12-30-2020, 07:49 AM | #2 |
Rep 886
wilbur_the_goose353.00 |
12-30-2020, 08:50 AM | #3 |
Rep 5,989
That would be the case in A mode. M mode means it's closed all the time. I don't think it's sensitive enough to detect COVID so I want it closed all the time. I tried turning on the AC by just pressing this button and it seemed to stay in M but it wasn't for a long trip and seems odd you have to do it that way. And no way to tell if it's staying closed when AC is off.
Rftech0.00 |
01-05-2021, 02:44 PM | #5 |
Rep 5,989
01-20-2021, 02:44 PM | #6 |
Rep 1,565
Also noted if you press it a 3rd time it just turns the light off...what is that doing?
Rather have fresh air all the time. There is a charcoal filter...COVID shouldn't be a problem driving down the road or even in traffic if the filter is doing its job.
2020 M340i: Dravit Grey Mettalic. Loaded.
01-20-2021, 02:51 PM | #7 |
Rep 16,060
Recirculate cools the car down faster, so it's useful in very hot weather, but it also results in higher CO2 and moisture content and less O2 in the cabin air, so you should only use it when you really need it.
01-20-2021, 03:04 PM | #8 |
Rep 5,989
That's fresh air, M light is recirculate and A is auto.
01-20-2021, 04:21 PM | #9 |
Rep 43
Its about memory settings attended to driver profiles and this driver profiles can also attended to key fobs. If your car has two drivers and drivers use different keys its normal. But you can switch them whatever you want. It memorizes the last adjustment.
Recirculation thing is different title. Auto mode decides according to weather condition. M mode means always closed. Lights off means always open. |
01-20-2021, 08:05 PM | #11 |
Rep 5,989
02-11-2022, 04:13 PM | #13 |
Rep 24
Have the same problem here with my F30 LCI.
AC is on and Manual on, all working fine for a few minutes, then automatically switches on Auto. This drives me nuts. I select again Manual, works fine for 3-5 minutes, then again switches automatically on Auto (22 Celsius degrees inside, 5 Celsius degrees outside). I flashed the car with the latest psdzdata (IHKA included), but no success in resolving this auto switching problem from Manual to Auto. I saw the problem on other forums also, but without any solution. Does anyone know if this can be coded somehow? Last edited by SharkGrogu; 02-11-2022 at 04:33 PM.. |
