07-20-2019, 01:34 PM | #1 |
Rep 622
K&N Air Filter
Hey guys! I just ordered a K&N air filter for my 320i. I wanted to know if this is a downgrade from the OEM paper filter. Will the new filter damage my engine? Will it worsen my performance? Will it worsen my MPG?
Thank You!
Ishan Achar
Former: 2004 BMW E46 325i Current: 2017 BMW F30 320i Follow @Black_Lux_Cars on IG |
07-20-2019, 02:55 PM | #2 |
Rep 15,963
Shouldn't you have asked these questions before ordering it? IMO if something so inexpensive did what it claims to do BMW would use it as OEM.
07-20-2019, 02:58 PM | #3 |
Rep 622
Lmao you're right. I shouldn't have. But my thinking was that I'll use it once in a while if I'm planning to show off the car or have fun driving
Ishan Achar
07-20-2019, 11:00 PM | #7 |
Rep 406
Im using stock intake and filter on stage 2 bm3. I’ve hear mixed opinions on K&n for the n20/26 engines. Some have experienced cels with tunes after using K&n.
07-21-2019, 12:04 AM | #8 |
Rep 3,752
I always use dry filter, it would be oem or aftermarket.
alohasurftoad3007.50 AsianBill73.50 |
07-21-2019, 03:31 AM | #9 |
Rep 3,674
It will have a negligible impact on performance. You're better off staying stock IMO. I've run a K&N for a while without issue, but I don't think it's worth the money/maintenance.
Billfitz8169.50 |
07-21-2019, 08:21 AM | #10 |
Rep 15,963
A higher flow filter might, and it's a big 'might', give better results with a normally aspirated engine. With a turbo it won't do doodily squat. If you don't think BMW engineers know enough to specify an OEM filter that is up to the job you should own a ricer.
floridaorange10014.50 |
07-21-2019, 09:05 PM | #12 |
Rep 5,451
Drives: F30
Running KN filter with no issues. I let mine bake in the sun (after oiling) while I change my motor oil.
Was cleaning and oiling every 10k miles but Ive since found out that this is overkill. Going with once per year from now on (20-25k). |
07-28-2019, 03:38 PM | #13 |
Rep 34
Drives: BMW 320i XDrive
I use an aFe Pro 5R drop-in air filter which is their oiled air filter equivalent of the K&N filter. That's the only performance part on the car at the moment. I'd recommend using it if for no other reason than the fact that it will be the last air filter you have buy.
Does it actually increase HP? If it does you won't notice it since it's likely in the single digits. |
07-28-2019, 05:27 PM | #14 | |
Rep 5,377
I use a lifetime aFe Pro Dry filter. Definitely feel a difference from better breathing. About $70 and cleans easily by soaking in warm dishsoapy water. Then rinse it with warm clean water in the opposite direction of normal engine airflow. You'll be amazed how much dirt comes out even if the filter appears clean upon visual inspection. Let airdry for a day or so. Save your OEZ filter to pop in while the aFe filter is drying. Hope this helps! |
07-28-2019, 06:03 PM | #15 |
Rep 101
K&N are great filters BUT, it has shown over the years that the oil can become detrimental to the MAS. Since our cars run MAS I would go with a dry high flow filter. Though a HF in a factory box is probably only good to give a mild gain, but if nothing else the last filter you'll have to buy so it's a win either way.
There is a fine line between being a hero, and being a victim.
07-28-2019, 09:33 PM | #16 |
Rep 15,963
An oiled filter clog the MAF sensor and cause carbon deposits on the intake valves and manifold. Those in the know install an oil catch can to prevent oil from the crankcase making its way via the PCV to the valves, causing carbon build up. Intentionally putting something in that will cause carbon build up is totally illogical. It might not be a problem with cars that don't have direct injection, but ours do.
muniz_ri447.50 |
07-30-2019, 12:20 PM | #19 |
Rep 190,128
Congrats OP
Ishan99114.00 |
07-30-2019, 12:34 PM | #20 |
Rep 15,963
Cleaning the MAF is a routine maintenance item that should be done yearly in any event. It's the potential for added carbon deposits on the intake valves that would concern me. I clean my valves yearly, when I've got the MAF sensor out to clean it, but I have to think that very few owners clean their valves, or their MAF sensor either.
07-31-2019, 12:49 AM | #21 | |
Rep 943
Drives: F30 328i Msport
07-31-2019, 07:30 AM | #22 |
Rep 15,963
Cleaning the MAF and intake valves is part of my spring maintenance, along with changing the oil and filter, cleaning the A/C coils and doing a full interior and exterior detailing. It may not be necessary to clean the MAF and valves yearly, but it can't hurt, and I can afford the twenty bucks for the cleaners.
