01-16-2021, 07:30 AM | #45 | |
Rep 1,105
01-16-2021, 03:37 PM | #46 | |
Rep 7,597
Is there a way to test app connectivity before you do the install? |
01-16-2021, 04:07 PM | #47 |
Rep 1,105
The sensor and the analyzer are visible in the engine bay. My first thought would be to install the new analyzer because it has the easiest access. The sensor is a little more involved but should not require removal of intake manifold. There is connectivity to the hardware using both android and iOS. This has me suspect that the sensor is faulty. :
01-18-2021, 01:51 PM | #48 | |
Rep 7,597
I was also asking because if i ever do HPFP + sensor, I would like to have to way to at least test connectivity before putting everything back together incase a situation like this isnt just a 1 off. |
01-26-2021, 03:26 PM | #49 |
Rep 1,105
Here's an update
Tried the new sensor and analyzer that spool sent but still same issue. The indy shop and spool spoke on the phone to see if there was a step missed and provided some tips. No luck resolving the issue. Spool is having me send back the equipment so they can test it and see whats happening although according to them everything is tested before being sent out. In the meantime im stuck paying for labor to reinstall the kit a second and a third time once spool figures out why the hardware is not working. I will say this much, spool was quick to respond with an initial resolution and sent the new sensor and analyzer quickly. They also offered to call the shop to speak with them directly. At this point I'm requesting a reimbursement for the additional labor hours to reinstall the first and future second replacement. Let's see how this plays out. |
01-26-2021, 05:05 PM | #50 |
Rep 55
I got this installed on my 2013 F30 N55 PWG FBO with Bigboost 3.3 and Port injection and satge 2 HPFP and Stage 2 LPFP and mine runs greats. I run usually E75-85 on 23 lbs of boost and never had any issues. Making well over 600 WHP. Easy install and the app is pretty accurate from when I got it dyno tuned with my shop and tuner at Stage FP in NC
02-09-2021, 09:22 PM | #51 | |
Rep 1,117
Hey man is your issue finally resolved? Who is the indy shop you're referring to? |
02-10-2021, 08:47 AM | #52 |
Rep 1,105
02-10-2021, 10:52 AM | #53 |
Rep 7,597
They are already out to my knowledge. I just dont think anyone has installed one of the two options for flex fuel yet.
02-10-2021, 09:44 PM | #54 |
Rep 1,117
05-24-2021, 01:22 PM | #55 | |
Rep 273
Having similar issues - get fuel temp but don't get E %
I'm targeting E50 and I put 9 gallons of E85 (and the rest 93) during my last fill up so I definitely have considerable ethanol content in the tank Spool was very responsive via email and they sent me a new Bluetooth analyzer. I just plugged that in and still getting the same behavior. I'm thinking they'll probably send me a new sensor and I'm not looking forward to tearing things apart again to install it. My only other thought is that maybe a wire on the harness got stretched or crushed during the install. When you got your replacement hardware did you try a new harness as part of your troubleshooting?
2009 335i AT xdrive E90 Sedan | Xhp Stage 3 | Custom Wedge Performance 93 octane tune | FBO + Inlets
05-24-2021, 02:11 PM | #56 | |
Rep 174
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
