11-09-2018, 04:58 PM | #1 |
Rep 1,079
245/50 R18 on 2014 BMW 328i xDrive Sedan?
I've an option to buy used wheels + tires that were on a 2013 X3 with the following specs:
18" x 8" Offset 43 Tires: 245/50 My current stock setup: 17" x 7.5" Offset 35 Tires: 225/50 I called tire rack and they said with 18" maximum I should go is 245/40. Does anyone have any suggestions or experience with this set of wheels? The wheels+tires are in great shape and the guy is selling them at a very reasonable price. |
11-09-2018, 11:55 PM | #2 |
Rep 4,325
oem=26", 245/50/18=27.6" . the front tire will rub the spring perch and the outer shoulder will rub the fenderwell liner while turning. tire rack recommendation is correct. 245/40/18(25.7") max size on 18x8 for F3X series.
11-10-2018, 05:28 AM | #4 |
Rep 4,325
+43 rear will work, however +43 up front will be tucked in 11mm more than OEM. It should not rub anything on non xdrive but I'm less sure about xdrive
f30, f30 wheel offset, f30 wheel specs, f30 wheels, wheel and tire |
