10-14-2018, 07:13 PM | #1 |
Rep 62
435i slow turbo
Hi
Previously had a 335i which had virtually no turbo lag. My ‘14 435i (17k miles) has pretty terrible lag - I can typically count to five before I can feel the turbo kick in. Wondering if this is: A) normal for a 435i B) a result of “comfort mode” C) indicative of an airflow or exhaust issue D) just a normal, albeit slow , turbo |
10-14-2018, 07:46 PM | #2 | |
Rep 3
10-14-2018, 08:09 PM | #4 |
Rep 10,351
I don't experience any lag. Perhaps it's not lag but a combination of comfort mode and the 8 speed AT.
What MY was your 335i?
"Drive more, worry less. "
335xi_full_throttle30.00 |
10-14-2018, 08:13 PM | #5 | |
Rep 62
It’s def turbo lag, though it might have something to do with comfort mode. I kick the throttle, it downshifts and 1,2,3,4 seconds it takes off |
10-14-2018, 10:08 PM | #6 |
Rep 470
Guessing the 335 was an N54? It had two turbos and one was smaller, so it was pretty lag free. The N55, though twin scroll, is not perfect and doesn't reach full boost until around 3000 RPM. I recommend replacing charge/boost pipe as well as a higher flow DP, all will help the turbo have less resistance to initial spool.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
10-14-2018, 10:38 PM | #7 |
Rep 5,776
Definitely not normal. Does it feel the same in sport? Or comfort with shifter to the left. When the turbo gets going does it feel quick or do the RPM's climb yet the boost feels low? This is indicative of a boost leak. These cars stock have very little turbo lag--but that is also relative to mode/gear you are in.
If your cruising in comfort at a low RPM and hit the throttle, the tranny goes down a couple gears and it does take a couple seconds to feel the power. Some does depend on how you drive and when you time your throttle. My car with my mods is fast and it is night and day when I hit it in comfort at 2000 rpm as opposed to sport or shifter to the left. But, I can get going real good in comfort if I time the throttle right at the higher rpm of the gear I am in.
Last car: 2011 335i Msport. JB4. Vrsf CP |
10-15-2018, 12:38 AM | #8 | |
Rep 62
10-15-2018, 12:43 AM | #9 | |
Rep 62
10-15-2018, 05:53 AM | #10 | |
Rep 232
The car you have now, even in Comfort mode, should spool up faster than you're explaining. The comfort mode will take a bit longer because it will likely have to kick down more gears to get you in a low enough gear for power, then spool up the turbo. But again, at worst case, you're in comfort mode at 7th gear, at 2500 rpm, pin the throttle, you should be pulling hard in under 3 seconds from the time you floor it. Do that in Sport mode, it should take less than 2 seconds for you to be pulling hard. Something sounds wrong, I'm not smart enough to tell you exactly what's wrong, I can only speculate, but I'd take her to the doctor. |
10-15-2018, 11:57 AM | #11 |
Rep 470
Wow OP, if you're N55 and experiencing this, that's really strange. Is it possible for you to log engine parameters using a JB4/BM3? That can help us see what's causing boost to stay so low (could be wastegates, boost solenoid, etc).
Current mods
10-15-2018, 02:32 PM | #12 |
Guy with a car
98
Rep 224
I have close to the same spec'd car except you dont have MPPK, but that is a large amount of lag that is not normal. Even in comfort mode lag should not happen to that degree. If you can pull the logs someone should be able to diagnose your issue, or point you in the right direction.
15' 435i BSM on CR // BM3 Stage 2 93 OTS // NGK Plugs Gapped 0.023" // VRSF Catless DP // CTS Turbo Intake, CP, FMIC // AWE Tuning w/ Perf. Midpipe // BC Racing BR Coilovers // Apex EC-7 // Michelin PS4S // Plus a shit load of carbon
10-15-2018, 05:02 PM | #13 |
Rep 190,725
If you have a tune , you can datalog boost and check if you have a boost leak.
10-16-2018, 02:12 PM | #14 |
Rep 62
10-16-2018, 02:13 PM | #15 | |
Rep 62
I bought a boost gauge and will install this weekend. Hopefully, that will give me additional info. |
10-16-2018, 02:15 PM | #16 |
Rep 62
The tune I have (dinan) doesnt allow for logging as far as i know, but I can probably log using an IOS app. I have the OBD 2 wifi adapter and have carly, as well as obd fusion.
10-16-2018, 02:33 PM | #17 |
Guy with a car
98
Rep 224
Oh apologies for the assumption, definitely not normal then. The boost gauge should help you narrow down the issue cause then since you can't share any logs. Hopefully its just a loose fitting that you need to tighten up
10-16-2018, 02:41 PM | #18 |
Rep 5,369
By an OBDII dongle and the Torque app and you can monitor and datalog boost.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
10-16-2018, 04:11 PM | #20 |
Rep 470
You should be able to find an android device for pretty cheap. It doesn't have to be recent.
Current mods
10-16-2018, 06:43 PM | #21 |
Rep 1,934
There are obdII dongles compatible with iOS devices. They're just more expensive than the kind that works with all of Android. Thanks Apple
10-27-2018, 05:22 PM | #22 |
Rep 62
Ok. The plot thickens. I was able to get an analog boost gauge tapped off the MAP sensor. I'm picking up boost - but pretty low levels of it with the Dinan in stage 1.
I put the Dinan in bypass mode.. and.. I'm getting a lot more boost and a lot less lag. So I don't know where that leaves me with Dinan. Not the results that I expected. With Dinan in bypass, max boost was maybe 5 psi. Without Dinan max boost was almost 9 psi. I should mention this car also has MPPK. I'll be reaching out to Dinan support. |
