BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Avin USA 10.25 android system install DIY
      09-21-2018, 06:51 AM   #2289
Bosley
Bosley's Avatar
Italy
Drives: BMW F20 116d 2.0
Originally Posted by hamouess View Post
Sorry i give the bad link, it’s os update, i have too mcu update if you want ( but may version )
https://mega.nz/#!U9hWUAaA!AwNrZJ2aT...hMA0AJDHUxzIoo
In another thread in this forum you can find:
- MCU 17.07.2018 update
- OS 28.08.2018 update
Anyway those updates I'm suggesting to you are not AvinUsa specific, but just updates for Android 7.1 head units..
      09-23-2018, 09:47 PM   #2290
therick3
Drives: 2015 X5
Android Split Screen
For those running 7.1 Android, can you run split screen when in android mode(long press on overview button )? (Not talking about BMW Split Screen). Meaning Google Maps in left panel and Google Music/Spotify in right panel? I know PIP is not available until 8.0 but am hoping someone creates a PX5/4GB unit for the F15s eventually...
      09-24-2018, 01:21 PM   #2291
hamouess
Drives: F20 116d
f you're talking about kalinkamaen, for me it did not work ( https://drive.google.com/drive/folde...b0SYl285RLrom8 )
      09-25-2018, 03:52 AM   #2292
Sturrock
Drives: F31
Hi peeps
Having a problem setting up a Samsung S9 as a mobile hotspot, asked avin and they sent an OS update with a date of Jan 2018. Didnt help and the subsequent email to Avin asking for help hasnt been responded to yet. Is Jan the latest update?
      09-27-2018, 01:51 AM   #2293
tpaxadpom
Drives: 550i
I have the same question. I found FW from April, but not sure if it is the correct one... I loaded Jan and Nov images today and do not see ID6 interface. Not sure what's going on. I had november fm previously and ID6 interface along with updated ID5 interface was available in the factory settings.
Figured it out. Had to update factory.xml, ended up updating everything in OEM folder and it worked.
      09-28-2018, 04:17 PM   #2294
Noelmus
Noelmus's Avatar
Drives: BMW E92 320D
Hi,
Thanks all of you to try and help each other especially for those people who are not technical. The fact is that after sales is minus 100% from all sellers. They only help you since you buy and give them good money.
I bought Android 4.4 Car Multimedia Player GPS Navigation for BMW 3 Series E90 with BT DVD SD USB WiFi 4Core a year ago from China and still they don't give me a single update. One of my issues is the car type. I can't select other car model cause it freezes on only one model.
Very disappointed.
      09-29-2018, 02:39 PM   #2295
Wooju
Drives: 5 series F10
To moderator, maybe it would be usefull to create a new section on the forum for all of us having the Android screens. Main reason is easyness of find the answers for the questions as the same ones are beeing asked over and over again... just a suggestion
      09-29-2018, 08:05 PM   #2296
mavic1010
Drives: G30 530e
Anyone also having issues with Carplay, IOS12.1 and the iPhone XS? Can't get it to load even when after updating to the most recent AutoBox. However, it works with the 7s on 12.1.
      09-29-2018, 09:02 PM   #2297
Echoes23
Hi, it would be really appreciated if someone can help me here. I want to order an android headunit for my bmw f30 2013 but i don't know if i have cic or nbt. I did my research and it looks like cic but forums are so confusing. I have a small screen with no nav. I checked the vin decoder and got no answer. Mine is a.march 2013 production date. Can someone help me here ? Thanks
      09-30-2018, 03:50 PM   #2298
Wooju
https://s.click.aliexpress.com/e/mPYXahj
Cic - 4 pins, nbt - 6 pins
      10-01-2018, 02:27 AM   #2299
rossjmccarthy
Drives: BMW F30 330e
Losing time and date
Hi all,
First time poster on here but following for a while.
Just received the AVINUSA Gen 2 unit (android 7) and on fitting the unit over the weekend I seem to have an issue. The BMWConnected drive is no longer holding the time and whether set to automatic or if I enter the time manually it remains at --:-- and will not set or hold the time or date.
This has a big knock on as my car is a 330e and uses this date and time to allow for offpeak charging and preconditioning of the cabin.
Has anyone seen this? I've searched the forums and given a good google with no luck.
Everything else works fine, including GPS.
Edit: I have made a video to demo the issue. Anyone seen this before?
https://youtu.be/aZpFgi739S8
      10-01-2018, 11:56 PM   #2300
zimasha
Drives: 2004 530i
Originally Posted by rossjmccarthy View Post
Hi all,
As i have noticed in your video, you did not remove the fiberoptic cable from the main harness and reconnect it to the back of the headunit. This might be the problem.
      10-02-2018, 12:58 AM   #2301
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Hi all,
This.
      10-02-2018, 11:05 AM   #2302
rossjmccarthy
Absolutely spot on. I though I just needed to move these if I had no sound so ignored them. Moved them today and clock back working!
Thanks!!!
      10-03-2018, 01:36 AM   #2303
s2kvee
Drives: 2008 BMW E90 M3
i have a ugode system but i feel like theyre all the same.... anyways. has anyone been able to figure out how to enable the idrive select button? I use my system for carplay and its annoying to have to use the touch screen. My idrive wheel allows me to scroll through the apps but does not select when in carplay mode.
same goes for next track, has anyone been able to make a button work for skipping tracks? i have to use the touchscreen.
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current
      10-03-2018, 04:33 AM   #2304
luisavila
Drives: X3 F25
hello, you can help me, the screen is great, but this button pdc does not want to work on android, when press button should open oem camera. i problems with displaying the PDC in android
      10-03-2018, 02:05 PM   #2305
zimasha
Drives: 2004 530i
You can buy a wireless touchpad cover for idrive knob. I installed one and it is pretty easy to install and works perfectly with android screen.
      10-03-2018, 06:56 PM   #2306
tpaxadpom
Drives: 550i
Looks like a pretty cool option. Do you mind sharing a link where one can find it?
      10-04-2018, 12:15 AM   #2307
zimasha
Drives: 2004 530i
https://m.made-in-china.com/product/...729057262.html
      10-04-2018, 03:19 AM   #2308
kalinkamaen
Drives: BMW X3 2.0 Diesel
Any video of this working?
      10-04-2018, 08:04 AM   #2309
zimasha
Drives: 2004 530i
I will post a video later
      10-04-2018, 11:45 AM   #2310
tpaxadpom
Drives: 550i
How much did it cost? Video would be really helpful.
Found one on aliexpress https://www.aliexpress.com/item/FOR-...806845296.html
$150. Wow. I will continue to use touchscreen.
