when the HK amp isn't directly driving the woofers. You'll know exactly what I mean when you come to do it.....
/// BM3 + M-Power ///
flashollie178.50 |
11-16-2020, 08:11 AM | #47 | |
Rep 2,069
BUT... there was strong conclusion that the woofers themselves were good, and will sound miles better if driven from a dedicated amp.
11-16-2020, 09:40 AM | #48 | |
Rep 565
Loads more complex than what I'd hope for with Plug and Play! |
t5pilot977.50 |
11-16-2020, 04:00 PM | #49 | |
Rep 2,047
Earthquake Sound SWS-8X, 4 Ohms: Specifications: • Model: SWS-8X Size: 8" high performance sub • Freq resp: 20-300Hz • Max Power: 300W • RMS Power: 150W • Impedance: 4Ω • Sensitivity: 86.7dB
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
11-16-2020, 04:23 PM | #50 | ||
Rep 2,069
Let's be right though, they're all very good, given the lack of flexibility in mounting replacement woofers & sound pretty incredible when amped properly. If you listen to any of these, you can't be anything other than impressed. I was lucky as I'd heard the Audisons in direct comparison to earthquakes. And I've heard the ghosts, but not in direct comparison. Unless you're an audiophile, I'd go with any of these, based on the best deal you can secure. None of these are cheap.
01-22-2024, 02:26 PM | #51 | |
Rep 6
Hi mate. Read your write up on m3cutters. I noticed you didn’t use a LOC. I’ve got the OEM HK underseats and have already got a sub in the boot wired using t tap connectors, LC2i and JL 500/1 amp. Any advice on how to amplify the HK underseats and how to go about wiring it without the Technic harness? |
