07-18-2018, 07:47 AM | #1 |
Rep 191
Drives: 2013 328i xDrive
Seat got wet....seat occupancy sensor error
Left my windows down a couple inches and experienced an unexpected rain storm. My passenger seat got pretty wet and now I'm getting fault code #930AC9 and a warning on my dash regarding a passenger seat airbag system malfunction. Ran a diagnostic via the Carly app and got the following description:
ODS system: seat occupancy mat passenger module for ODS system sends error #13 / ODS System: seat occupancy mat passenger sends CIS internal electronic fault (external comparator). Any thoughts on how to correct this? Is this something that may correct itself after it drys out? Any insight would be greatly appreciated. Ultimately trying to avoid a trip to the dealer.
'13 328i xDrive│Jet Black│BMS JB Stage 1│MPE│18" 400M & Conti DWS 06│DelVal BMW CCA #533245
07-18-2018, 07:53 AM | #2 |
Rep 209
According to my CA this is the leading cause for replacing the mat. Ask me how I know
Unfortunately will not be covered by warrnary as it was damaged not malfunctioning. |
07-18-2018, 07:55 AM | #3 |
Rep 16,081
You get that warning when the seat wiring has been unplugged. Water in the connector could have shorted something out, giving the same result. A good diagnostic tool, like the Foxwell NT510, can tell you if the fault still exists and if it's OK can clear the code. I can't say if Carly has that capability. It won't clear by itself.
07-18-2018, 08:05 AM | #4 | |
Rep 191
What are my options to correct this? I guess the obvious one would be to replace the sensor mat but was wondering if there are any other things that can be done. Can I unplug the connector and attempt to dry it out?? Also, I saw that there are bypass modules that you could buy online.
07-18-2018, 09:25 AM | #5 |
Rep 191
Did some more research and found an emulator bypass module on ebay in the event the seat occupancy mat has failed. This bypass will tell the car that the seat is continuously occupied and will allow me to clear the fault code. Hopefully, I can dry out the connector and fix the problem but if not, this emulator will solve the problem.
Here's the link to the emulator on ebay in case anyone is interested: https://www.ebay.com/itm/Seat-Occupa...sid=m570.l1313
07-18-2018, 10:02 AM | #6 |
Rep 5,993
That doesn't actually fix the problem, though I guess you could just make sure anyone who sits there weighs more than 45 pounds. Otherwise the airbag will always go off and could injure or kill a small child in an accident. Or just don't get in an accident.
murphius111899.00 |
07-18-2018, 10:10 AM | #7 |
Rep 191
I hear ya about it not being an actual fix but rather a work around and my 8 yr old daughter will never ride in the front seat until she can do so legally. I believe in PA the child has to be in the back seat in a booster until they are over 80lbs. Thanks for the input and I will do my best to not crash and burn
bimmer4562959.50 |
07-18-2018, 03:07 PM | #9 | |
Rep 191
I see you regularly on the forum and you have some good insight but I think you missed the mark on that last comment. If you have some input that's relevant to the repair besides running to the dealer then feel free to share.
07-18-2018, 03:15 PM | #10 | ||
Rep 10,473
07-18-2018, 03:31 PM | #11 | |||
Rep 191
Billfitz8243.00 |
07-18-2018, 03:39 PM | #12 |
Rep 10,473
07-18-2018, 04:02 PM | #13 |
Rep 191
Thank you for your insight and genuine concern for my family. Now if we can move on to some actual constructive commentary...I'm all ears.
07-20-2018, 01:20 PM | #14 |
Rep 191
UPDATE....I was able to gain access and dry out the seat foam by unclipping the passenger seat upholstery from the rear, shoving a small desk fan under seat and set the fan to high for more than 8 hours. I removed the fan, waited an additional two days, ran a diagnostic via Carly app, cleared the seat occupancy mat sensor fault and it appears that worked!! No more fault warnings. So I just had to allow the seat and electronics to completely dry and problem solved.
12-19-2019, 06:14 AM | #15 | |
Rep 2
02-03-2020, 07:28 PM | #16 | |
All your 1 are belong to us!!!
20
Rep 658
Any help much appreciated! |
09-22-2022, 09:52 PM | #18 | |
Rep 15
Drives: 2018 bmw 320i xdrive
09-22-2022, 10:00 PM | #19 | |
Rep 15
09-24-2022, 09:36 PM | #20 | ||||
Rep 18
12-24-2022, 07:32 AM | #21 |
Rep 15
My windows opened the other day in a rain storm because of our crap key fobs. Same error. I'll be trying to clear it tomorrow by getting into the seat and drying it out. I'll try to take some pictures.
The real bugger is it went from 50 and raining the night before last to 11 degrees now. So I can't finish drying the car until I can get it inside a heated garage. |
