03-29-2020, 03:43 AM | #3015 |
Rep 40
Hi guys,
I broke my sd card socket on the unit and now Iīm desperately looking for a replacement. I found out that the sd and sim card sockets are on a seperate little circuit board (see pictures, the sim socketīs cover has been opened ). Do you know where I can buy such one? Or do any of you have a broken unit and would sell it to me? I was looking everywhere but couldnīt find it. Even the proper sim socket (without the board) is only available on ali, couldnīt find it anywhere else. I ordered it but it will take weeks to arrive and I hope I can solder it properly. So if anyone knows where to find the board, I would really appreciate |
03-30-2020, 05:19 AM | #3016 | |
Rep 67
03-30-2020, 02:19 PM | #3018 |
Rep 1,048
03-30-2020, 03:20 PM | #3019 |
Rep 11
Try this.
03-30-2020, 05:30 PM | #3020 |
Rep 80
Goodnight, i am going to buy a cic mid navi (bussines) for my e87 to use it with the android screen, the navi is codieren for an e84 x1 i think should work with mine. My question is, if someone knows, what i kabels i need to connect it with the android screen (mine abdroid screen have cic port) and what kabel i need to connect idrive controller 8 buttons with the navi.. because the seller doesnt sell the kabels. Thank you soo much!
03-30-2020, 08:16 PM | #3021 |
Rep 9
Hi! I bought a HU sd 625 from Mekede. HU does not accept CAN bus data.
1. Does not display speed, rpm, fuel quantity, or door closing. 2. Does not switch to the Parking sensor screen when reverse gear is turned on. 3. The I-drive joystick doesn't work at all: both in the BMW menu and in the HU menu. If I connect pin 6 and 7 together, or pin 17 and 18 together, the joystick only starts working in the BMW menu. 4. It doesn't turn off when I turn off the ignition. This is the second purchase from Mekede. In the first case, navigation did not work, and I made a refund. But in the first such device, the CAN bus worked perfectly. I checked the large power cable to see if it was short-circuited or damaged. I also tried changing "type A" to "type B" in the menu. Tried to upgrade the firmware, MCU, OEM. Does anyone have any ideas how to fix the problem? Maybe the hardware part of reading CAN-data is simple? And it's easy to repair? Or is it better not to risk opening a dispute on Aliexpress again? Last edited by lenkavovka; 03-30-2020 at 10:54 PM.. |
03-31-2020, 02:30 AM | #3022 |
Rep 32
03-31-2020, 02:30 AM | #3023 | |
Rep 86
03-31-2020, 04:04 AM | #3024 |
Rep 9
Yes, I did reset to factory settings. Absolutely the same head unit on Android 9.0 with the same settings worked perfectly in my car, but I had to return it due to a defective navigation module. In the new HU, navigation does not work, but there is no connection to the car.
03-31-2020, 05:02 AM | #3025 | |
Rep 86
03-31-2020, 05:16 AM | #3026 |
Rep 399
03-31-2020, 08:34 AM | #3027 |
Rep 12
After 2 hours searching on the forum I now know how to solve futere issues ;-) but could'nt find were i was looking for.
I would like to remove some menu items from my Mekede Android 9 HU with Snapdragon chip. For example the DVR (recorder) tile/button in the menu because I'm not planning to install a dashcam or any other camera's. Someone figured it out? |
03-31-2020, 09:03 AM | #3028 | |
Rep 80
03-31-2020, 10:09 AM | #3029 |
Rep 9
Unfortunately, I reconnected the cable many times. I checked that the plug goes deep enough. This does not fix the problem
03-31-2020, 10:17 AM | #3030 | |
Rep 9
I'm sorry that I don't know the correct name of some technical terms in English. |
03-31-2020, 05:22 PM | #3031 | |
Rep 399
https://f30.bimmerpost.com/forums/sh...&postcount=869 |
03-31-2020, 11:56 PM | #3032 |
Rep 9
@ Kri
I would like to clarify. I'm trying to solve my problem with the CAN bus data. In Android 8080 harness.pdf specifies "two cables to the CAN B violett/black" (Attach 1) But I have violett/black this is the 1 wire. All 4 wires is single. Do I have the correct harness (Attach 2)? Is this the complete CAN A/B connection diagram? Last edited by lenkavovka; 04-01-2020 at 04:31 AM.. |
04-01-2020, 01:46 AM | #3033 | |
Rep 551
Hello, Playing with a badly signed or badly compiled new launcher is a guaranteed crash ... So it is better to abstain or clearly warn here than on SNAPDRAGON unit in BOOTLOADER mode = TRASH-RUINED and PX6 unit in BOOTLOOP mode = TRASH-RUINED And we must repeat it loud and clear here ! In my opinion... |
daschacka76.50 |
04-01-2020, 12:39 PM | #3034 | |
Rep 399
The DVR tile can actually be useful, because you can attach any app to that button. For example, if you add com.zoulou.dab to the supported DVR apps in factory_config, you can launch DAB-Z with this button. |
04-01-2020, 01:13 PM | #3035 |
Rep 30
Hi. I have an Android 9 PX6 unit. I want to connect internet to the unit. I am looking for a 4G LTE USB dongle that will work with this unit. So it will download the internet via USB and then the unit will make the internet available as a hot spot via the Android menu.
Which modems / routers in Europe work with this unit? Unless there is a modem for USB or 12V that after turning on the ignition in the car will automatically turn on and start to share the Internet via WiFi. |
04-01-2020, 01:39 PM | #3036 | |
Rep 1,048
The Teltonika is easier to install, the mikrotik does have some more features, for only internet the teltonika is probably the best choice. I have the Mikrotik in my Car, connected to 30G of Hifi Amp , does start as soon as i unlock the car, and is running 30min after locking the car, so it will also stay on for a shop or fuel stop Kri |
daschacka76.50 |
