01-17-2020, 12:31 PM | #89 | |
1296
Rep 3,532
01-17-2020, 12:39 PM | #90 |
Rep 7,597
However i don't think it's this cut and dry. The valve will open even in comfort depending on throttle, engine load, etc. Basically, it will open and close depending on driving conditions, not just selection of comfort vs. sport/+. Unless maybe there is a specific way to code it like that? But the default behavior i have experienced with stock exhaust valve is as i described.
n55david1295.50 |
01-17-2020, 01:48 PM | #91 | |
1296
Rep 3,532
I have mine set through the bm3 flash to be open in sport, but its stock in everything else, so for the most part its closed when its not in sport because of how i drive.
01-17-2020, 01:54 PM | #92 |
Rep 221
Follow up, I found their youtube channel and watched their install video. The exhaust reuses the existing valve controller and wiring harness (with extension). So valve behavior should be same as stock.
01-17-2020, 02:04 PM | #94 | |
1296
Rep 3,532
There isnt any power to be gained by swapping it, just drone or maybe a little louder. My car is loud outside but so so inside because of how well they are sound insulated.
01-17-2020, 02:08 PM | #95 | ||
Rep 288
01-17-2020, 02:29 PM | #96 | |
Rep 1,467
Also i hate the stock mid pipe, i want a stainless one. I know it adds no performance but my stock midpipe is in 3 pieces now and dont feel like getting it rewelded.
01-17-2020, 02:58 PM | #97 | ||
Rep 288
01-17-2020, 03:02 PM | #98 |
1296
Rep 3,532
Thats so interesting to me, usually there is drone.
01-17-2020, 04:34 PM | #99 |
Rep 288
Same. But I haven't noticed any. I've been actually driving around in comfort but paddle mode because the burbles have just gotten too loud lol
01-17-2020, 05:55 PM | #100 |
1296
Rep 3,532
HAHAHAHA
01-18-2020, 10:55 PM | #101 |
Rep 1,934
It's quite subjective to say what's too much drone. However, the resonator's only job is to remove drone from the exhaust note. The muffler is there to reduce the bulk of volume. Fine-tune with a resonator. In that process the resonator can also reduce some volume, but that's not it's primary goal. When you remove it you are absolutely reintroducing drone into the cabin again. It may not be enough to bother you in particular, but it could be noticeable to some one else. It's there.
Even the stock system has a noticeable zone around 1300-1800 rpm. If you catch yourself cruising in that RPM range, there are few people who would not call that drone.
01-18-2020, 11:01 PM | #102 | |
Rep 288
01-19-2020, 10:15 AM | #103 | |
Rep 1,467
01-19-2020, 06:39 PM | #104 | ||
Rep 288
01-28-2020, 04:41 PM | #105 |
Rep 44
Anyone else can weigh in on if they are happy with their purchase? I'm debating to order or not. I already have a Fabspeed catted down pipe. I don't think an MPE is loud enough for me, so I am hoping this will fit the bill.
01-28-2020, 05:00 PM | #106 | |
1296
Rep 3,532
I do like how it sounds (Im catless obviously). I still have never heard my car from the outside though, other than at idle.
01-28-2020, 10:13 PM | #107 | ||
Rep 288
n55david1295.50 |
03-06-2020, 12:55 PM | #109 |
1296
Rep 3,532
Yes, the clamp thats used is garbage though.
03-06-2020, 01:00 PM | #110 |
Rep 1,467
Any suggestion on what clamp to use instead?
