06-25-2018, 09:24 PM | #1 |
Rep 184
Drives: F30 N26
Sport + and Launch Control - Review
So, this probably exists somewhere already, however I would just like to report that if you don't have Sport + and Launch Control already... GET IT CODED IN NOW!.... Best $120 I've ever spent... I went through this guy Steve Ma, from Canada.. he coded my car in like 15 minutes... Here's the site http://www.codemybimmer.ca/?v=7516fd43adaa
I tried to figure out all this coding stuff on my own, managed to get the mirrors and few other things, however it's just time consuming and I had other things to do, so to have him do this in like 15 mins and me be on my way was a life saver. Things I recommend though, just buy a ENet cable in advance, make sure you can hook-up an ethernet cable to your computer. He'll give you everything else that you need to do. |
06-26-2018, 08:51 AM | #2 |
Rep 184
Drives: F30 N26
sspade for the 1/4 mile times you've been posting, was it discussed if everyone who ran was using LC and or Sport +????
06-26-2018, 09:42 AM | #3 | |
Rep 5,457
Drives: F30
I honestly dont have an opinion either way as I dont have these items coded, maybe someone who does could chime in. I managed to get SAT coded through BimmerCode but havent ventured into expert mode to try Sport+ or LC coded yet. I want to but would need to be walked through it like a child as I dont have any "real" coding experience and am afraid I would mess something up... |
06-26-2018, 09:46 AM | #4 |
Rep 2,382
Good to hear. I'm a huge supporter of everyone getting 2TB. Not to discount your coder but just simply for those who want to learn or would like to save some money, do let me know if you want to get into coding the car! It's pretty simple once set up and there are plenty of references to keep by your side to ensure you take each step correctly. Otherwise, sounds like Steve is the guy!
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
LordRuxpin103.50 |
06-26-2018, 09:47 AM | #5 | |
Rep 2,382
sspade2464.50 LordRuxpin103.50 |
06-26-2018, 11:38 AM | #6 | |
#gotboost
517
Rep 861
Please let me know if there has been some update that now allows you to add in 2TB because I haven't messed around with it since earlier this year
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
06-26-2018, 11:40 AM | #7 | ||
Rep 5,457
Drives: F30
06-26-2018, 01:46 PM | #8 |
Rep 184
Drives: F30 N26
BunkerJ To be clear, I just had other things going on ... and didn't feel like messing with it... the 120 is me buying the cable separately and including it in the over all price, so it's actually cheaper in general. But yea, in the future when I get my 6WB and Paddle shifters, I'll be coming to you.
06-26-2018, 04:02 PM | #9 | |
Rep 2,382
06-26-2018, 07:33 PM | #10 |
#gotboost
517
Rep 861
Wooooo, thanks dude! Going to do this today
06-26-2018, 07:49 PM | #11 |
Rep 2,382
Wait, if 2TB is an option, then that should enable Sport+, SAT, and Paddles.
06-26-2018, 08:23 PM | #12 |
Rep 5,457
Drives: F30
People without factory SAT/2TB dont have paddles, right?
It did not enable Sport+ on my car... unless Im doing it wrong. All you do is push up on the rocker switch to get to Sport and then again to get Sport+ right? |
06-26-2018, 08:35 PM | #13 |
Rep 2,382
Yes, that's right. 2TB comes with Sportline and M-Sport models. I retrofitted a wheel with paddles since I have a baseline. But yeah, 2TB encompasses SAT, Paddles, LC, and Sport+. If you don't have Sport+, then it just did SAT and didn't code paddles, Sport+, or LC. In ESys, you can change the "205" in the Vehicle Order (VO) to "2TB" and it enables all of the above! Looks like Bimmercode does it by changing each variable instead.
06-26-2018, 08:40 PM | #14 | |
Rep 5,457
Drives: F30
06-26-2018, 08:50 PM | #15 |
Rep 2,382
If not, you could always VO code it through ESys. Takes one value to solve all your problems.
06-26-2018, 08:56 PM | #16 |
Rep 5,457
Drives: F30
Ughhhhhhh. Trust me, I want to. Got a few personal issues on my mind at the moment but will come around in due time. Im definitely taking you up on the offer (of help) - trust me!
BunkerJ1032.00 |
06-26-2018, 09:40 PM | #17 |
Rep 2,382
Always understandable. Let me know and we'll get you going in under an hour easily. Just FYI, I don't charge btw. It's all free.
06-26-2018, 11:39 PM | #19 |
Rep 2,382
Exactly. For me, it's cool to just teach those who want to learn and they just pass it on and make life easier for everyone and make us all smarter!
06-27-2018, 11:31 AM | #20 | |
#gotboost
517
Rep 861
EDIT: If you have the base'st of base models like myself, you will be able to enable the sport display gauges, but they wont work EDIT2: Its been so long since I've done it....I think this is the list: Kombi/ 300C /ECO_FDSF /Function / -> FDS_MENUE_TEXT_1=> menue_3 -> FDS_MENUE_SIGNAL_1=> menue_3 -> FDS_MENUE_TEXT_2=> menue_3 -> FDS_MENUE_SIGNAL_2=> menue_3 -> FDS_MENUE_TEXT_3=> menue_3 -> FDS_MENUE_SIGNAL_3=> menue_3 -> FDS_MENUE_TEXT_4=> menue_3 -> FDS_MENUE_SIGNAL_4=> menue_3 ICM/3000 Daten -> IcmKod_B_Sportlenkung -> verbaut ICM/3000 Daten -> IcmKod_B_S2TBA -> verbaut EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! Last edited by MONSTAR; 06-27-2018 at 11:38 AM.. |
06-27-2018, 01:16 PM | #21 | |
Rep 2,382
06-27-2018, 02:59 PM | #22 |
Rep 5,457
Drives: F30
Thanks guys. Will be attempting this soon.
For what its worth, I already have working sport gauges from the factory. Does that mean anything?! |
