03-16-2019, 03:00 PM | #309 | |
Rep 565
03-25-2019, 09:32 PM | #310 |
Rep 57
Hi everyone,
Where can I get a safe link for eSys or BimmerCode to code my new 8.8 screen unit on my f32??? I bought the ethernet cable in Ebay, and now I need help with the coding. Please any information is greatly appreciated. Thanks! |
03-26-2019, 06:32 PM | #311 | |
Rep 1,325
The other option is to buy the cable which you have, which manually plugs into the same OBD port and then use your laptop. If you post in this thread https://f30.bimmerpost.com/forums/showthread.php?t=696777&page=655 I believe Shaun is very helpfully sending the links to people via PM. |
03-26-2019, 09:52 PM | #312 |
Rep 57
Hi everyone.
I recently swapped the 6" stock screen for the 8.8" one on my f32. Can someone please help me coding my new 8.8 screen unit on my f32? System turns on, but it shows no image. I bought the ethernet cable with the ODB adaptor in ebay. I downloaded the link app to my laptop (shawnsheridan sent it to me), but I don't know what I am doing wrong that when I connect the cable to the car it doesn't do anything. I don't think the laptop is connecting to the car. Can someone help me to code this screen step by step? Unfortunately, I am an amateur at coding. Or is someone willing to do it for a fee? Thanks! |
03-27-2019, 04:57 AM | #313 | |
Rep 1,325
03-27-2019, 08:46 AM | #314 | |
Rep 565
03-27-2019, 01:50 PM | #315 |
Rep 4
Hi all
I'm looking to upgrade to a 8.8 and have no idea what nav I got. I got a 64 plate f30. I have bimmercode and obd reader could I find out from that if not my last 7 digits of my vin number is K282619 if anyone could help that's would be great! Thanks in advance. |
03-27-2019, 02:19 PM | #316 |
Rep 1,325
03-27-2019, 06:07 PM | #317 | |
Rep 565
https://f30.bimmerpost.com/forums/sh....php?t=1312102 https://f30.bimmerpost.com/forums/sh....php?t=1350558 |
03-28-2019, 07:58 AM | #318 | |
Rep 1,325
03-30-2019, 05:44 AM | #319 |
Rep 3
Does anyone have a guide on how to physically change the screen ? Kudos to all that have took the time to reply to everyone’s messages and provided links , advice etc you’re all decent spuds
03-30-2019, 08:50 AM | #320 | |
Rep 565
Just watch these parts: - 00:00-01:47 (remove the trim) - 05:15 afterwards (disconnect old screen and connect new one) Ignore everything that has to do with the head unit or cable switching. Last edited by MarkoSK; 05-16-2019 at 05:31 PM.. |
04-01-2019, 09:05 PM | #321 | |
Rep 245
S606A Navigation System Radio S654A DAB Tuner S698A AreaCode 2 For DVD S6ACA INTELLIGENTER NOTRUF S6AEA TELESERVICES S6NHA FREISPRECHEIN M USBSCHNITTSTELLE |
04-02-2019, 12:53 AM | #322 | ||
Rep 4
04-02-2019, 07:36 AM | #323 | |
Rep 565
Anyway you should have the HU_ENTRYNAV head unit and you can retrofit a larger screen (8.8" or even 10.25"). |
04-02-2019, 07:58 AM | #324 | ||
Rep 4
04-03-2019, 09:34 AM | #325 | |
Rep 407
04-04-2019, 06:12 PM | #326 | |
Rep 565
You can retrofit one of these two screens, the only difference is the older pre-LCI one has a blueish tint. And as cdwalls noted, a 10.25" screen will work but it won't fit without cutting the dash or screen. |
04-07-2019, 12:30 PM | #327 |
Rep 2
Hello,
I am writing here because I am not sure about the choice of the 8.8 screen. I want to change my 6,5 to a 8.8. My car : BMW F30 318d business (with navigation) of may 2014. My choice seems to be between 9292248 -> pre-LCI screen 9387453 -> LCI screen But I don’t really know if I have the HU_ENTRYNAV. I checked with bimmercode App and I saw HU_NBT instead of HU_ENTRYNAV. Here below some pictures of my idrive system and bimmercode app. Thank you for your help |
04-07-2019, 04:38 PM | #328 | |
Rep 565
EDIT: One user (domaxx) reported that his 06/2014 F30 with business nav did not work with the LCI screen, but worked okay with the pre-LCI screen: https://f30.bimmerpost.com/forums/sh...&postcount=275 https://f30.bimmerpost.com/forums/sh...&postcount=287 https://f30.bimmerpost.com/forums/sh...&postcount=289 So your best bet is to get the pre-LCI screen. Last edited by MarkoSK; 04-07-2019 at 04:46 PM.. |
04-07-2019, 07:33 PM | #329 |
Rep 4
I leased a 2018 330e recently but it doesn't have nav or CarPlay. This is the last 7 of the VIN: A756949
If I understand correctly, the only way to do CarPlay is by replacing the display unit. And the only way to do that is to be sure you have HU_ENTRYNAV, which is in the CPU. 1) Am I correct in understanding that? 2) And is it possible to know if I have that without buying and OBD adaptor to use with the BimmerCode app? 3) The other option is the Wireless CarPlay adaptor that I saw from Unique. I don't think that would require any "surgery" which might be better. Any help would be greatly appreciated Thanks! Bill |
04-09-2019, 01:18 AM | #330 |
Rep 67
Hi all,
I am writing here because 1) I want to check if it is possible at all to make a swap from my 6,6 screen to 8,8 2) If it is possible, which exactly 8,8 screen I need to look for? My car : BMW F30 320i LCI sport 2017 (w/o navigation). I don't have navigation however seems that I have HuEntry 2 since it has bluetooth and USB from the factory. I saw first posts in this topic and it was written that swap of 6,5 to 8,8 is impossible for HuEntry, but is it the same for HuEntry 2? If it is possible which screen I need to look for LCI HuEntry 2? Thanks a lot in advance, |
