BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > .022 spark plug gapping ngk
      06-06-2022, 07:26 PM   #1
Bxrger
Bxrger's Avatar
75
Drives: Bmw
About to do a spark plug swap of my old ones with the 94201 ngks, seen people have gapped them go .022 rather then .030 when they are running a tune, anyone got insight on this and if the gapping would be better for stage 2+ hpfp mhd on my 2016 340i, thank you!
Bxrger
      06-06-2022, 09:01 PM   #2
G.Newt
Drives: CT4-V Blackwing 6MT
OEM Champions at stock gap, 0.030" is what a lot of us do now. No timing corrections with upgraded turbo and E40 custom tune.
Stock gap is good for anything under like 850whp.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
Appreciate 6
B58557.50
Bxrger75.00
IMS-340C394.50
dmanb2b2124.50
kern4174449.50
      06-07-2022, 12:54 AM   #3
Jay5k
Jay5k's Avatar
88
Drives: 2017 BMW 340i
these ones? https://www.championiridiumplugs.com...um-spark-plug#
      06-07-2022, 09:18 AM   #4
B58
B58's Avatar
558
Drives: 922 Turbo
The Champions are already .030 out the box or they need slight adjusting? I read this on Rock Auto:
CHAMPION 9425 {12120040551, 12120041666} Iridium Info
with Cup Terminal; Gap 0.032 IN
      06-07-2022, 12:26 PM   #5
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
492
Drives: BMW 340i xDrive
What I'm doing as well.
      06-07-2022, 12:27 PM   #6
WrxToBeamerGuy
492
I had to adjust mine they were more like .031 - .032
      06-09-2022, 01:40 PM   #7
1slowb58
Drives: 340i xDrive Stage 3
Stage 3 here, car loves .022 94201
      07-31-2022, 06:29 AM   #8
Sleeper340i
Drives: BMW 340i
Does stock gap still apply to NGK plugs? Missed the champion plug part, and I need to install my new NGKs today. Was using NGK .022 previously
      07-31-2022, 07:52 AM   #9
johnung
Spark plugs themselves will tell you what to do. If you remove the old plugs and they look fine then replace them with the same plug and gap that was working well. There are plenty of photo articles and videos that explain how to look at spark plugs and "read" their condition.
There really isn't a spark plug "upgrade". If everything is running cleanly as designed by the engineers who created the engine, then there is nothing to be improved upon.
Wires1645.50
kern4174449.50
      07-31-2022, 01:30 PM   #10
cxmplex
Drives: 2018 340i GT
I run .022, no issues.
      07-31-2022, 06:16 PM   #11
talontdone
talontdone's Avatar
Drives: 2017 BMW 340Xi
I'm running .020 due to mainly running E85 and was running 0.022 on pump gas
17 BMW 340iX / DAW UF/ DS2 HPFP
      07-31-2022, 06:24 PM   #12
B58
B58's Avatar
558
Drives: 922 Turbo
I'm running .022" and everything is fine. Flex fuel tuned with a Pure 800. Tuner recommended .018" but I personally did not want to close that gap that small.
2024 X3 M40i
2014 BMW M5
      08-08-2022, 10:18 AM   #13
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
Stock Gap is 0.028-0.031. No need to adjust but worth double checking that they aren't outside of that.
Gapping is to reduce blowout and will burn less efficiently. Worst case scenario you damage the tip when adjusting it. That's why it's not recommended to mess with it. It'll run fine either way but a bigger gap is better if you can get away with it, which the B58 can for most setups.
Youtube/Instagram/TikTok: @kern417
johnung4528.00
      08-09-2022, 12:42 PM   #14
cxmplex
The only way you’re really going to damage the tip is if you try and narrow it while you have your feeler in. Beyond that, the tip never makes contact with anything.
With that being said, I think I’ll try the stock gap champions next spark plug change. The stock gap works fine for us Kern? With MHD hpfp maps?
      08-10-2022, 12:04 PM   #15
kern417
Cheapskate
4450
You're being very optimistic. Especially for people that use the old style gap tools. It's happened to several people unfortunately.
I'm running stock gap at over 600whp along with many others. The most I've seen is the Twisted Tuning A90 running 750whp, again with stock gap. Until you experience blowout, I wouldn't change anything.
      08-24-2022, 07:17 PM   #16
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
How do you know you're getting blow out vs timing corrections?
      08-24-2022, 07:29 PM   #17
B58
B58's Avatar
558
Drives: 922 Turbo
You sorta feel sudden cut-outs under WOT or almost like the car is choking out. Back in the days I felt mine more in the upper RPM range like at 5500+ rpm or so.
      08-24-2022, 09:54 PM   #18
435gc
435gc's Avatar
174
Anything visibly different in logs?
      08-26-2022, 08:05 AM   #19
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
I'm pretty sure this is what's happening to me. And backfiring out the exhaust. It shouldn't be but that's the exact symptoms. E50 it does exactly that around 4k.
I had the ngk 94201 at 0.022, car ran amazing. Tried 0.020 and no noticeable change. I'm wondering if they are too cold of a plug for E I was reading about that. It's probably something else though.
I found these which look rad but I don't think they work on the b-58. It be cool if we could get a set of these:
https://euroklasse.com/products/bmw-...el-spark-plugs
      08-26-2022, 09:01 AM   #20
B58
B58's Avatar
558
Drives: 922 Turbo
If it's back firing from the exhaust its probably a HPFP crash from a weak pump or too much ethanol. Usually spark plug blow outs from my experience don't do that and have a sudden choking symptom or cut-out without that loud backfire from the exhaust. Those spark plugs you posted are made for the N-Series and typically they can damage the coil plug. My best experience with spark plugs so far has been the NGK 94201 even compared to the Champion plugs.
