02-05-2024, 09:42 AM | #1 |
Rep 32
F32 msport suspension refresh
Afternoon all
My F32 Msport has just clocked over 90k amd I intend to give the suspension a bit of a refresh. The car currently has passive msport suspension and runs on 19" PS5's. I'm looking at keeping the comfort as it's a daily driver whilst having a sporty edge to it. I'm not that bothered about it being so low that it scrapes over bumps. However, I wouldn't mind fitting Eibach lowering spring to lower it just a little. I'm currently looking at the Koni special active kit listed below. Does anyone have any experience with these & would they work with the Eibach lowering springs? https://performancem.co.uk/choose-yo...cl-xdrive-edc/ Any help is much appreciated Thanks |
02-05-2024, 10:08 AM | #2 |
Rep 1,013
Stock M sport springs with Bilstein B4 = cheapest way to refresh stock, but B4s are allegedly 10% stiffer, so a little extra spice.
Eibach pro springs with Bilstein B4 = a little extra fruitiness over the stock setup. Eibach pro springs with Bilstein B8 = 'sporty edge' but at the expense of low speed ride quality. Konis reputedly work well but in my experience are terrible quality wise. |
danb19791897.00 |
02-05-2024, 10:28 AM | #3 | |
Rep 32
Even if it's a little stiffer than my current set up, I cant see it being any worse than a system that has travelled over 90k. think the B8's will be a little too harsh for my usage |
danb19791897.00 |
02-05-2024, 10:42 AM | #4 | |
1897
Rep 2,090
This is exactly what I've just done to my 2015 F31; with all new Sachs top mounts all round; all new mounting rubber parts/gaskets from BMW and all arms/links/inner tie rods/track rod ends replaced with a mix of Lemforder, TRW and Moog parts My F31 now drives & handles as it should; with no waywardness on the back end any more and it takes bends/roundabouts superbly All the works listed in my project (link below in sig) Pic of how it sits now: I test drove an F30 330D with the B12 kit (B8s with pro-kit springs); far too firm for normal roads (superb on the local country lanes and B roads/bypasses); but normal driving back to where my pals garage is; it was horrible (very jittery, bouncy and horrible when it hit raised manhole covers/potholes etc); albeit that was my opinion and everyones tastes are different...
02-05-2024, 02:16 PM | #5 |
Rep 32
I certainly don't want anything too stiff so I think B4S's will be what I'm looking for. I just want it tightening up a bit but still comfy enough for daily duties! |
02-05-2024, 02:35 PM | #6 | |
1897
Rep 2,090
I sourced everything via Autodoc bar the OEM BMW bits that I needed. You'll not better Autodocs prices TBH. Just keep an eye on their app as sometimes they have a big % discount and that's the time to buy |
02-06-2024, 03:06 AM | #7 |
Rep 1,013
At 90K, just replacing the dampers would bring about big improvements! They wear out so gradually, you get used to it and don't realise how bad they've become until replaced!
As Dan said, it's probably also worth checking and replacing any worn out suspension bushes whilst you're there. Especially at the back as that has more of an influence on handling than the front. Last time I checked, 1 front M sport damper was about 400 quid, so you can almost do the entire car with B4s for the same cost I think they would work well with M sport springs for those not wanting to lower the car at all. |
02-06-2024, 03:53 AM | #8 | |
1897
Rep 2,090
And yes; they'll work well with the OEM springs but for me, as my suspension was all original and the same age/mileage as the OPs near enough; refreshing with what I think are better springs than OEM, made a lot of sense; more so as it's all got to come apart anyway and replace the worn out rubber bits too (the spring perch's weather the most along with the bump stop/dust boots etc)
02-06-2024, 03:58 AM | #9 |
Rep 3,068
Not sure if these are still for sale in the classified section, but may be worth a look ??
https://f30.bimmerpost.com/forums/sh....php?t=2075235 |
02-06-2024, 04:26 AM | #10 | |
Rep 32
BMW's prices are an absolute rip off 🤣 Does anyone have any recommendations as to what suspension bushes to go for?bits not anything I've really looked into. Ove been on Autodoc and there's quote a few options about. |
danb19791897.00 |
02-06-2024, 04:31 AM | #11 | |
1897
Rep 2,090
I've used all 3 since 2010 and getting into BMWs and never had an issue with Moog whatsoever (on E38s, E39s, E65, F01 and now F31 etc); I've unfortunately had more issues with OEM BMW and Lemforder (Lemforder had issues with 2018/2019 parts - poor manufacturing issues etc)! Moog you'll get off Autodoc or your local motorfactors; Lemforder & TRW via Autodoc. Although when I was doing my shopping; they'd have one side, but not the other, if that makes sense
02-06-2024, 05:15 AM | #13 |
1897
Rep 2,090
They didn't say; just had the BMW sticker on them and that was it
02-06-2024, 05:25 AM | #14 | |
Rep 32
danb19791897.00 |
02-06-2024, 05:48 AM | #15 | |
1897
Rep 2,090
New bump stops/dust boots/gaskets for the top mounts and spring perches cost me around £250 via Cotswolds BMW (they offer forum discounts etc) I'd recommend getting new top mounts too; it makes a lot of sense as whilst it's all separate; they can be built up on the bench and then each corner swapped out in one go (if that makes sense)? If your OEM suspension is still in good health/not leaking/damaged etc; someone will buy it as they always do! Sold mine via eBay for £200 delivered (listed it when it was 80% off final fees); so cost me £20 all in!
02-06-2024, 08:33 AM | #16 | |
Rep 32
Would you recommend shorter bump stops if I run the eibach pro springs? Do you also have a link to any recommended rear bushes that would need replacing? Thanks! |
danb19791897.00 |
02-06-2024, 08:40 AM | #17 | |
1897
Rep 2,090
Re the rear arms; have a look on RealOEM and see the arms listed; I've replaced every arm/drop link etc on my F31, inc the inner CV joints/track rod ends too... I didn't want to faff about with replacing a few bits at a time; so got it all done in one swoop... Proper future-proofed This is RealOEM for a RWD 430D (not sure if yours is RWD or xDrive): Front suspension: https://www.realoem.com/bmw/enUS/par...BMW-430d&mg=31 Rear suspension: https://www.realoem.com/bmw/enUS/par...BMW-430d&mg=33 Steering arms (tie rods etc): https://www.realoem.com/bmw/enUS/par...BMW-430d&mg=32
02-06-2024, 11:54 AM | #18 | |
Rep 32
Is the Eibach pro kit much lower than the original msport suspension? It seems to be mostly xdrive folk installing it for the drop from what I can see. |
danb19791897.00 |
02-06-2024, 01:38 PM | #19 | |
1897
Rep 2,090
But what it will do is balance out the ride level/height: Before: After:
02-07-2024, 09:32 AM | #20 | |
Rep 32
Did you also get new nuts and bolts with the Bilsteins or is it so.ething I'll have to source myself? |
02-07-2024, 11:25 AM | #21 | |
1897
Rep 2,090
You get no bolts whatsoever; again I got all new bolts from BMW for the rear arms/camber bolts etc and the front bolts had been replaced under some warranty work in 2023; so they were fine. The rears came out fine; but its handy to have new ones in case they're rusted to buggery and need to be cut out etc...
02-08-2024, 10:33 AM | #22 |
Rep 32
danb19791897.00 |
