11-06-2018, 12:23 PM | #1 |
Rep 283
Programming Canadian car at US Dealer?
Hey everyone, I recently bought a 435 that is a Canadian market car. It was imported in early 2016 to the person I bought the car from. It has a MPH Cluster and is legal in the states. I recently was in at the dealer and requested programming on the car to update the vehicle, but they said it failed because the iDrive and the Instrument Cluster are both Canadian parts! The dealer suggested to install a U.S. Instrument Cluster and a U.S. iDrive.
My Questions are as follow... 1.) How can I get my car updated? 2.) My connected drive does not work, and I CANNOT connect to my mobile app, so how would I resolve this issue? I hope there is someone out there who has had the same issue that I am currently experiencing, because my dealer and everyone I have talked to have never seen this before.
2014 F32 435i /// M Sport Brakes /// Vorsteiner VFF103 /// Resonator Delete /// MP Carbon Front Spoiler /// MP Carbon Mirror Caps /// MP Carbon Rear Spoiler
@slowf32 on instagram |
11-06-2018, 12:37 PM | #2 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
1) This is likely due to a mismatch in the installed equipment with the vehicle order stored in the car. Most likey due to the instrument cluster swap. The iDrive unit is actually the same between US and Canada. 2) US and Canada use different versions of the app so if you can download BMW Connected Classic from the Canadian App store, that will work. Do you know who did the cluster swap? If option 838 (National Version Canada) was left in the vehicle order, that's likely the cause of the issue. I would see if you can find a coder who can check that for you and remove it. From there, you can try and see if the dealer can program the car.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
11-06-2018, 03:14 PM | #3 | ||
Rep 283
11-09-2018, 12:57 AM | #4 |
Rep 283
How can I get my car programmed? I just want the software on the vehicle running the newest possible
11-09-2018, 01:15 PM | #5 |
Rep 765
11-09-2018, 03:29 PM | #6 |
Rep 283
Then why would my dealer recommend new headunit and cluster ?
11-09-2018, 06:37 PM | #7 | |
Rep 765
11-10-2018, 03:40 AM | #8 |
Rep 1,976
I can remove option 838 from your FA and you can attempt to have them program the car again to see if it works. No guarantee that it will work though.
Removing 838 should allow ISTA to treat it as a US car and allow ISTA-P to carry out the programming given that you have a US cluster in there.
12-07-2018, 12:13 AM | #9 | |
Rep 283
12-09-2018, 12:00 AM | #10 | ||
Rep 10,473
If the info doesn’t match what’s in the database for the car, ISTA stops the cycle before the coding is performed. I’ve seen it happen multiple times first hand. Quote:
See above. |
04-10-2019, 02:57 PM | #11 |
Rep 283
hey late response, but i finally have time to solve this issue. i have esys, i can download the full psdzdata. Are there any tutorials on how to do this diy?
04-16-2019, 12:36 PM | #12 | |
Rep 765
04-16-2019, 12:37 PM | #13 | ||
Rep 283
04-16-2019, 12:38 PM | #14 | |||
Rep 765
04-16-2019, 12:39 PM | #15 | ||||
Rep 283
04-16-2019, 12:43 PM | #16 | |||||
Rep 765
blakep842.00 |
