11-04-2020, 04:11 PM | #2 |
Rep 1,800
The physical replacement is easy, 15 mins each, tops. They pull out by hand.
Be extra careful with the fuel return clips on top. They can get fragile and break. Simply clean the bore if it's dirty, do not grind or anything invasive like that!!!! Original injector is lubed on the outside with some grease, you should do the same. Coding depends on what tools you have. It's as hard as typing in a few numbers and letters.
11-20-2020, 07:17 PM | #3 | |
Rep 412
Max |
11-21-2020, 01:13 PM | #4 |
Rep 1,800
It's basically a registering the new code that is inscribed on the injector body, into the engine ecu with BMW diagnosis software.
Usually you can use ISTA-D or even Tool32. Some mobile diag apps may do it too. |
11-21-2020, 05:31 PM | #5 | |
Rep 412
*EDIT* contacted BimmerLink support and this function is not supported Max Last edited by clemsonf31; 11-23-2020 at 03:54 AM.. |
06-04-2021, 11:56 PM | #6 | ||
Rep 420
05-17-2022, 10:15 AM | #7 |
Rep 424
Bumping this - Anyone find a tool that can register the new injector? I have a foxwell BMW scanner and it doesnt appear to be able to. Just got the 24BB00 for injector #1.
Thanks! |
05-17-2022, 11:23 AM | #8 | |
Rep 1,800
Run Tool32 program (as administrator) while correctly set up and connected to car: 1. File -> Load SGBD 2. Load D70BX7A0.prg (2b. Check your connection by running job "ident" with Start Job Once only button. Result should be an ID number) 3. Read current Injector coding with job "abgleich_ima_lesen" (located in the upper 1/3 of jobs. double click on it to run, or Start Job Once). To program 1 single cylinder's injector, use "job abgleich_programmieren_ima_zyl" In the arguments box type in IMA1 (for cyl 1) a ';' and then the injector code. Eg. IMA1;B123456 Click Start Job Once. It should say OKAY. Then repeat for any others changing the number after IMA if you have to change them. Turn off ignition for some time, 5-10 seconds, then use step 3 to read injector codes. To program all cylinders, use job "abgleich_programmieren_ima" and write in all 4 (or 6) codes in the arguments box in cylinder order 1;2;3;4;5;6 (front to back) and then push Start Job Once. It should say OKAY Ignition off for 5-10 seconds and then verify with Step 3. Clear all errors (job "fs_loeschen") and you're good to go. This can also done with INPA if set up correctly.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 05-17-2022 at 11:30 AM.. |
05-17-2022, 11:31 AM | #9 | |
Rep 424
05-17-2022, 11:40 AM | #10 |
Rep 1,800
Deep OBD app for Android has all the tool32 jobs ported in it. But I have never used it.
05-17-2022, 11:41 AM | #11 |
Rep 1,800
Bimmergeeks has a decent pack, or Mike's INPA pack, for these almost ready to go packs.
LKM_touring4.50 |
09-11-2022, 02:11 PM | #14 |
Rep 1,800
#1 is frontmost and #4 is rearmost, they simply go in order from there
LKM_touring4.50 |
