BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > What is this noise.!!!
      08-17-2018, 10:42 PM   #1
cesarortiz23
cesarortiz23's Avatar
Drives: bmw m2 lci
You guys this noise is getting in my nerves
I took part the whole rotor
Brake pads cleaned the whole thing out grease on them everything make sure everything was tight the noise went away for about 4 days
And here we go again same noise
What the hell can it be
Please help
bmw m2
      08-17-2018, 10:44 PM   #2
obert
obert's Avatar
Drives: 2013 328i
Video is not working
      08-17-2018, 10:45 PM   #3
cesarortiz23
Drives: bmw m2 lci
It should be now
bmw m2
      08-17-2018, 10:47 PM   #4
cesarortiz23
Drives: bmw m2 lci
Check if it works now
bmw m2
      08-18-2018, 02:46 AM   #5
obert
obert's Avatar
Drives: 2013 328i
Is it happening while you press on the brakes? Like pumping them?
      08-18-2018, 03:18 AM   #6
cesarortiz23
Drives: bmw m2 lci
Only when I press the brakes
If I release the brakes
Noise gone
Do you think my rotors are warped ?
And I am not messing with the brakes like pumping them lol
That is just me stepping on the brakes like maybe 20 %
bmw m2
      08-18-2018, 08:37 AM   #7
obert
obert's Avatar
Drives: 2013 328i
This is just a guess. Could be your caliper making the noise. You press on it and it makes a noise. You release it and it stops. Just a guess.
      08-18-2018, 10:08 AM   #8
cesarortiz23
Drives: bmw m2 lci
It could be
Like I mentioned
I took apart the whole assembly even the rotor cleaned everything put it back together noise went away for like about a week now noise is back
It almost sounds like a spring sound of some sort
bmw m2
      08-18-2018, 11:11 AM   #9
obert
obert's Avatar
Drives: 2013 328i
I have not done breaks on my bmw yet but I know some use brake grease where the pads come in contact with the caliper or caliper pistons.
It is weird it went away and came back.
      08-18-2018, 11:13 AM   #10
cesarortiz23
Drives: bmw m2 lci
Yeah I put grease right there
bmw m2
      08-18-2018, 11:44 AM   #11
obert
obert's Avatar
Drives: 2013 328i
Sorry wish I could be more help!
Could just be a bad caliper. Good luck!
      08-19-2018, 08:56 PM   #12
cesarortiz23
Drives: bmw m2 lci
Any body else have a idea what this can be
Is driving me crazy
bmw m2
      08-20-2018, 11:17 AM   #13
cesarortiz23
Drives: bmw m2 lci
I swapped out the rotors from right to left left to right to see if the sound will now go o the opposite side that didn't help at all
Same exact sound same side
Rear driver side
Anyone have a clue what this can be?????
bmw m2
      08-20-2018, 11:30 AM   #14
rak299
Drives: 2021 M3 6MT
Is the backing plate the rotors bolt to clean and flat? (Use wire brush) If the rotor doesn't sit flat, it will make noise. Stock brakes? (single piston caliper) If the pin isn't greased and the caliper won't slide it can make noise.
      08-20-2018, 11:35 AM   #15
cesarortiz23
Drives: bmw m2 lci
So I took apart the whole thing greased up the pins on the pad and on the calipers to make sure it has grease to slide the noise went away
Then a week later noise happen again...
I just went and bought new pads going to slap them on and see if that helps
This noise is so fucking annoying
is pissing me off
bmw m2
      08-20-2018, 11:36 AM   #16
cesarortiz23
Drives: bmw m2 lci
Is a stock brake system
The single piston..
I mean it seems to be clean but I get Ima give that a try now
So what exactly do I clean before I pick up the pads at 2:30
Or what do I need to scrub ?
The backing plate where the rotor sits ?
bmw m2
      08-20-2018, 11:40 AM   #17
rak299
Drives: 2021 M3 6MT
Yes. If there is crap there, the rotor won't sit flat and it will wobble like it is warped.
      08-20-2018, 11:49 AM   #18
cesarortiz23
Drives: bmw m2 lci
So the hub
The wheel hub where the rotor sits and bolts down
I just cleaned all of that now
I almost feel like this nose is coming from the E brake
Does the ebrake move or works aswell when you apply the brakes while driving ?
bmw m2
      08-20-2018, 12:26 PM   #19
cesarortiz23
Drives: bmw m2 lci
So I just did all of that no fix
I guess pads are next I pick them up today at 2
Hope that helps I guess
This shit is annoying
bmw m2
