08-14-2019, 11:17 AM | #46 | |
Rep 2,302
Does your car had already the S2VBA or did you retrofit the RDC? To see the tire pressure and the temperature you need more codings. |
08-14-2019, 11:30 AM | #47 |
Rep 3
08-14-2019, 12:49 PM | #48 |
Rep 2,302
Check these settings ( some ecus will probably have a different name): FEM_01 > RemoteControl 30D0 > RC_RDC_ENABLE = aktiv ICMQL > Daten 3000 > IcmKod_B_S2VBA = verbaut DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RDCi_l = nicht_aktiv DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RPA_e = nicht_aktiv DSC_CT01 > DSC_CODIERDATEN_RPA_CONTI 3002 > C_RPA_Extra = nicht_aktiv HU_NBT > EXBOX 3001 > RDC = aktiv HU_NBT > EXBOX 3001 > RDC_DRUCK_TEMP = aktiv HU_NBT > EXBOX 3001 > RDC_FORTSCHRITTSANZEIGE = aktiv HU_NBT > EXBOX 3001 > REIFENUEBERWACHUNG_RDC_RPA = rdc HU_NBT > EXBOX 3001 > RPA = nicht_aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_ALIVE = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_TIMEOUT = aktiv KOMBI L7_MID > FZG_Ausstattung 3003 > DSC_MIT_RPA = ohne_RPA |
kalinamichael0.00 |
01-23-2021, 02:43 PM | #49 |
Rep 561
Would be nice if this question resolved. Did you look at the additional codings? What happened? Did you solve it? Thanks!
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport. |
12-19-2022, 07:49 AM | #50 |
Rep 263
Drives: 2006 Z4 M Roadster
resolved?
I have an e70 x5 as well with RDC. Did you ever resolve this?
The HU is CIC. It does not have the parameters: RDC_DRUCK_TEMP = aktiv or RDC_DRUCK_TEMP = druck_und_temperatur. What other parameters and/or modules should I check? Thanks.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
12-20-2022, 11:35 AM | #52 |
Rep 263
I have factory TPMS. VO has 2VB as one of the installed options. The RDC module is installed and comes up as RDC in the UIF in INPA, but RDCLC in NCSExpert. And I have the metal valve stems/TPMS units in the tires.
That should be all I need, correct?
12-20-2022, 02:50 PM | #53 |
Rep 15,964
It would seem so. I coded mine to show temperature as well as PSI with Bimmercode. It showed PSI already. If yours didn't from the get go something isn't right.
12-21-2022, 10:23 AM | #54 | |
Rep 263
Which module did you code for the temp and PSI? I checked through the HU CIC FSW_PSW.trc file and did not see an option for druck_and_temperatur
12-22-2022, 11:51 AM | #57 |
Rep 15,964
If you open Bimmercode and go to HU-NBT and there's no entry for Tire Pressure Control you don't have Direct TPMS, which is the system that supplies temperature and pressure readouts. If you don't have HU-NBT I can't say if you have Direct TPMS or not. I wouldn't assume that the valve stem material is definitive. My last car had metal valve stems, but not Direct TPMS. It had Indirect TPMS, which doesn't give a readout, only a warning if a tire goes low.
12-23-2022, 06:02 AM | #58 |
Rep 5,451
Drives: F30
