BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > What springs should I get?
proTUNING Freaks
      09-12-2019, 08:58 AM   #1
xcviwp6
Drives: BMW 328i M-Sport
I have H&R Super Sport Springs on M-Sport Stock Suspension. I bought the car like that. But ride quality is horrible especially on NJ roads. So I want get rid of the springs.
What springs should I get for ride quality to become better? I can't find stock springs for RWD.
or
Any other springs that lowers car but not as drastically but ride quality still good?
      09-12-2019, 11:03 AM   #2
FaRKle!
It wouldn't surprise me if some of the harshness is coming from early bump stop engagement. You might want to think about changing those out for lower profile ones along with the springs.
Eibach springs always get my recommendation due to the fact that you can see their data sheets and know what you're getting, or choose the kit that will give you what you want even if it's not the "recommended" kit for your car.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      09-12-2019, 11:05 AM   #3
jh_f30
jh_f30's Avatar
1306
Drives: 2013 335i Sportline Auto RWD
or
H&R Sport springs are less aggressive, both in drop and spring rate. Either way, you might want to consider new dampers and shorter bumpstops to match the shorter springs with higher spring rates.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      09-12-2019, 11:52 AM   #4
xcviwp6
Thank you! I appreciate it.
      09-13-2019, 09:56 PM   #5
EDWYER
Yoda of mods
EDWYER's Avatar
1673
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Love my dinan's.
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      09-18-2019, 07:07 PM   #6
cfm56d7b
or
How many miles does your car have at the moment?
      09-18-2019, 07:27 PM   #7
xcviwp6
or
44k miles.
      09-19-2019, 12:10 PM   #8
cfm56d7b
44k miles.
What was the mileage when H&R Super Sport springs were installed?
Lowering springs can shorten the life of OEM shocks because OEM shock travel hasn't been designed to match lowering springs. Add bad roads to the mixture and OEM shock lifespan can shorten further.
I suggest to inspect the health of OEM shocks.
      09-20-2019, 12:35 AM   #9
FaRKle!
I don't agree with this statement. As long as the piston is within its allowed travel (not hitting either the top or bottom of the damper while in use) then it doesn't matter where it is within the damper as dampers are velocity sensitive, not position sensitive.
Additionally, BMW prevents the damper pistons from bottoming out by using the bump stops. As an example see my pic below. I have the piston rod fully compressed (bottomed out) and the bump stop next to it. There's absolutely no way the piston can bottom out with the thickness and stiffness of the bump stop.
When you lower and are riding the bump stops that add additional spring rate that the damper isn't tuned for, it gives you an underdamped condition, and/or harsher ride from hitting the bump stops so often. The underdamped feeling will make it seem like the shocks are worn.
      09-20-2019, 12:41 AM   #10
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
FWIW - try swapping out bumps stops as Farkle suggested. It's cheaper than a new set of springs and IF you end up getting different springs, you have to get shorter bump stops too.
      09-20-2019, 05:56 PM   #11
Jvac
Drives: 2015 335i rwd
Interesting comments here. I've been looking at the eibach pro kit springs. My stock dampers are very low mileage so I'd rather not pay to replace them right now. According to the eibach product info, the pro kit springs were designed to work with the oe bumps tops even though they lower the car by an additional. 75 inch below the m sport ride height. Yet Dinan springs do an equal drop and they recommend shorter bump stops installed. How can they both be right?
      09-20-2019, 07:41 PM   #12
FaRKle!
They can both be right based upon the variable definition of "work with."
"Work with" doesn't necessarily mean "optimized." Just like, "Developed on the Nurburgring." can mean, "We just drove this configuration on the Nurburgring once and nothing broke." and not, "We went through repeated iterations to develop and optimize the product on the Nurburgring."
It's all marketing... This is why you need to do your homework on what the product actually does, how it was really designed (what were the success criteria?), and not put blind trust into companies that don't provide data or insight.
Eibach lowering springs certainly don't make your car "not work" anymore when paired with the OE bump stops, but it's also not optimal IMO.
      09-20-2019, 08:41 PM   #13
Jvac
I was expecting you to say as much. Eibach couldn't legitimately claim their setup is superior without calling Dinan liars in the process, and vice versa. The more you read into the product listings for these shocks, springs, and coilovers, the less hard details you come away with. And some of these parts are compatible with so many different models of car that they couldn't possibly be optimized for any one model. It sucks to have to spend the time and money trying different setups to see what works best when the parts and labor are this costly.
      09-20-2019, 09:21 PM   #14
FaRKle!
Marketing: Making people believe what they want to believe without actually saying it, thus clearing oneself of culpability.
      09-20-2019, 10:35 PM   #15
xcviwp6
I was able to find OEM springs for my car off user on here. So I'm going install those.
Thank you everyone for your help and insight!
      09-21-2019, 01:18 PM   #16
Finn Germai-Yaz
Finn Germai-Yaz's Avatar
Drives: 2017 M240i
Give me the H & R Springs
      09-21-2019, 03:14 PM   #17
oregondonor
Drives: 2016 435i
Where are you located? I'd be interested in the H&Rs.
      09-22-2019, 09:27 AM   #18
JeffreyB
Drives: Bmw 335i f30
From what I understand the f30 has no camber adjustment. The Dinan springs state no camber adjustment needed. I've used eibach on many cars before and this is my first BMW so I'd like to try them out but I'm guessing if I go with the eibach I'll need and after market camber kit.
      09-22-2019, 09:31 AM   #19
xcviwp6
New Jersey. I'll post them after I get the springs installed.
      09-22-2019, 09:32 AM   #20
xcviwp6
Will post them after I get springs install.
      09-22-2019, 09:45 AM   #21
JeffreyB
What springs are you going with?
      09-22-2019, 10:07 AM   #22
Finn Germai-Yaz
Drives: 2017 M240i
Stock and giving me the h&r's
