BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Rotate the TU HPFP Connector **NO MORE MODDING THE WIRING HARNESS**
Studio RSR
      12-18-2020, 12:20 PM   #1
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
Made a video on how to rotate the TU HPFP connector. This way, there's no need to mod the wiring harness or add an extension, just plug it in the same as stock. Hope this helps.
Thanks to janea1207 for researching this
Youtube/Instagram/TikTok: @kern417
Appreciate 9
      12-19-2020, 07:27 AM   #2
MTWO
Drives: M2
Respect for doing the vids thank you!
kern4174449.50
      12-19-2020, 09:21 PM   #3
MarioG
Drives: 2015 M235i Xdrive
I wonder if the depth of the piece you are removing and reinstalling, meaning how far you press it back on when you tap it back on, will affect the calibration if the pressure sensor.
      12-20-2020, 04:05 AM   #4
T_H_O_M_A_S
Drives: M140i
its closed loop so it doesnt matter
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
kern4174449.50
      12-25-2020, 05:48 AM   #5
kern417
Cheapskate
4450
The pressure sensor is on the fuel rail. This only monitors the pumps operation, i.e. the pison movement inside the pump. that's why it's so simple, kind of like a wheel speed sensor. It just monitors movement.
      03-16-2021, 02:18 AM   #6
G.Newt
Drives: CT4-V Blackwing 6MT
Just did this, thanks for the video. I had to use a hammer on my flathead to get it underneath initially. A couple flick of the wrists later and it was off and I was able to rotate it. You're the man.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
kern4174449.50
      06-03-2022, 09:03 PM   #7
emersonmjvr
Drives: Bmw 340i
2018 BMW 340i   [0.00]
Exclamation B58tu pump scratched from connector rotation
I was popping my connector off from the hpfp and I went a little too hard with the flat head and scratched the inside of where the connectors slides on. I'm a bit anxious because I'm not sure if I damaged anything. I put the connector back on and I will install it soon. Hopefully nothing major happens.
      06-04-2022, 04:24 PM   #8
lemonana
Australia
Drives: 340i x328i Q7TDI
Done it 2 weeks ago, can confirm it's a 3mins easy job
      06-05-2022, 06:24 AM   #9
Jnat
DisplacementReplacement
Jnat's Avatar
409
Drives: 2020 X3M
I guess in this case you won't know until you try. Good luck with it.
2020 X3M /// MHD Tune
Prior Bimmers
2017 240XI Hybrid / FBO / MHD E40
2015 235XI FBO / MHD E30
2009 335XI FBO / COBB / E30
      06-11-2022, 04:03 PM   #10
emersonmjvr
Drives: Bmw 340i
Yup just connected it to my 340 and it worked!
It was a pain to get the fuel line back on but I managed to make it fit.
