BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Finally added Speed Limit Info
      04-08-2021, 10:00 AM   #617
Siki78
Siki78's Avatar
136
Drives: F30,G30
for bmw speed Limit Information SLI Emulator for BMW NBT Retrofit NBT F3/F5/F7/X5/x6
https://a.aliexpress.com/_msT8lC7
I buy this one km\h and it‘s working on f20 for a one year
      04-13-2021, 04:31 AM   #618
raphaelpais
Portugal
Drives: F20 116i
2012 BMW 116i  [0.00]
Originally Posted by MHF30 View Post
Thank You for confirming this, went though all 26 pages in advance of this looking for confirmation lol. Can you post the link one the one you bought?
I use the same as Siki78 posted =)
      04-15-2021, 01:28 PM   #619
drdino
drdino's Avatar
135
Drives: BMW 330i
2019 BMW 330i  [0.00]
Got a bimmer8 SLI module installed. Does anyone have a list of confirmed parameters that need configuring on an ID6 + 6WB + HUD vehicle? The list of parameters that are on the ebay listing is a bit hit and miss... Some of the parameters are not available, others mentioned in the G-series section are present on my kombi etc...
      04-15-2021, 11:35 PM   #620
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Did u try the coding mentioned in bimmer8 ebay page? Those parameters worked fine for me and yes, I have ID6+6WB+HUD.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      04-16-2021, 02:29 AM   #621
drdino
drdino's Avatar
135
Drives: BMW 330i
I didn't try them, I was a bit apprehensive as I couldn't find everything, but I'll give it a go.
      04-16-2021, 03:02 AM   #622
Siki78
Siki78's Avatar
136
Drives: F30,G30
There is all what you need
【F Series】
ANZEIGE_NPI = aktiv
KI_PIA_SPEED_LIMIT = aktiv
SPEED_LIMIT = aktiv
SPEED_LIMIT_GENERATION = sli_gen_2_npi
RCOG_TRSG_APPL = aktiv
RCOG_TRSG_TIMEOUT = aktiv
【G Series】
ADDITIONAL_SIGN_ENABLE = aktiv
ANZEIGE_NPI = aktiv
CB_TACHOZEIGERBAND = aktiv
CB_SLI_NPI = aktiv
PIA_SLI_NPI = aktiv
SLI_PERMANENT_ENABLE = aktiv
SPEED_LIMIT_ENABLE = sli
TACHOZEIGERBAND_ENABLE = aktiv
NO_PASSING_ENABLE = aktiv
SPEED_LIMIT_UNIT_ENABLE = Wert_02 ( *If you dont want to display the speed unit kmh or mph, please set Wert_0 )
* If your vehicle have HUD (Head-Up Display) , ignore this if not applicable
HUD_NPI_ENABLE = aktiv
HUD_PIA_SPEED_LIM = aktiv
HUD_SPEED_LIMIT_ENABLE = aktiv
HUD_SLI_ENABLE = aktiv
PIA_HUD_SLI = aktiv
PIA_HUD_SLI_NPI = aktiv
PIA_HUD_SLI_PORTIERUNG = aktiv
PIA_HUD_VSLI = aktiv
HUD_PIA_SLI = aktiv
HUD_PIA_NPI = aktiv
Coding to be modified for HU_NBT or HU_NBT2
SPEEDLIMIT_INFO = aktiv
SLI_NAVI_DISPLAY = nicht_aktiv
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      04-16-2021, 03:11 AM   #623
drdino
drdino's Avatar
135
Drives: BMW 330i
I have that, but for example I couldn't find the config parameters "ANZEIGE_NPI" or "SPEED_LIMIT" in the DKOMBI.
      04-16-2021, 03:19 AM   #624
Siki78
Siki78's Avatar
136
Drives: F30,G30
I find this two in kombi and I added them was diferent writing
HUD_PIA_SLI = aktiv
HUD_PIA_NPI = aktiv
It is not all there because it is mix between 6wa and 6wb but ANZEIGE_NPI and SPEED_LIMIT should be there
drdino135.00
      04-16-2021, 03:24 AM   #625
drdino
drdino's Avatar
135
Drives: BMW 330i
Thanks for the info, I will take another look.
      04-16-2021, 03:27 AM   #626
Siki78
Siki78's Avatar
136
Drives: F30,G30
Or give me you cafd from dkombi that I can look there
      04-16-2021, 04:12 AM   #627
Siki78
Siki78's Avatar
136
Drives: F30,G30
I check right now and no ANZEIGE_NPI and SPEED_LIMIT in cafd_00001060.caf.008_000_020 but you have
drdino135.00
      04-16-2021, 04:29 AM   #628
drdino
drdino's Avatar
135
Drives: BMW 330i
Yeap, looking at my notes these are the ones I could find on the DKOMBI. Interestingly enough, KI_PIA_SPEED_LIMIT was already at aktiv.
      04-18-2021, 07:28 AM   #629
drdino
drdino's Avatar
135
Drives: BMW 330i
Success!
x-m4n148.00
      04-18-2021, 07:54 AM   #630
freespirit
freespirit's Avatar
83
Success!
Enjoy
      04-26-2021, 01:09 PM   #631
Johnkwick
Drives: F10 LCI
hi,
how to make sure that navdata around my area has embedded SLI in it? I have BMW Southeast Asia NEXT 2020
Thanks
      04-26-2021, 06:01 PM   #632
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Originally Posted by Johnkwick View Post
hi,
Thanks
Honestly, you can’t. So install the adapter and see what happens, or ask someone who has one locally if it works for them.
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
      04-27-2021, 01:46 AM   #633
x-m4n
x-m4n's Avatar
Drives: Gran Turismo (F34)
Bimmer8 has a table showing supported countries here:
https://bimmer8.com/products/bmw-spe...module?lang=en
      04-28-2021, 11:30 AM   #634
apollo
Drives: F82 Sakhir Orange
Anyone installed one of these along side a ghost immobiliser? Fitted one today and speed limit works fine on dash, cant get it working on HUD and Ghost also seems messed up as can no longer deactivated it with this installed.
      04-28-2021, 03:50 PM   #635
Burniksapwet
Burniksapwet's Avatar
Drives: Bmw 540i
【F Series】
ANZEIGE_NPI = aktiv
SPEED_LIMIT = aktiv
【G Series】
ANZEIGE_NPI = aktiv
CB_SLI_NPI = aktiv
PIA_SLI_NPI = aktiv
PIA_HUD_SLI = aktiv
HUD_PIA_SLI = aktiv
HUD_PIA_NPI = aktiv
I only turned on two on my and it was fine. What are all this other extras for? Can someone please elaborate? Thank you.
      05-08-2021, 03:37 PM   #636
dimooon85
Drives: F20
Hey! how did you get the gear number to be displayed on the dashboard? (D8)
      05-09-2021, 10:25 AM   #637
Kolianovskyi
Drives: BMW 650i
XHP flash. I believe.
So, I tried several boxes and can say, some boxes have a problem if there is no data for a particular street they show 150)))). I have found a box that shows - - - then. This is pretty good.
Be aware.
      05-12-2021, 08:53 PM   #638
taarobaap
taarobaap's Avatar
Drives: 2017 BMW 340i
Originally Posted by rimlaban7 View Post
Would love to see how this is done too!
Same-would love to know how to do this!
'17 BMW 340i
