12-18-2020, 12:20 PM | #1 |
Cheapskate
4450
Rep 4,993
Rotate the TU HPFP Connector **NO MORE MODDING THE WIRING HARNESS**
Made a video on how to rotate the TU HPFP connector. This way, there's no need to mod the wiring harness or add an extension, just plug it in the same as stock. Hope this helps.
Thanks to janea1207 for researching this |
dmanb2b2124.50 disintegrator66412.50 OzBMR574.50 IMS-340C394.50 TemjinX2520.50 chenry2357.50 lemonana3.00 AsianBill73.50 B58 _gran_coupe_638.50 |
12-19-2020, 09:21 PM | #3 |
Rep 17
I wonder if the depth of the piece you are removing and reinstalling, meaning how far you press it back on when you tap it back on, will affect the calibration if the pressure sensor.
12-25-2020, 05:48 AM | #5 |
Cheapskate
4450
Rep 4,993
The pressure sensor is on the fuel rail. This only monitors the pumps operation, i.e. the pison movement inside the pump. that's why it's so simple, kind of like a wheel speed sensor. It just monitors movement.
03-16-2021, 02:18 AM | #6 |
Rep 1,454
Just did this, thanks for the video. I had to use a hammer on my flathead to get it underneath initially. A couple flick of the wrists later and it was off and I was able to rotate it. You're the man.
2022 CT4-V Blackwing 6-speed
kern4174449.50 |
06-03-2022, 09:03 PM | #7 |
Rep 2
Drives: Bmw 340i
B58tu pump scratched from connector rotation
I was popping my connector off from the hpfp and I went a little too hard with the flat head and scratched the inside of where the connectors slides on. I'm a bit anxious because I'm not sure if I damaged anything. I put the connector back on and I will install it soon. Hopefully nothing major happens.
06-05-2022, 06:24 AM | #9 |
DisplacementReplacement
409
Rep 1,101
I guess in this case you won't know until you try. Good luck with it.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
emersonmjvr0.00 |
06-11-2022, 04:03 PM | #10 |
Rep 2
Drives: Bmw 340i
