BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Confimed E90 Clutch fits!
proTUNING Freaks
      01-31-2018, 12:41 AM   #1
D041987
Big Turbo Boys N Girls
D041987's Avatar
Drives: 2012 328I 6speed
So with more people going with higher power outputs and bigger turbos on our cars the stock clutch will not last. My clutch gave out at 380WHP and we have limited aftermarket support for clutches and flywheel combos. The only one I found so far is a ClutchMasters but it's still very expensive and still uses the faulty SAC pressure plate. So I searched a lot and the data seemed to match up with the older 2010+ 328i E90 setup as they use close to the same Transmission S6-17BG Getrag. With days of calling and gathering info I gave it a go and orders the E90 setup from Southbend and got the Stage 2 clutch kit rated at 500ftlbs and an OEM F30 Flywheel.
When getting both sets side by side they are identical
- 9" disk diameter
- 240mm pressure plate mounting positions and height
- 22 splines. Sized at 1 and 5/32 (or 1 and 1/8)
- Center spring hub is the same depth
- Both use the same release bearing/ arm and alignment tool.
- Same Flywheel and pressure plate mounting bolts.
Overall I paid $540 for the stage 2 Southbend clutch disk and around $420 for the F30 flywheel. So very cheap considering the OEM F30 clutch is around $500 and flywheel is around $1100 at the cheapest I found. ClutchMasters is priced at $890 for a stage 2 and their flywheel is around $800-900 as well.
Looks like Southbend uses Sachs engineering pressure plate, Sachs release bearing and arm and an uprated LUK disk (or so the center mounting where the splines are say but could just be that center piece and they form their own disk material). So all high quality and OEM components!
Update as of 7/3/2019:
You can use any 335I pressure plate from the N54 or N55 engine.
Piece the kit yourself:
Recommend to use the NON SAC Pressure plate Sachs Part#: 883082001243
You can match this up to any aftermarket E90 328I clutch disk.
Use factory F30 Flywheel.
Setup is good to 550WTRQ.
If you want a fully assembled kit and not piece it by yourself:
SouthBend will put together the kit for you if you call and ask.
Use the clutch disk from K70528-HD either the daily (500ftlbs) or the endurance (580ftlbs) that is for the E90 328I and use the red pressure plate from K70526-02-SS.
Happy Tuning guys!
Stubok471.50
take1step100.50
      01-31-2018, 08:46 AM   #2
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Good to hear. What all do you have done to hit 380whp?
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      01-31-2018, 10:14 AM   #3
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Cool..
Mike
      01-31-2018, 04:06 PM   #4
bmwchue
Drives: 2013 bmw 328i
following
      02-02-2018, 03:48 AM   #5
D041987
D041987's Avatar
Custom twinscroll Mani with a BW EFR 7670 turbo. Stage 2 lpfp, ATM intercooler with FTP CP's, Custom Dyno Map and jb4 for control, ARP upgraded Rod bolts for protection, muffler delete, southbend stage 2 clutch. This is a break in map, I am shooting for 420-450whp. But playing it safe to see how engine internals will hold up. Turbo spools quick and has lots of top end.
Diegov209164.50
Stubok471.50
zinner559.00
      02-02-2018, 09:15 AM   #6
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Good luck and let us know! Only thing stopping me lol.
      02-02-2018, 05:31 PM   #7
terryd5150
Head Fry Cook at McBurgertown
Drives: 2015 435i M-Sport 6MT
So would it be fair to say the clutch/flywheel combo from the 335is would work?
      02-02-2018, 07:55 PM   #8
Diegov209
Drives: 540i Xdrive
Are you running pump gas or any type of blend?
      02-02-2018, 11:58 PM   #9
D041987
D041987's Avatar
Unfortunately I don't think so... The 335i uses a 26 spline input shaft and our cars use a 22 spline input shaft.
      02-02-2018, 11:59 PM   #10
D041987
D041987's Avatar
I have it tuned on e85 and pump 92. I can also run a blend as I have autotunning so it will sense what gas is in it and adjust the power for that.
      02-03-2018, 10:12 AM   #11
MacklinUSOB
Drives: f30 328i 6MT Sport
NICE WORK. When it comes time to replace my clutch/flywheel, I am going to be referring back to this for sure.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      02-03-2018, 12:36 PM   #12
Diegov209
Drives: 540i Xdrive
OH okay 👌 also if you don’t mind me asking where did you get the Custom Mani done at? My build is getting their I have ER charpipes, VRSF IC 6 stepped, catless dp ER, afe stage 2 intake, jb4 maps 2 and 5 e85 blend e30 mix basically, res and muffler delete, gfb dv+ and that’s about it plus federal 595 rs rr 275/35/19 with Esr wheels. Lately I’ve been wanting to pull the trigger on bigger turbo forged internals etc... but haven’t had any time due to work and school. What do you suggest in terms of tune I’ve been debating bootmod3 with a ACF performance and jb4 tune but just don’t know yet I do daily this now but want to get 380 or 400 later on as well.
      02-03-2018, 09:37 PM   #13
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
ACF is the way to go for a great E85 (E40 mix) tune. They are in Brazil where their cars run off the stuff.
Diegov209164.50
      02-04-2018, 10:22 AM   #14
Diegov209
Drives: 540i Xdrive
I need to go to brazil for ethanol lol smh why America can you not give us 93 octane and ethanol at every gas station lol that would be a dream there is 100 octane at a 76 gas station but haven't put it in besides a 91 and 100 octane mix which was like 93 octane I guess like the feeling better though on e85 less jittery in my opinon.
      10-10-2018, 11:53 AM   #15
OhioJon
Drives: M3/S38 3.0cs/M635
D041987 - Did you use the F30 or the E90 flywheel with the Southbend clutch?
If the E90 flywheel will interchange, did you consider the Valeo 835115 solid flywheel conversion kit for the E90 328?
      10-11-2018, 02:42 PM   #16
D041987
D041987's Avatar
E90 flywheel will not fit, it does not sit correctly on the splines (Too short and does not go deep enough). You need to use the F30 flywheel and E90 clutch. I do get slight judder with this clutch, so might try another option but only happens on cold morning and first gear starting out. It goes away after a few start and stops and all other gears are smooth. Clutch is also very grabby which might attest to the slight jerkiness cause of the material and extra stiff springs to provide additional clamping force. But a happy 8K miles so far and no slipping or issues.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
      10-15-2018, 10:49 AM   #17
LordRuxpin
Drives: F30 N26
Say again? Auto Tuning? How and where do I get this?
-2013 F30 328i xDrive Melbourne Red-
Injen CAI | GFB DV+ | FTP CP & TP | CW DP | G-Plus Oil Cooler | Mishimoto CC | VSRF FMIC | BM3 Stg 2| H&R Rear Sway Bar | H&R SS & Bilstein B8 | Carbon Fiber Dealibobs | 525 LPFP | Soon to come upgraded HPFP (B58TU) and Navardi Tune
      10-15-2018, 02:02 PM   #18
jamesf30n20
Drives: bmw 328i
The jb4
      10-15-2018, 02:46 PM   #19
D041987
D041987's Avatar
Originally Posted by jamesf30n20 View Post
The jb4
Correct, it is a flex fuel sensor and the JB4 adjusts the parameters accordingly.
      10-15-2018, 03:43 PM   #20
jamesf30n20
Drives: bmw 328i
The jb4
While we are on this subject, I know newer jb4 wire harness's have a fuel pressure sensor to adjust. And that map 5 has the auto tuning feature. But if I were to use a high e mix in a different map, say map 6 user adjustable, would the fuel pressure sensor benefit me and adjust my parameters, and or timing. Or does it only function in map 5?
      01-30-2019, 04:54 PM   #21
D041987
D041987's Avatar
Update, been 15k so far with the setup and not a single slip at my power levels.
      01-30-2019, 07:07 PM   #22
RMachuca3d
RMachuca3d's Avatar
724
Drives: F30 328i Msport
Just noticed you're local! would like to see this monster run some day, great numbers for a n n20\26!
