BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > BM3 v.2.2 - Traction Control Issues Thread
Studio RSR
      02-20-2022, 09:09 PM   #133
leew102
Drives: F30 BMW 340i xdrive
Originally Posted by Wires View Post
Originally Posted by leew102 View Post
Same thing happened to me. It happens a lot in 1st gear pulls off an on ramp, and then it surges like anti lag.
It's like it's preemptively thinking you might spin, so it kicks in. I had it in 2nd gear as well.
Did you get an yellow traction control flickering lights when it happens? I didn't, which is leading me to believe it didn't actual lose grip even though it kicks into this mode.
Nope never. Dry road, full traction. Kinda exactly like you described. It's preemptively engaging thinking it's going to lose traction in situation where you wont lose traction. Sometimes is scary though when you need to merge quick from an on ramp onto the highway. Especially down here in NYC/CT area where your gaps to merge onto the highway are tight sometimes.
Wires1645.50
      02-21-2022, 11:15 AM   #134
leew102
Also will add, when this anti lag/tc control thing happens, after it surges, rpm continue to climb for a second even after lifting off the gas completely. I think there was a user who posted about the car accelerating even after lifting off the gas with BM3. I do feel like it happens more in d/comfort mode too.
      02-21-2022, 12:56 PM   #135
Wires
Drives: 2016 340i xDrive
That is actually just part of the BMW design. Revs climb slightly after getting off the gas (it's pretty short though, sub-1 second).
leew10283.00
      02-28-2022, 08:57 AM   #136
CrimsonMoonLight72
Drives: BMW 340i Xdrive
So I’m assuming most are still up in the air about the v2.3 maps? I’m still a bit hesitant to flash it. Still staying at v2.1 stage 1 93....I wish I had access to v2.1 stage 2 93 though as I have a high flow DP now. Maybe they will tweak v2.3 a bit?
      02-28-2022, 10:09 AM   #137
Red-i
Drives: 2018 340i
Maybe it's not perfect but tc works for me. Safer than when it was almost never coming on
      02-28-2022, 11:12 AM   #138
leew102
I did reflash stage 2+ a couple times and then reset adaptations which left a persistent drivetrain error. So did a final reflash of stg 2+ and did a reflash of xHP and it seems to behave better now.
      02-28-2022, 11:37 AM   #139
dmanb2b
Drives: G07, F97, F30, E90, E46, E30
Isn't 2.4 out or am I losing my mind?
      02-28-2022, 02:38 PM   #140
CrimsonMoonLight72
Ink...haven’t logged in for awhile
I hope it is
      02-28-2022, 04:23 PM   #141
Wires
Couple of them are at 2.4 (Ethanol maps, some 1.0 maps) but not all.
dmanb2b2124.50
      02-28-2022, 04:24 PM   #142
Wires
They work for me, it's just a couple of those quirks that would be nice to go away. I'd have no issues recommending those maps. It takes care of the car spinning which was the main reason for them.
      03-03-2022, 01:27 AM   #143
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
Drives: 440i Gran coupe F36
Does anyone have any info if they are in the process of releasing another update soon for the stage 1 91 octane? Like a polished 2.4 map?…
Wires1645.50
      06-10-2022, 12:29 PM   #144
Wires
I've logged a bunch of miles on the v2.3 version. For the most part, power delivery is spot on.
I did find that the invasive torque management when cornering on winter tires must have been slight wheel slip. Since the temps are warmer, and I have summer tires back on, it's only showed up when raining.
Wouldn't mind it to be a bit more polished on the torque management, but tolerable during those situations.
