03-20-2019, 08:30 AM | #67 | |
Rep 134
Thank You T and to the one above who's having a problem updating the HU_NBT, try update the NBT with your firewall OFF. happened to me back then, turns out that my firewall blocking the connection. Hope thiss help T
Instagram: @tafikhulafaa & @88tuning.id
03-20-2019, 10:10 AM | #68 |
Rep 40,765
PM sent.
88tuning.id38.50 |
03-22-2019, 05:11 PM | #70 |
Rep 40,765
04-10-2019, 02:52 PM | #72 |
Rep 40,765
You cannot Send or Receive PM's yet. Send me one when you can.
06-07-2019, 07:16 AM | #74 |
Rep 40,765
PM sent.
03-23-2020, 03:59 PM | #75 |
Rep 8
I have a problem with HU_NBT--63
when I want to code blue one I see this error: "Abort! <ECU "HU_NBT--63" of selected CAF not found. But it should have been added before. >" the red one HU_NBT2--63 I can not code and also when I click on "Detect CAF for SWE" there is an error: "Actual SVT has to contain at least one BTLD. [G093]" see picture: [IMG] https://ibb.co/3ygwDkr [/IMG] https://ibb.co/3ygwDkr Could you please tell me what should I do step by step? It happend when I changed in FA 853 to 8A1 and click on the ECU "code". It was a bad idea because after that there was a lot of errors. I fixed everything but I can not restore the red CAFD from the picture
BMW F30 335i 2015 Last edited by Cidaro; 03-23-2020 at 04:20 PM.. |
03-23-2020, 04:09 PM | #76 | |
Rep 40,765
03-23-2020, 04:23 PM | #77 |
Rep 8
the picture is here at the link:
BMW F30 335i 2015 |
03-23-2020, 04:28 PM | #78 | |
Rep 40,765
03-23-2020, 04:45 PM | #79 |
Rep 8
I have a backup of FA, so should I load a backup and after that click code at ECU's?
BMW F30 335i 2015 |
03-23-2020, 04:51 PM | #80 | |
Rep 40,765
If you code all ECU as you suggest, the motor better not be running. You cannot code DME / DDE with motor running.
03-23-2020, 05:18 PM | #81 |
Rep 8
I've just done that (load FA from backup -> ECUs "code") and everything came back to the factory like language, sidemarkers etc. but NBT2 is still in red like it was before :/ What else can I do?
BMW F30 335i 2015 |
03-23-2020, 05:29 PM | #82 |
Rep 40,765
NBT was in Blue. NBT2 was in Red. You do not have 2 head units in car. You do not have NBT2. Reset SVT and then Read ECU. Nothing should be in Red.
03-23-2020, 06:37 PM | #83 |
Rep 8
It's still in red :/ (Reset SVT --> Read ECU --> Calculate = HU_NBT2 in red)
picture/link: https://ibb.co/pZmW1mJ Maybe something is wrong with my first FA file which I saved in "Coding" Form. Now when I click on: VCM --> Master --> Write SVT --- I get an error: "The following ECUs have a wrong bus ID: [BaseVariant=HU_NBT, DiagAddress=63]. Do you want to write the SVT anyway? [C235]" picture/link with error: https://ibb.co/hMTy7tK
BMW F30 335i 2015 |
03-23-2020, 06:49 PM | #84 | |
Rep 40,765
03-23-2020, 07:06 PM | #85 |
Rep 8
If I click "Read ECU" then nothing is in red.
After that when I want to change for example radio frequency from us to eu HU_CIC / 3002 AUDIO_TUNER_TRAFFIC / RADIO_COUNTRY = ece (changed from US) / Werte=00 ANZEIGE_FREQ = nicht_aktiv / Werte=00 FM_DEEMPHASIS=50us (changed from 75) then "code" NBT everything seems to be loaded correctly with no errors but there is no effect... when I go again to FDL then evertything are not changed to EU. I can repeat that a few times with no effect. When I click "Read ECU" --> "Calculate" again I see NBT2 in red What am I doing wrong? Before the issue with changing FA --> "ECUs" --> "code" (result = a lot of errors) everything was fine and the radio was converted US to EU without any problems.
BMW F30 335i 2015 |
03-23-2020, 08:31 PM | #86 | |
Rep 40,765
03-24-2020, 03:36 AM | #87 |
Rep 8
Yesterday I didn't check it because it was 1:20AM so I was going home, but today I checked it and as always you have rigth
Thank you for your support!!!
BMW F30 335i 2015 |
03-24-2020, 07:42 AM | #88 |
Rep 40,765
