02-11-2019, 03:17 PM | #23 |
Rep 5
I like it...
This company (Injen) has been around since I started working on cars 20 years ago. I was a Honda guy before I could afford to be a bimmer guy. So I was happy to see they are making an intake for my 340i. I didn't see any for sale on extremes site. I'm looking to get this and an active 8 tune. Any idea when you will have them in stock? Also, it's a closed box in the pic, but I've seen them without the box elsewhere. Do you know if the closed box will make fun sounds?
02-11-2019, 03:34 PM | #24 | |
Rep 190,777
02-12-2019, 04:22 AM | #25 | |||
Rep 968
"it does x, y, and z" "JUST AS I SAID, USELESS" |
kern4174446.50 BMWiltshire63.00 |
02-12-2019, 10:47 AM | #26 |
Rep 446
looks kinda cute with that box
Mod bug will bite you if you buy a BMW ================================= |
03-12-2019, 03:59 PM | #27 |
Rep 190,777
Injen B58 intake officially released
Injen EVOLUTION Cold Air Intake System Part No. EVO1105 2016-2019 BMW 340i/440i (F3X) L6-3.0L(t) B58 Take the ultimate driving experience of your 2016-2019 BMW 340i/440i (F3X) series with the B58 engine to the next level of excitement with Injens EVO1105 Evolution cold air intake system. This intake was designed using the most up-to-date engineering tools and techniques available to produce a top quality kit that has no parallel. The EVO1105 cold air intake system is truly on the next level. From the one-piece sealed housing that utilizes our patent pending Twist-Lock technology to securely attach a massive SuperNano-Web Dry air filter in place all the way down to premium hardware, Injen has put it all on the board to provide you, the consumer, the best intake possible! Roto-molded Housing: The one-piece sealed housing utilizes the all-new Injen Twist-Lock System to securely attach the SuperNano-Web Dry air filter in place which eliminates the use of unnecessary parts and provides one of the simplest installations available. The EVO1105 housing also sports the all-new Injen Clear-View badge for a cleaner more aggressive under hood appearance. Roto-molded Intake Tube: The EVO1105 Evolution Air Intake System uses a custom designed and dyno-tuned, intake tube to produce huge power gains while retaining an OE quality fit. SuperNano-Web Dry Air Filter: Thats massive! is all you will hear about this SuperNano-Web Dry air filter that is included with the EVO1105 cold air intake system. This filter has been uniquely designed to work with the Injen Twist-Lock System. Using our Twist-Lock technology has allowed our engineers to use the largest filter possible for this application, which increases the available air volume - resulting in added power while keeping the installation process quick and simple. Quality Hardware: From the Stainless Steel Band Clamps with an inner protective liner to the reinforced automotive grade silicone coupler, every aspect is covered for a perfect and secure fit. Hassel-Free Installation: Make it easy! The Injen Evolution Air intakes that use our Twist-Lock System have been strategically designed to use fewer parts to provide the end user with one of the quickest and simplest installations available on the market today. Dyno Proven: Clean and simple, NUMBERS talk! Injen has put in the time and diligence to stand behind our performance data. We put in the time to test and prove that we have developed a superior kit for your BMW. So after hours of designing and dyno testing, Injen is proud to say that the EVO1105 Evolution Air Intake system puts down numbers of up to 13 additional horsepower and 18 lb-Ft. of torque. KEY FEATURE Dyno Proven gains of up to 13 hp and 18 ft-lbs. of torque Designed to work with the stock calibration Aggressive intake growl under acceleration Durable Roto-Molded Polyethylene tube and housing Reinforced automotive grade silicone couplers Fully serviceable Injen SuperNano-Web dry air filter Stainless steel band clamps with inner protective liner Aggressive under hood appearance while maintaining an OE fit Our clear inspection badge allows you to quickly check the condition of your air filter while the red stripe enhances under hood appearances. Made in Pomona California, USA Injen Technology Limited Lifetime Warranty This product is not currently CARB exempt and is not available for purchase in California or for use on any vehicle registered with the California Department of Motor Vehicles. Direct Fit for
HP GAINS 13 HP TORQUE GAINS 18 Ft.-Lbs. of Torque BOX SIZE 28" x 17" X 13"
01-10-2020, 12:47 AM | #28 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Is it possible this will fit a 2020 M40i B58?
01-12-2020, 11:44 PM | #30 |
Rep 299
hi all,
i actually have one of these on my car and posted a review on xhp or somewhere here. essentially i cannot tell the difference at all between stock in terms of performance and sound but thats probably because its a closed system? either way i thought i would benefit from having something reusable at the very least although a replacement panel filter in hindsight wouldve been the better option i think given the high cost. the item is very built with high quality plastic and is much cheaper than AFE's equivalent product. install was a little painful though and instructions not great being low res black and white print outs so yes, just an unbias owners review of the product. any criticisms would fairly apply to AFE or other equivalent designed kits.
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
