02-10-2015, 01:14 AM | #45 |
Rep 16
Hi guys,
Just to follow up on my problem I had. Just got an Android 5.0 lollipop upgrade to my phone and It has started to work fine for my Samsung Galaxy S5 with usb cable. I do not need snapin adapter. I have only identified one problem, I have no sound when playing audiofiles thourhg the player in BMW apps. Anyone has any clue what it can be? Everything else works fine.
//Bojan |
04-15-2015, 05:45 PM | #46 | |
Rep 1
Hi shawnsheridan, Could you please share with me by MP your source to get a 9C FSC? Also, do you know if there is a step by step guideline to retrofit the 6NR BMW apps? Thanks in advance! |
04-15-2015, 05:53 PM | #47 | |
Rep 40,903
There is no Tutorial, but the steps are: 1) Add 6NR to FA 2) Import and Activate FSC Code 3) VO Code Head Unit / Combox for 6NR
01-09-2016, 01:45 AM | #48 | |
Rep 4
Only one thing. I bought the '' FSC lifetime "by a Canadian site with which I updated my navigation maps. Is the FSC that I have the same i can import and Activatein the VO Code Head Unit / Combox for 6NR ? |
01-09-2016, 01:58 AM | #49 | |
Rep 40,903
Yes, VO Code HU_CIC and CMB_MEDIA with 6NR in FA.
03-20-2016, 12:29 PM | #50 | |
Rep 66
Abort! Asynchrone programming failed! [C049] task extension configuration missing in container - maybe the template is too old [1906] |
03-20-2016, 12:36 PM | #51 |
Rep 40,903
If you are using 58.x PSdZData, you must also use E-Sys 3.27.1.
03-20-2016, 01:05 PM | #53 |
Rep 66
Ok, now It went thru, however I got a lot of errors during ecu coding, I have a RPA and some traction error messages on screen, I just turn it off for a while turn back on and everything backs to normal, I added 6NR but I have no apps on Connected drive menu, do I need the FSC to get it? I'm doing this on my F23 01/15 production date.
03-20-2016, 01:07 PM | #54 | |
Rep 40,903
04-05-2016, 04:04 PM | #55 | |
Rep 9
Can you send me your contact of where I can get the 9C FSC Codes please. Thanks in advance. |
04-05-2016, 04:09 PM | #56 |
Rep 40,903
PM sent.
04-11-2016, 02:53 PM | #57 |
Rep 11
I've read the thread and i'm a little confused on the terminology.
Can you please let me know what the following stands for in relation to the coding process: VO FSC FA Also, am I right in thinking I can't activate the 6NR apps as I have only the following: S676A HiFi speaker system S696A DVD changer S698A DVD Area-Code 2 for DVD S6AAA BMW TeleServices S6ABA Control for Teleservices S6NFA Music interface for Smartphone S6NKA Link for Bluetooth and USB device I have a CIC unit (non-navigation) along with the combox, stock 6.6' screen + iDrive controller and the DVD changer is in the trunk not the glovebox. F30 built 04/2012 Ultimately I would like online connectivity and video functionality (plus a bigger screen). Last edited by Bowen151; 04-11-2016 at 03:02 PM.. |
04-11-2016, 05:07 PM | #58 | |
Rep 40,903
FSC = Freischaltcode (Enabling code) FA = Fahrzeugauftrag (Vehicle Order) I think you have CHAMP2 Head Unit, so you could not have 6NR BMW Apps. If you PM me your short VIN, I can confirm it.
04-12-2016, 08:13 AM | #60 |
Rep 40,903
You have HU ENTRY head unit. You cannot have BMW Apps.
04-12-2016, 08:50 AM | #61 |
Rep 11
Thanks very much for taking the time.
So am I right in saying a retrofit to NBT with nav and a larger screen should give me what I want? Or at least give me the hardware I need to activate BMW apps? (along with the video playback) |
04-12-2016, 09:28 AM | #62 |
Rep 40,903
Correct.
04-30-2016, 01:59 PM | #63 |
Rep 8
regarding bmw apps - I have used an iphone 4s for a long time with my f01 with apps - however after I reset the phone (wanted to delete everything on it) I cannot make it work with bmw connected and apps.
I have an Ipad air (same os and same version of BMW connected) which works perfect. Have any of you had the same problem or have I forgot something after the reset to make it work with the APPS? Thanks Mogens Last edited by mjuhl2003; 04-30-2016 at 02:25 PM.. |
07-02-2016, 01:42 AM | #64 | |
Rep 2
Should i write updated FA (with 6NR option) to the car? Will it cause any issues when dealer decide to make sw update? Thanks. |
07-02-2016, 03:39 AM | #65 |
Rep 40,903
If 6NR was valid factory Option for car's Build Date, and car has all required hardware, then it should not be any issue.
07-05-2016, 12:43 PM | #66 |
Rep 2
