04-29-2022, 01:09 PM | #67 |
DisplacementReplacement
409
Rep 1,101
It's interesting when i did add more ethanol to the 95 map it did help but it also gave me a lean code which i don't love....
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
04-29-2022, 01:24 PM | #68 |
Rep 1,010
This is strange even if you added 3 gallons it's on E21, I tried Stage 2 95 with E30 mix and it worked fine no codes.
Does your fuel already contain Ethanol ? but yeah don't run it with a lean code. P.S. I read that Boostane also messes up with the cat and O2 sensors.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 04-29-2022 at 01:34 PM.. |
04-29-2022, 04:12 PM | #69 | |
409
Rep 1,101
I'm running a CTS cat (not that expensive, worst case i'll replace it). 02's yep, i've read that... The reality, i accepted a looong time ago i have a problem and that problem is i like to mod cars and therefore there are risks... I've read it's a good additive to use with ethanol, acts as a conditioner for the fuel, who knows. I do know that it has a positive impact on knock and misfires. Bottom line is it works and IF it offers some protection from more expensive repairs due to knock for instance, play on!!!
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 Last edited by Jnat; 04-29-2022 at 04:19 PM.. |
04-29-2022, 04:31 PM | #70 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
eluded3041.50 |
04-29-2022, 10:56 PM | #71 | |
Rep 97
04-29-2022, 11:17 PM | #72 |
Rep 1,010
MHD HPFP E map is E40.
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
04-29-2022, 11:21 PM | #73 |
Rep 1,010
04-30-2022, 12:07 AM | #76 |
Rep 1,010
BMW says it can be used and that's the only fuel I got here.
04-30-2022, 09:12 AM | #77 |
409
Rep 1,101
I do sometimes along with the 95 oct maps both Hpfp and reg stg 2's... Just experimenting...
04-30-2022, 04:35 PM | #78 |
Rep 1,010
What's the highest boost anybody saw on stock Turbo ?
04-30-2022, 04:43 PM | #79 |
Rep 1,457
Local guy was boosting about 22 psi on a stock turbo before it popped and threw a ton of metal inside his intake manifold and motor.
2024 X3 M40i
2014 BMW M5 |
04-30-2022, 05:21 PM | #80 |
Rep 1,010
Oh that's scary.
04-30-2022, 06:08 PM | #81 |
Rep 1,457
Yeah unfortunately his engine was toasted after that. It had a rough idle from the metal making it's way inside the engine. They had to replace it with a used one and it was not covered under warranty.
2024 X3 M40i
2014 BMW M5 |
05-01-2022, 02:49 AM | #82 |
2JZ-GTE
3042
Rep 3,996
On 87 octane ?
05-01-2022, 03:24 AM | #83 | ||
Rep 3,876
I found it scary when I saw the log…
05-01-2022, 03:31 AM | #84 |
Rep 1,010
05-01-2022, 03:35 AM | #85 |
Rep 1,010
Yeah both MHD and BM3 HPFP maps produce around 20-21 psi.
We always knew the risk of frying a turbo but turbo shattering into the engine is next level scary.
05-01-2022, 03:37 AM | #86 |
Rep 3,876
That's a well known failure condition by turbos. With clearly catastrophic consequences.
05-01-2022, 03:40 AM | #87 |
Rep 1,454
I just looked at my old BM3 Stage 2+ E30 map datalog. It definitely hit 23-24 psi at times. I ran that for nearly a year with little issue.
IMS-340C394.50 |
05-01-2022, 03:50 AM | #88 |
Rep 1,010
Never heard of a turbo shattering and making it's way into the engine before.
