09-03-2020, 07:02 AM | #45 | |
Rep 368
That's right. Or for the latest PN, I'll quote your earlier post...
02-10-2022, 08:29 AM | #46 |
Rep 1,209
A question for the folks that have done the HPFP on the diesel, got my wife's 2018 328d wagon back from the dealership with the HPFP recall late last night and have a question. At the lot it started fine. On the way home noticed what sounded like an air inrush sound. This was a new sound. Also noticed when we shut the car off there was the sound of something spooling/whirring down, only for a couple of seconds, followed by a "thunk". This was repeatable. Going to call the dealership this morning, but was looking for some insight before they get to make it worse. I hate it when people touch my cars, but this level of replacement is beyond what I can do at home. Any thoughts welcome.
02-10-2022, 08:45 AM | #47 |
Rep 368
Did they actually replace the pump? Quite often my car makes a thunk as the trans sets itself into park. Just intrinsic to having a cable free transmission shifter though. No reason the pump should cause a thunk I can think of. As far as the whirring / wind sounds, maybe the intake pipe to the turbo is loose? Or the air filter housing fits into a notch kinda deal on the left side, maybe they misaligned it. Unless you want to mess with the piping, probably best to have them take another look.
The throttlebody makes some noise when the car is shut off. Could always pop the hood and listen in that area to see if that's where it's coming from. Any software updates while it was in? I know my throttle body made a different noise previously, and now it makes a clicking noise like a woodpecker for about 5-10 seconds after shutdown… that started after I updated one of the ECU's. |
02-10-2022, 09:17 AM | #48 | |
Rep 365
What is abnormal is that you hear it now, which makes it more pronounced. That worries me whether or not they installed all the right things back, since they had to take a few pieces out to get to HPFP. The other question is whether or not they flashed your car with a newer iStep version while there? I noticed different versions may have adjusted the shut down sequence and turbo behavior, which as a result can affect the noise of the turbo spooling down. Let us know what you find. That is the exact reason why I have not taken my car to the dealer for the recall. I think my car is safer sitting on a time bomb than it is in my dealer's hands. It is sad, but true. |
02-10-2022, 03:05 PM | #49 |
Rep 1,209
Thanks for the responses, much appreciated. They did replace the pump, definitely a new part in there. Went out today and found the problems, plural. None of the clips holding the airbox assembly were engaged. The rear top seal of the air filter was clearly visible and looked a good 1/2 inch open at the back. Definitely sucking in some unfiltered air, glad we didn't travel far. The main air noise was what I call the mystery hose, it's the one that goes from the bottom, driver's side of the airbox to the main inlet. That was totally disengaged and just hanging in space. It click-locked back to the airbox with no problem, so I'm assuming it's okay. Definitely different shutdown noises than last night, also definitely on the passenger side of the engine in the area of the turbo. I checked as much as I could in the area of the HPFP and everything looks like it's connected.
I'm going to vent at the dealership later. They're going to get to totally reinspect the installation. The bottom of the airbox felt looser than what I remembered from doing the air filter in Dec of 202o. I'm hoping the air intake is connected. At least I feel comfortable driving it now. We let them do the rear brakes instead of me doing them, plus they did two control arm bushings. Given how gently she drives that wagon I'm not happy about the bushings at 45k miles. So about $1700 over and above the recall. Last edited by lfdal54; 02-10-2022 at 03:11 PM.. |
02-10-2022, 03:23 PM | #50 |
Rep 368
Glad you got it figured out. Sounds like they just got lazy! 45k is definitely early for control arm bushings. I did the rear bushings at about 180k, BMW actually calls them ball joints if it's the same one I replaced. Very tricky job without the specialty tool.
02-14-2022, 01:22 PM | #51 | |
Rep 421
Drives: 2017 F31 328dx
02-23-2022, 07:46 AM | #52 |
Rep 1,209
Sorry for the lag, been away. My shutdown noise was similar, but stopped within 15 seconds. Didn't have the startup noise.
Looks like I'll be making another trip back to the dealership though. Noticed when wife pulled out of garage last night there was oil under the car. Looked at the car after it sat in the garage a while last night. Looks like the top of the splash shield, or whatever BMW calls the undercover is wet with oil. Looks like the underside is as well. Slid some cardboard under there and will look at it after I have more coffee. Popped the engine cover but couldn't see anything obvious. Any idea what they could have compromised that would cause an oil leak? Can't believe this is a coincidence. Did I mention I hate letting anyone else touch my cars? Last edited by lfdal54; 02-23-2022 at 09:56 AM.. |
02-23-2022, 11:05 AM | #53 | |
Rep 3,540
02-23-2022, 12:39 PM | #54 |
Rep 1,209
If only there was a dipstick..... the automated oil check says its fine. The fill cap is fine and the oil filter cap is fine. Can't really see anything from above, except the wet top of the undershield. If I wanted to find it the best way at this point is to put it on ramps and pull the undershield. Made an appointment for the dealer to fix it on Tuesday. They would have taken it on Saturday but it needs a March inspection sticker. Going to see if I can find the procedure for changing the HPFP to see what they might have screwed up. I also hate trying to clean up oil stains on my concrete garage floor.
02-23-2022, 01:04 PM | #55 | |
Rep 1,805
02-23-2022, 05:05 PM | #56 |
Rep 1,209
Not on my 2018. At least whatever is in the dipstick tube doesn't come out. I've pulled with as much pull as I dare and it doesn't budge. Can't see any sign of a locking mechanism ala Nissan but I'll ask the dealer next week. Be nice if there was a useful stick. Went researching and saw folks recommended turning and pulling hard. I have unpleasant visions of breaking something.
02-23-2022, 10:04 PM | #59 |
Rep 1,209
Appreciate the responses. Thats interesting - "remove the torx screw that holds the dipstick in place" - torx screw? I can find the dipstick easy enough. Although the stick on mine has a black top. I can find a p/n for the stick on realoem, and cross it to a stick from a BMW dealership, although doesn't look anything like the head on mine. I'll give it one more good tug tomorrow then ask the dealership to free it up when they have the car next week. Sincerely, today I put my entire bodyweight behind pulling on the thing with no results. BTW - I've had the cover off on my X3m40i and if that has a stick I haven't seen it, nor does realoem list one. I'll look again next time I'm under there. Hasn't been a concern so far since the dealer has been doing the oil changes on both of them, although I plan on starting to do the 328d's now that its about to hit 50k.
02-23-2022, 10:17 PM | #60 |
Rep 368
The Torx screw is just for removing the dipstick holder from the engine block. That was a pic from the writeup in this thread to remove the hpfp. If you have one it shouldn't need any tools. Dunno, mine comes out pretty easily, but it's a 2014.
02-23-2022, 11:22 PM | #61 |
Rep 365
I have a 2018, there most definitely is a dipstick. I use it every time I changed my own own after the "free" maintenance period ended. It does not require brute force, I pull it with 2 fingers. You don't have to take cover off, it just makes it easier with cover off. All N47 and N57 engines have it. Only gassers got rid of dipstick.
02-24-2022, 02:31 PM | #62 |
Rep 1,209
First, thanks everyone for not calling me an idiot. Kindness is much appreciated. I went out there again today and gave the stick one last ho-heave-ho. It let go with a pop and came out of the tube. All in one piece. Yea team. Interestingly enough I reinserted and removed it about a dozen times thereafter and its now a light two finger pull just like any other dipstick. The good news is that it agreed with the iDrive and I haven't lost enough oil to make a dent on the stick. The bad news is that the drip pan I slid under the car is still getting oil on it. Onward to Tuesday.
02-24-2022, 05:00 PM | #63 |
Rep 542
If the engine is N57, see attached procedure for HPFP replacement.
It states, the transmission has to be dropped as well. (Auto). 13 51 017 Removing and installing_replacing high pressure pump (N57 D30 O_T 1).pdf
335d xDrive
02-24-2022, 05:59 PM | #64 | |
Rep 1,209
02-27-2022, 08:13 AM | #65 |
Rep 368
Ouch, it is a little tight on the N47, I would have to see it on the N57. Maybe you could get away with just lowering the tail of the transmission. Unless the bell housing is in the way or something, then I guess removal it is! Glad I didn't have to do that.
03-10-2022, 01:22 PM | #66 |
Rep 1,209
Just cause I hate to bother people for information and not tell them what happened.
The oil leak was the o-rings on the dip-stick tube where it goes into the block. At least that's what they said. I was trying to replay the chronology of events to see if I contributed to it. When she first got the car back in 2019 I noticed the dipstick tube and gave the stick a few good tugs. At the time I wasn't sure if it was really a stick or something BMW blanked off so I didn't pursue it. No leaks in the intervening time. I didn't notice the leaks on the floor until after the car came back from the recall. Indeed, in the two weeks it was at the shop, I definitely noticed no oil on the floor. I did start to mess with the stick as I mentioned previously, but not until after the HPFP was changed and I noticed oil on the floor. So, I don't think it was anything I did. Been back in the garage a week now with a 240 mile round trip on-it and no oil loss or further staining. I hate coincidences. Thanks for all the advice. Last edited by lfdal54; 03-10-2022 at 02:47 PM.. |
FaRKle!4017.00 |
