01-20-2021, 05:07 PM | #1 |
Rep 117
N55 Chargepipe + Intercooler Question
Dumb question so please excuse my ignorance, but anyone know if there would be issues with buying a VSRF Intercooler and the ER Chargepipe upgrades?
Don't believe there would be but wanted to check if anyone had any issues buying interrelated parts from different brands. |
01-20-2021, 05:14 PM | #2 |
Rep 7,606
I think the only issue is with VRSF race and ER CP.
I would confirm with VRSF or Mike at XPH |
mike@x-ph.com24183.00 Kurt206147.50 |
01-20-2021, 08:05 PM | #3 |
No 55mph
1621
Rep 8,476
Personally I would not buy anything made by VRSF, there are many other mfg of fmic that are better for around same cost
You can't go wrong with ER though But I agree, contact Mike at XPH he will let you know the pros n cons
alohasurftoad3078.00 mike@x-ph.com24183.00 |
01-21-2021, 05:57 PM | #4 |
Rep 117
Much appreciated all! I went with a full ER setup for charge pipes and intercooler.
Since those are being replaced would it make sense to grab a GFB Diverter Valve? |
01-21-2021, 06:19 PM | #5 |
Rep 10,256
alohasurftoad3078.00 Kurt206147.50 |
01-21-2021, 06:28 PM | #6 | |
Rep 7,606
Also, i recommend researching the turbosmart option in addition to the GFB. There have been reports of the GFB needing maintenance over time. But in any case, the stock DV is usually fine unless it has a underlying problem. It hasn't been quantitatively demonstrated (to my knowledge) that it is an improvement over the stock DV for a FBO stock turbo car, although people do report improved throttle response/boost control. But lots of people meet boost targets just fine with the stock one, so i wouldn't consider it an essential upgrade assuming your stock one works fine. |
alohasurftoad3078.00 1QuikWS61620.50 |
01-21-2021, 08:00 PM | #7 |
Rep 820
Drives: Bmw 335i f30 N55 ( sold)
I have VRSF 5" HD intercooler with BMS charge pipe no issues!
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
01-22-2021, 08:21 AM | #8 |
No 55mph
1621
Rep 8,476
Another vote for Turbosmart over GFB
I started with the GFB, no problems over the short time I had it installed, just liked the TS design better once it came out so I swapped it in I would say that GFB or TS are not really a necessity if you are still on the stock turbo unless you have higher mileage on your car - stock valve is plastic & degrades over time TS does offer a sense of security if still stock but the install if DIY for either is a PITA - especially for AWD
alohasurftoad3078.00 |
01-22-2021, 10:46 AM | #9 | |
Rep 190,777
Evolution Racewerks quality is second to none, all their products and design and build in their facility in CA
01-22-2021, 03:40 PM | #10 | |
Rep 117
Will look into the Turbosmart option for sure, thanks! |
01-22-2021, 03:41 PM | #11 | |
Rep 117
Which option did you go with? I see two on the site: https://www.turbosmart.com/product/b...lumb-back-vr9/ https://www.turbosmart.com/product/b...dual-port-vr9/ Last edited by Kurt206; 01-22-2021 at 03:47 PM.. |
01-22-2021, 03:46 PM | #12 |
Rep 7,606
I'll be interested to see if your shop really doesn't charge extra labor for the DV install if they are already doing IC+CP+TIC. There's no doubt it adds significant extra time/work over those parts.
01-22-2021, 04:09 PM | #13 | |
No 55mph
1621
Rep 8,476
01-22-2021, 04:39 PM | #15 | |
Rep 7,606
Read the thread here, starting on page 8 and my post about 2/3 of the way down showing the gains. Inlet is a big upgrade in terms of throttle response and drivability, not to mention the overall improved airflow. Get the MST v2 if you go this route. https://f30.bimmerpost.com/forums/sh...1656337&page=8 |
