07-16-2020, 04:02 PM | #1299 |
Rep 1,010
Ok but that's compared to MPPSK.
On another note I also find that the M340i IAT quite high relative to the ambient temp in Ukraine of 25 Celsius at day and 15 at night.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
07-17-2020, 08:12 PM | #1300 |
Rep 312
Drives: 2019 x3 M40i
Just picked up 110 gallons of ~E33 mix I made the other day so I can have it on hand instead of random fillups from small cans. Gotta say, I'm happy with this pull
2019 X3 M40i ER catted DP MST intake VRSF charge pipe BM3 Stage 2 E30 with ~e33 fuel 4th gear pull - traffic prevented a 5th, and now its raining tonight https://www.bootmod3.net/log?id=5f11...90c66625c372d0
2019 X3 M40i - Phytonic Blue - MST Intake, VRSF Chargepipe, ER catted/coated DP, Dorch Stage 2 HPFP, BM3 stage 2+ e30, XHP stage 3, 275/40/20 Michelin MPS4
07-17-2020, 09:03 PM | #1301 |
Rep 452
07-18-2020, 03:25 AM | #1302 | |
Rep 1,010
You are welcome mate it's nice to see B58 Gen2 logs and compare it to Gen1, I actually asked if anybody has logs in the M340i Forum and they didn't have any idea what I was talking about
Also if you got a Dragy and did some runs you can post them in this thread: https://f30.bimmerpost.com/forums/sh....php?t=1621233 Quote:
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 07-18-2020 at 07:45 AM.. |
07-18-2020, 10:46 AM | #1304 |
Rep 1,010
24 PSI is a lot of boost, check your charge air temp it would definitely be very high.
07-18-2020, 10:48 PM | #1305 |
Rep 585
Here's the log from a 7.02s 100 - 200 run using the MHD Stage2+HPFP and E42 fuel, Dorch Stage 2 HPFP.
Tiny bit of timing delta for knock adapt and minor corrections. Certainly goes well and Virtual Dyno says 509 WHP 60 - 130 mph was 8.25s https://datazap.me/u/ozbmr/ozbmr-mhd...25-26-27-28-39
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
07-19-2020, 03:56 AM | #1306 |
Rep 281
Morning all. Reading through all the pages it seems that us chaps in the UK who don’t have access to e85 are using boostane professional. Is this safe for our engines I am thinking of getting some to take our 99 Ron (us 94) to 101Ron (us 96) just to help with timing etc when running the 93 tune.
07-19-2020, 09:59 AM | #1307 |
Rep 164
Hey, do you guys mind taking at peak at my log. This is the OTS stage 2 93oct hmd map. I do plan to get a tune soon, but I just wanted to get a feel for how the car is running as of now. Thanks
https://datazap.me/u/devil-doc/m240i...37-38-39-40-44 |
07-19-2020, 01:25 PM | #1308 |
Rep 312
I've been slightly concerned with the amount of whooshing I'm hearing from the front of the car under part load, and got a 5th gear log finally on my e30 map and noticed the MAP is not keeping pace with boost target or pre throttle. Suggesting leak?
https://www.bootmod3.net/log?id=5f12...0b432a4784ebec |
07-19-2020, 01:56 PM | #1309 | |
Rep 69
[QUOTE=N420i;26440900]
I ran the ACN 91 map for a while. Timings aren't so different from the 91 or 93 maps, the car is only much slower but the exhaust burbles are much louder ?! I have no idea how people get that timing correct. Maybe I need another car lol (Also I have a strange whining noise coming from the back at higher speeds, I don't hope it's in my xdrive drivetrain |
07-19-2020, 02:09 PM | #1310 | |
Rep 192
[QUOTE=340iNL;26457648]
07-19-2020, 06:17 PM | #1312 | |
Rep 585
Spark plugs may need to be replaced more regularly with continuous Boostane use also.
07-19-2020, 06:20 PM | #1313 | |
Rep 585
Getting up to 11 - 14 degrees of timing over 6000 RPM, just could be a bit better and more even between cylinders.
07-19-2020, 06:50 PM | #1314 | |
Rep 585
MAP (TMAP at manifold) and Boost Pre-throttle use separate sensors and are scaled differently as one is 2.5 bar and the other 3.5 bar. Up to about 0.6 PSI difference is normal.
07-19-2020, 06:59 PM | #1315 | |
Rep 281
Thanks. How much e85 is required to make an improvement I can get 19l drums of renegade pro e85 for £60. If I could get away with 6.3 litres to a tank so it lasts three tanks that would be feasible. Fuel here comes regulated to e5 so by my calc I would end up with roughly e13.5 including the base e5. Is that enough to help with corrections etc.
07-19-2020, 07:08 PM | #1316 | |
Rep 1,239
07-19-2020, 07:12 PM | #1317 |
Rep 281
I don’t want to go to an e85 specific map just help improve corrections on a 93 tune. My last logs on v power timing was all over the place just filled up with momentum 99 today see if that helps but if 1.5gals of e85 will help do what I need I will buy some. Only works out an extra tenner a tank of the 6.3 litres will be enough. Much more than that and you are right things get very expensive.
07-19-2020, 10:07 PM | #1318 |
Rep 30
Hi,
Looking for feedback on my log. 2016 340xi AA catted downpipe stage 2 91 I have “not high grade” 93 octane. I was running stage 1 93, but noticed some knock detects, so I swapped in 91 tune for stage 2, but still see knocks. I’m still trying to learn the logs. I think the timing doesn’t look great? Maybe new plugs would help? Should I run the colder/gapped ones I see comments about? I have 40k on the odo. Thanks! https://www.bootmod3.net/log?id=5f14...0b43706d8b4762 |
07-19-2020, 10:28 PM | #1319 | |
Rep 585
It'll clean up your timing on a 93 octane map, make more power and may even go OK with the 102RON/95 octane maps, as the base fuel for the Renegade product is a higher spec petroleum, so overall octane will be 94 - 95. Let us know how it goes if you try it.
07-19-2020, 10:33 PM | #1320 | |
Rep 164
