BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > NBT retrofit quick question!
      03-25-2022, 07:13 PM   #1
robertst
Drives: F20 120d, F30 335i
Hi guys,
I am going to try to retrofit a nbt evo unit from an entry basis.
I do not have a combox(so no mic or antennas). For the antennas I will pick some aftermarket ones(and place them in the dashboard), and for the mic I will man up and cut the headliner.
I've also managed to find a pdf with the nbt quadlock pinout. However, I couldn't find one for the entry basis.
I am wondering if my current quadlock will be wired correctly for the nbt unit. I guess not, but if someone could tell me for sure and also give me an example of a quad adapter that would do the trick it would be much appreciated
:help
Many thanks in advance!
      03-27-2022, 08:14 AM   #2
kubax86
kubax86's Avatar
Drives: M2
Originally Posted by robertst View Post
Hi guys,
:help
You should be good with quadlock wiring.
All wiring you can check on newtis as well
      03-28-2022, 02:07 PM   #3
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Unless you buy an Evo with GPS plug, you will need an ATM emulator to allow a GPS antenna to be connected.
I suspect you have the Mic wired in already but you will need to add a BT antenna.
The rest of the wiring should be fine.
The EVO will need to be coded to your VIN or it will go into Component Protection when connected to your vehicle.
      03-28-2022, 02:11 PM   #4
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
if anyone interested i have NBT EVO with GPS port for sale. can precode it for your VIN.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
nbt, quadlock, retrofit, retrofit nbt
