10-23-2020, 02:44 PM | #1 |
Rep 78
435d xdrive staggered 1.1%
Hi peeps I recently well not exactly recently August to be exact picked up a 435d xdrive with staggered 225/35/20 275/30/20 tyres. I’ve been reading up on the 1% maximum tolerance and xdrive issues and mine come at 1.1%. Should I be concerned.
Sorry if I’ve posted this twice but no answer in the general forums. maybe someone in the UK like me could shed some light Thanks in advance |
10-23-2020, 02:52 PM | #2 |
Rep 8,509
Technically it's on the limit but it should be OK. That's a very staggered setup though - you might want to go for more of a F/R balance of tyre sizes next time to help dial-out any understeer.
ukbeemerboy462.00 |
10-23-2020, 02:55 PM | #3 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
10-23-2020, 03:48 PM | #4 |
Rep 78
Thanks for the info. I did wonder why when I got the car .I’ll change the fronts .. again cheers for the advice.
It’s my first BM and new to the xdrive .. |
10-23-2020, 04:11 PM | #5 |
Rep 337
Drives: F31 335D
10-24-2020, 01:50 AM | #6 |
Beemer Heaven
462
Rep 2,941
The fronts are right, it’s the rears I’d change as these are the wrong size.
Scott
10-24-2020, 07:42 AM | #7 |
Rep 724
You may need to double check the wheel sizes first, my car was bought with 225's on the fronts and 275's at the rear, and i later found out the wheel sizes were slightly wider than oem, which are usually 8J at the front and 8.5J at the rear, mine turned out to be 9J and 9.5J, i just changed the fronts to 235's which puts it under 1 and very good combination for the transfer box.
Out of interest where did you get your car ? |
10-26-2020, 06:25 AM | #8 | |
Rep 78
10-26-2020, 06:36 AM | #9 | |
Rep 78
10-26-2020, 03:18 PM | #10 |
Rep 724
Near Derby ?, i only asked, as you get many a garage that buy the cars standard then put all these kits on, i bought mine from one of these garages, which most of the time isn't a problem, they just don't always put exact copies size wise on the vehicles, and are probably very ignorant of some of the potential issues they could cause afterwards. you just don't realise this until you start reading lots of different stuff on this forum !!
10-26-2020, 05:32 PM | #11 | |
Rep 78
Going from a 2 litre Audi A5 to my first BM at 3 litre was mental. Straight onto the upgrades tho with it, full surround view, inc reverse camera which was a piece of piss to retrofit and easy to source parts. Also fitted the 6WB digi cluster I got that from Georgia so probably nicked to order.. Next is the park assist as I’ve got all the bits for about 150 quid believe it or not. Just sourced the rear brembro callipers cheap as the fronts were brembro but not painted and the rears were the normal ones, so that to do as well. After tinkering with the old A5 I realised SH Audi parts are a total rip off plus the component protection was a sod to get removed on ECU’s. The BM is a dream to FDL code with ESYS and parts dirt cheap; if you spend all evening on eBay looking for the underpriced bargains. Alloys to refurb but it’s coming together nicely. Keeps me out of trouble when home tinkering etc. Going back to when I purchased it, yea! your right they shove any shit on to get it sold but luckily enough there’s here to help me. I’m grateful for all the help |
10-27-2020, 08:30 AM | #12 | |
Rep 724
Sounds like you are having a lot of fun |
10-27-2020, 10:46 AM | #13 | ||
Rep 78
10-28-2020, 06:52 AM | #14 |
Rep 724
10-28-2020, 01:08 PM | #15 |
Rep 78
