BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 328i non-sport oil cooler?
proTUNING Freaks
      03-12-2018, 08:44 AM   #23
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Originally Posted by Alpine3s View Post
Sorry if I may be asking ignorant questions, probably something I can get answer by some spirited "google-ing" or a simple forum search. Wouldnt the oil need to be kept at a particular temperature for proper operation? Meaning, too cool or too hot is obviously not ideal, but in order to reach the oils viscosity (ie 5w30) are we intervening and may try to keep things "too cool" for operation? I understand number is upon start and the other is after its reached its heat points (viscosity).
I would like to hear it from the Gurus on the forum. If I keep the temps between 190-230 even after runs, back to back, etc, would an oil cooler be necessary? I log with the JB4 BT module realtime via iPhone and havent seen anything over 225 on a 88f ambient.
There is such a thing as too cool, but we won't hit it with a small oil cooler. I'm not sure how his is, but you can have thermostat controlled ones as well. Honestly, you don't need an oil cooler. The reason I brought it up was because I'm finally going with an upgraded turbo like Stubok and want to minimize the heat levels. The guys who bricked this engine came from high heat (track) and high torque. We can cap the torque, but I would like tonkeep the temps down so that it doesn't stress the rods.
      03-12-2018, 01:10 PM   #24
take1step
Drives: M340ix 2020
I think coolant/water temps are more of an issue with high power n20’s. I’ve seen water temps get to 230F on the stock radiator, I’ve got an upgraded turbo also.
      03-12-2018, 02:40 PM   #25
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
I will be giving an additive a shot here soon for the water. However, if you have an aux oil cooler, your coolant temps will be lower as well.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      03-12-2018, 03:46 PM   #26
Stubok
Drives: Melbourne Red F30 328i M Sport
Exactly this. You are rejecting less heat into the water since you remove the oil-water heat exchanger, and instead rejecting the oils heat to atmosphere through the oil-air cooler.
BunkerJ I did install it myself. I did it while I had the bumper off for my Depo headlight swap. With the bumper off and the cowl removed it was pretty easy.
My only issue was the bracket it came with positioned the oil cooler coil too low and it hit my FMIC. So I had to modify it slightly. I also had to trim the AN hose and reinstall the AN fittings to get the whole thing looking pretty.
Because of the extra volume in the system I also added 1 more quart of oil.
So far so good, but I've only had a 88f day so far nothing higher. Also my car came with the high temp pack.
I did reduced my tune to stage 1 for the time being to see how temps hold up. Going to slowly drive harder and harder and move to stage 2 and then 3 once I'm fully confident in the performance of the cooler.
      03-12-2018, 04:57 PM   #27
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Awesome. Keep me updated on how it goes! Turbo is going in here next week, so I'll be going the same route as you and capping it at 300/340 whp/wtq. Eventually I'd like to do the cooler.
      07-06-2018, 02:12 AM   #28
Manboy
Manboy's Avatar
Sweden
440
Drives: 2020 M135i Misano Blue
Finally installed my Kate Cool oil cooler
So yesterday I installed the kit myself. It took some time but wasn't to hard to do. here are some pics.
Note, that the dashboard pic is after pushing the car for a good 45min on highway at high speed and backroads with high revs. I am absolutely stunned how this kit keeps the oil temp down
In this particular scenario I would almost reach 120c degrees and DME would pull back power untill temp comes back down.
Now my car feels constantly responsive, no matter how hard I push it. I would say getting an oil cooler is not only good for track but for day to day as well.
ngl118.00
      07-06-2018, 08:49 AM   #29
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Good to hear! I've also had this on the back of my mind for awhile now but was likely going to go a universal route to cut the cost. Glad to hear the Kate setup wasn't hard to get in.
N26Ghost496.50
      07-06-2018, 08:54 AM   #30
Stubok
Cool, mine never gets hotter than that same temp gage tick and it's been 100F plus here in TX for weeks now.
The one design component that I'm not a fan of is plugging the return coolant hose. I prefer the design that has the coolant passing through the new plate and down its return.
I'm sure it's no bid deal. In fact it may even mean a cooler setup since no coolant heat goes into the new plate whatsoever.
Anyway nice job!
      07-06-2018, 08:57 AM   #31
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Anyway nice job!
Stu, could you clarify? So I'm assuming the stock Water/Oil exchanger is still in place and running; however, the new additional oil cooler is only air cooled?
      07-07-2018, 08:32 PM   #32
Diegov209
Drives: 540i Xdrive
I said fudge it and got this lol also ordered the oil cooler Gplus performance and Mach 5 performance oil coolers are the same talked to a Gplus service dude and gave me details on it lol.
http://www.ve-c.com/webs/VEC%20BMW%2...G%20PULLY.html
      07-09-2018, 02:38 AM   #33
Manboy
Manboy's Avatar
Sweden
440
The stock heat exchanger is removed, in both the Kate Cool setup and Stu's setup. In my case, the water hose is detached from the removed heat exchanger and simply plugged. I think in Stu's setup it goes via the new adaptor plate.
Either way the cooling process is seperated between water and oil.
Stubok471.50
      07-09-2018, 08:45 AM   #34
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Yeah, I see that now for the Kate setup. Comes with a sandwich plate.
      07-09-2018, 06:49 PM   #35
Stubok
Correct.
Water to oil HX is no more. Instead there is a conversion plate that allows the water to flow straight through to its return and the oil to circulate to and from the front mount cooler (oil to air HX).
      07-24-2018, 04:59 PM   #36
LordRuxpin
Drives: F30 N26
Did you feel a difference with this installed?
      08-10-2018, 01:59 PM   #37
Manboy
Manboy's Avatar
Sweden
440
Engine bay and front end looks a lot nicer with the oil cooler installed.
N26Ghost496.50
      10-17-2018, 10:32 AM   #38
Stubok
Well folks I guess you get what you pay for!
I'm so lucky this happened 200 yards from my house and I was able to freewheel my car into my drive.
The radiator in the GPlus system turns out to be junk. The plate, hoses and brackets are fine, but the radiator is crap.
With the cold conditions here (low 40's) and cold start I guess the oil pressure was high and the radiator couldn't take it and went pop!!
Oil all over my drive and in engine bay.
I still think a cooler is worthwhile for higher boosted engines, since my engine temps have been lower across the board but mainly during very heavy driving.
So now I have to find a better replacement Oil Hx core and redesign the system.
Be Careful with oil coolers. This could have been a blown engine!
Solidjake945.00
N26Ghost496.50
      10-17-2018, 08:51 PM   #39
Diegov209
Drives: 540i Xdrive
Wellllllllll I'm definitely going to make sure mine is okay lol
Current: 2017 Bmw 540i M sport bluestone metallic
Previous:F30 328i 2012 PWG: FBO Vrsf 6 stepped fmic, Afe intake, Catless DP ER, FTP CP's, FTP turbo inlet, GFB DV+, Gplus oil cooler, BM3 stg 2 tune, Cary Jordan E50 tuned stock fuel system.
      10-17-2018, 10:34 PM   #40
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
Stubok Oh crap... thanks for the heads up for something I wanted to get in the spring but I'm glad nothing catastrophic happened to your car!
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
Stubok471.50
      10-19-2018, 04:03 PM   #41
Stubok
Yea man if I were you I would plan to replace the gplus cooler/radiator part asap!
It is made from very light gauge metal and has bowed out in a few rows (particularly the top one which should be flat the the bottom) and fractured along the underside of the top bar).
Thinking about it, the Kate cool unit has 14 rows and other more expensive units I've seen have up to 25 rows.
I just ordered and will replace the failed cooler with this 19row Mishimoto unit.
https://www.summitracing.com/parts/MIO-MMOC-19
It has roughly the same dimensions and has the same AN10 fittings (so it will fit nicely in the same place and can use the existing hoses), but it has almost double the number of rows so it should have half the pressure drop. It's also Mishimoto so will be built right.
Those two things hopefully will mean it will not fail like the last one. Cost $150 so all in the kit is still a good deal.
Solidjake945.00
      10-19-2018, 08:33 PM   #42
Diegov209
Drives: 540i Xdrive
Gotcha yeah im going to order this this weekend forsure thanks Stubok much appreciated bro.
      10-22-2018, 08:02 AM   #43
Manboy
Manboy's Avatar
Sweden
440
I actually upgraded mine 14 row with a 21 row unit from Kate Cool. Easy Switch and the extra rows now makes sure i never pass 100c regardless of how hard I'm pushing the car - That is in Swedish weather conditions. I'm assuming it would go a little higher if in a warmer climate and pushed equally as hard.
N26Ghost496.50
Stubok471.50
      10-22-2018, 08:28 PM   #44
Stubok
Yea I went for the Mishimoto 19 row unit.
With my FMIC I can't fit anymore height, so the 19row unit works.
Interestingly before my Cooler blew up the temps were much better then with stock. Even in TX which is pretty much as hot as it gets. So I'm expecting it to cool off further and hopefully with almost double the pathways will be a lot lower pressure drop.
Solidjake945.00
Manboy440.00
